robbie_R Posted September 19, 2010 Share Posted September 19, 2010 Just did this to mine today. 200 at 10mins makes them come apart pretty good. Then I made a pizza Link to comment Share on other sites More sharing options...
Blind_Dude Posted September 24, 2010 Share Posted September 24, 2010 Step one - Grow a pair Step two - Take off all the pop its around the bumper (a flat head screwdriver works well). Just pop the tabs up and pull them out. There are a few on top and underneath that are easy to find. But make sure you remove the ones in the wheel wells before trying to pull the bumper off. They are right in the wheel well where the bumper meets the rest of the body. Step 3 - After all the pop its are removed and if you don't need to mod your grill the bumper and grill should come off in one piece. Just start with one side at a time and it should release from the bumper with a little force. Step 4 - After removing the bumper and setting it aside there are about 6 screws in each light that need to be removed. I did one light at a time to ensure that I knew how to put it back on. Remove the screws and the light should come out no problem. Step 5 - Remove all the bulbs and wiring from the light. There are also three screws on the back of the light that need to come out. After this throw it on some aluminum foil in the oven. I did it at 260 F for 15 minutes and there was no damage to the lights. Just loosen the tabs and pull apart with some force. Step 6 - After the light is open and apart there are three screws inside that need to be removed. Take these out and feel free to customize whatever you want. I just took off the orange reflectors which was harder than I originally thought. I used a butter knife and slid it in an opening working it around the edges until the reflector popped off (be careful not to snap off the corners of the lights). Step 7 - Put the light back together and stick it in the oven. I did the same temperature and time as when I first baked them (260 F for 15 min). I then pushed them together and much as I could, put the screws back in and popped it back in for another 5 min. Step 8 - Good luck putting your car back together! It looks messy and hard but everything pieces together like a puzzle. I don't have too many pictures but here are some and an example of how to do the pop its for those who don't know. Link to comment Share on other sites More sharing options...
jhawk222 Posted April 29, 2011 Share Posted April 29, 2011 No excuse not to clear your lights guys. I admit I was nervous so I set the oven @ 170 degrees. Lights in for 20 minutes, came right apart. Cleared them and put them back in the oven for 10 minutes, then used a bead of GE waterproof silicone and slapped them back together. Very happy with the results. Link to comment Share on other sites More sharing options...
Subie Lovers Posted September 11, 2011 Share Posted September 11, 2011 (edited) I have read through most of this tread and will be doing this and the blacking of the crome... but is there a way to tint the lens? Would I just pick up some window tint and tint the inside of the lens? And what about the rear lens? Edited September 11, 2011 by Subie Lovers more to add Link to comment Share on other sites More sharing options...
dwolson2 Posted September 16, 2011 Share Posted September 16, 2011 maybe vht tint, used it on my rears Link to comment Share on other sites More sharing options...
05 Scooby roo Posted September 17, 2011 Share Posted September 17, 2011 subie lovers, if you are going to tint your headlights, tint the outside. It is not legal to even tint headlights or tail lights but if you get any crap for it, you can remove it with ease instead of having to take the whole lens apart again. I have my tails tinted and you want to use a flexible tint. You can but it from Home Depot or Lowes. There isn't a lot of adhesive on that style tint and it flexes easy. If you use window tint, and remove it later on, it will leave a lot of the adhesive on the lens. Just my opinion, but I would black them out and leave it alone in the front. Link to comment Share on other sites More sharing options...
doobaruGT Posted December 5, 2011 Share Posted December 5, 2011 Question Fellas, I cleared my light about two weeks ago, however, my projectors were way off after install. I can't seem to get them aligned and it looks like the beams of light are "bug-eyed" out. Any suggestions? Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
FJuan Posted December 5, 2011 Share Posted December 5, 2011 Did you recheck the housing and make sure it sealed correctly? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
doobaruGT Posted December 6, 2011 Share Posted December 6, 2011 Did you recheck the housing and make sure it sealed correctly? I think I did...in fact, I resealed it with new silicone. I'll include a pic to show you what I mean, but it's like the main part of the beam faces slightly outward (bug-eyed). The horizontal adjustment only pulls the bulb over so far towards the center. Think I have to pull them apart again? Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
FJuan Posted December 6, 2011 Share Posted December 6, 2011 That maybe your best bet, to make sure it's aligned in the housing correctly. Also, recheck the bulb and see if it's seated right. If it's off, it will cause your beam to be slightly off too. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
doobaruGT Posted December 6, 2011 Share Posted December 6, 2011 Here's how the lights look from inside just behind the scoop. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
doobaruGT Posted December 6, 2011 Share Posted December 6, 2011 (edited) That maybe your best bet, to make sure it's aligned in the housing correctly. Also, recheck the bulb and see if it's seated right. If it's off, it will cause your beam to be slightly off too. I'm certain the bulb is seated correctly, guess I have to double check the projector assembly to make sure it's in the housing correctly. What a pain...ugh Edited December 6, 2011 by doobaruGT text correction Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
FJuan Posted December 7, 2011 Share Posted December 7, 2011 Yup, a pain it is. I've done 3 sets myself, and only had to reopen just one to re-align the housing. Hopefully it's just the housing. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
doobaruGT Posted December 11, 2011 Share Posted December 11, 2011 so I'm baking them now for the second time trying to reconcile the aiming issue and the first light looked as though the housing was seated correctly. I'm not sure what else to do if this doesn't work... Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
dave00100 Posted April 15, 2012 Share Posted April 15, 2012 did this a few weekends ago and couldnt be happier with the results. mad props to tsunami for helping me out! Link to comment Share on other sites More sharing options...
jswain101 Posted June 24, 2012 Share Posted June 24, 2012 I wanna try this ! Link to comment Share on other sites More sharing options...
dustdown Posted July 7, 2012 Share Posted July 7, 2012 great write-up pretty easy... ya just gotta make sure you get those turn signal bulbs that are painted silver.. it just looks cleaner that way. What I DIDN'T do was place a bead of silicone down before i put the headlight back together...I felt like the existing stuff was plenty but I realized last week in the dark that there's some space between the front and back pieces of my headlight still so I'd recommend that extra little bit of silicone before re-assembly Link to comment Share on other sites More sharing options...
WhiteRose Posted July 16, 2012 Share Posted July 16, 2012 Did this on my WRX, can't wait to do this to the LGT. Thanks for the detailed descriptions and pictures. Link to comment Share on other sites More sharing options...
dr_sharp Posted July 22, 2012 Share Posted July 22, 2012 **** those reflectors! lol. Just finished the first light. Second going in oven now. Kinda jealous of 08-09 owners yours looks easier. lol Link to comment Share on other sites More sharing options...
dr_sharp Posted July 22, 2012 Share Posted July 22, 2012 Also a 3/32nd allen wrench worked perfect for the torx screws lol Link to comment Share on other sites More sharing options...
bboygreddy Posted July 22, 2012 Share Posted July 22, 2012 grew some balls, not my first redeo in baking headlights hahah just hate the time consuming process but was very happy with the outcome! (warning i lost some chrome on the halo part the turn signal chrome was much sturdier but you literally touch the chrome on the halo and it will come off) rustoleum's semi black. i know i always get questions on whether to use high gloss, gloss, semi, flat, satin, etc etc note the halo ring missing some chrome rebaked to reactivate the old glue, lense is filthy in this pic NOTE** to remove the amber reflector on the 08-09 it's a little scary but again requires some balls. its glued onto the clear plastic lense by maybe 2-3 corners. while your headlights are hot you should be able to pry it off. work you way from the corner, it WILL sound like you're breaking something but it will come off with patience end result, instagram pic lol. bug/tar remover or any paint cleaner will remove adhesive residue, i dont know if i would use goo-gone or whatever. hit it up with some plastix after and it shined nicely while my headlights were off and apart, i closed that little peeper hole and the cut off is much sharper! Link to comment Share on other sites More sharing options...
nhltfour Posted November 12, 2012 Share Posted November 12, 2012 attempted clearing my headlights yesterday but couldnt remove the bolts that are found underneath the headlights (where the bumper attaches too) I could get all but one. Tried spraying pb blaster on it and everything. Anyone have any ideas as to how i could tackle this? cheers Link to comment Share on other sites More sharing options...
Gorilla_Douglas Posted January 24, 2013 Share Posted January 24, 2013 Sick! I so want those but never took apart a headlight Link to comment Share on other sites More sharing options...
Spec-Bro Posted January 24, 2013 Share Posted January 24, 2013 Definitely doing this! Question: How do the projector lenses work with the blacked out housing? Link to comment Share on other sites More sharing options...
Drift Motion Posted January 24, 2013 Share Posted January 24, 2013 won't make a difference projectors don't use the housing to reflect the lights Link to comment Share on other sites More sharing options...
