VTGT Posted October 24, 2006 Share Posted October 24, 2006 My friend is deadset on doing an ls6 conversion on his 1998 camaro ls1 with 75000 miles. His car right now has an slp exhaust and intake. He found a conversion ket on ebay for 1025, http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=017&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=270041790595&rd=1&rd=1 I thought a more logical approach would be long tube headers, throttle body, and possibly a 4.10 gear. For anybody that knows about f-body's what would be a good route to go. He told me that he and a couple of his friends could do the conversion themselves but It sounds pretty hard. one more thing, what 1/4 times is his car capable of with just the exhaust and intake? Link to comment Share on other sites More sharing options...
rao Posted October 24, 2006 Share Posted October 24, 2006 For that price it is not a bad idea. The LS6 is nothing more then a set of heads and a cam and a revised intake manifold. The aftermarket has much better stuff available. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
bosco Posted October 24, 2006 Share Posted October 24, 2006 the LS6 is the same as an LS1 but changes where made by casting windows into the block between the cylinders, improved intake manifold, higher lift cam, higher compression, and a new oiling system better suited for high lateral acceleration. bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
HansGT Posted October 24, 2006 Share Posted October 24, 2006 Ask MDTURBO. Rob used to be a GM guy. Link to comment Share on other sites More sharing options...
rao Posted October 24, 2006 Share Posted October 24, 2006 http://www.ls1tech.com Also, the change in casting was made afer 98 to all LS1 blocks. The 02 F-bodies have the revised intake manifold as well. The oil pumps were also all changed in02 IIRC. Heas, cam and exhaust will get you to around 450 at the flywheel wihout any trouble. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
RangerMan Posted October 25, 2006 Share Posted October 25, 2006 That is a pretty good price. Aftermarket heads and cam will run about that much as well. How long does he plan on keeping the car? If he is going to keep it for a while or pretty seriously race it, why stop at just the heads and cam? At 75k miles he might as well bore the cylinders, rebuild & balance the bottom and deck the block? Does the LS6 already require premium? Link to comment Share on other sites More sharing options...
itsme Posted October 25, 2006 Share Posted October 25, 2006 It depends on what he is trying to do. Get a supercharger. It will make the car faster then all the things you said combind. Paxton make one for about $3500 I think. They have centrifugal SC that mount just like an alternator. Easy to install and at least 100+hp. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
RangerMan Posted October 25, 2006 Share Posted October 25, 2006 But then he will have a supercharger on a 75k motor with new heads. Eventually he will have to rebuild the bottom end. I would rather put the money into building a solid, well matched motor, balanced motor. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted October 25, 2006 Share Posted October 25, 2006 intake, exhaust, heads and a cam Link to comment Share on other sites More sharing options...
Hagarr Posted October 26, 2006 Share Posted October 26, 2006 Now I am starting to feel at home. The question is how much power does he want? I have a 98 and I wouldn't even buy the LS6 heads. There are much better aftermarket heads available. Buy an LS6 intake, cam of your choice ( www.thunderracing.com ), pushrods, springs, longtube headers and be done with it. You can have a 400+ rwhp dependable daily driver. Yes you might take a small hit on gas mileage but it is worth it. It's all in the tune...you guys understand that The LSX engines are so lovable Brian 98 Formula Link to comment Share on other sites More sharing options...
Hagarr Posted October 26, 2006 Share Posted October 26, 2006 Oh one more thing... http://www.ls1tech.com B Link to comment Share on other sites More sharing options...
urfsin Posted October 26, 2006 Share Posted October 26, 2006 Well, to keep with the roots of this forum, I say TURBO charge it!! I know that Lingenfelter does some wicked twin turbo stuff on his vette's. Slide It Sideways Link to comment Share on other sites More sharing options...
VTGT Posted October 26, 2006 Author Share Posted October 26, 2006 Now I am starting to feel at home. The question is how much power does he want? I have a 98 and I wouldn't even buy the LS6 heads. There are much better aftermarket heads available. Buy an LS6 intake, cam of your choice ( www.thunderracing.com ), pushrods, springs, longtube headers and be done with it. You can have a 400+ rwhp dependable daily driver. Yes you might take a small hit on gas mileage but it is worth it. It's all in the tune...you guys understand that The LSX engines are so lovable Brian 98 Formula Glad you are right at home. How much for above said mods if you got decent prices and did all the work yourself, around 2000? Link to comment Share on other sites More sharing options...
Prod Posted October 26, 2006 Share Posted October 26, 2006 Cams + Full exhaust + beefy rear to take it = 400+whp streetable. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted October 26, 2006 Share Posted October 26, 2006 Well, to keep with the roots of this forum, I say TURBO charge it!! I know that Lingenfelter does some wicked twin turbo stuff on his vette's. its really hard to squeeze a turbo in the camaro's engine bay. a lot of ppl do the rear mound setup Link to comment Share on other sites More sharing options...
urfsin Posted October 26, 2006 Share Posted October 26, 2006 Well if Twin Turbo is a PITA, then at least supercharge it. I figure with supporting mods you could get 450whp. Slide It Sideways Link to comment Share on other sites More sharing options...
RangerMan Posted October 26, 2006 Share Posted October 26, 2006 Glad you are right at home. How much for above said mods if you got decent prices and did all the work yourself, around 2000? Buy an LS6 intake, $500 cam of your choice ( http://www.thunderracing.com ), $390 custom That website looked like they would put together a cam/spring package fro you as well. pushrods, $150 (manley) springs, $150 longtube headers and be done with it $300 These are pretty much estimates from Jegs, he can probably find some better prices on these. The intake is an estimate from eBay. That comes to like $1490. Staying under 2k shouldn't be a problem. Link to comment Share on other sites More sharing options...
Hagarr Posted October 26, 2006 Share Posted October 26, 2006 Buy an LS6 intake, $500 cam of your choice ( www.thunderracing.com ), $390 custom That website looked like they would put together a cam/spring package fro you as well. pushrods, $150 (manley) springs, $150 longtube headers and be done with it $300 These are pretty much estimates from Jegs, he can probably find some better prices on these. The intake is an estimate from eBay. That comes to like $1490. Staying under 2k shouldn't be a problem. RangerMan is pretty darn close. You can buy LS6 intakes all day long on LS1tech for $300-350. Thunderracing has cam packages along with gaskets as well to make the swap real easy. You can buy the longtubes used as well and save some cash but a 300 budget won't get you too far b/c you'll need a new y-pipe as well. Find some ceramic coated headers or you'll be buying new ones as soon as 2 yrs b/c of rust. I am actually selling my cam TR230 /springs Comp 918 / hardened pushrods/ LS6 oil pump / all associated gaskets. I bought the cam/springs/pushrods from a buddy of mine. He put about 6k on it until his wife made him get rid of the car...he de-modded. Oil pump/gaskets all brand new. Brian Link to comment Share on other sites More sharing options...
GTTuner Posted October 26, 2006 Share Posted October 26, 2006 My buddy has an '02 Camaro SS. Special orderd with the 335hp motor, no rear defogger, ya da de da and so on. Well, my little LGT ran away from him last year going up an on ramp to the highway. My car was all the sudden "The balls" according to him. He just had a supercharger installed last week. The installer tuned it to, get this, 436WHP @5000 rpm. Problem is he is making 7.5psi of boost at 5000rpm. So he cant rev it over 5k. They have the biggest pulley they can fit in there....so he's screwed on that. Here's the result. First gear, useless. Second gear, goes up in smoke after 3500rpm. Third gear it's light out man. That car is nutty, crazy, out of control fast. My feeling is he will blow it up as he passes me in third. Link to comment Share on other sites More sharing options...
urfsin Posted October 26, 2006 Share Posted October 26, 2006 My buddy has an '02 Camaro SS. Special orderd with the 335hp motor, no rear defogger, ya da de da and so on. Well, my little LGT ran away from him last year going up an on ramp to the highway. My car was all the sudden "The balls" according to him. He just had a supercharger installed last week. The installer tuned it to, get this, 436WHP @5000 rpm. Problem is he is making 7.5psi of boost at 5000rpm. So he cant rev it over 5k. They have the biggest pulley they can fit in there....so he's screwed on that. Here's the result. First gear, useless. Second gear, goes up in smoke after 3500rpm. Third gear it's light out man. That car is nutty, crazy, out of control fast. My feeling is he will blow it up as he passes me in third. So in 1st and 2nd he just smokes tires?? Well, with 436 whp I guess you need a lot of traction. What kind of tires does he have? I would hope with that much power you would have like 325's or something. Gotta stick to the tarmac to put all that power down!! Slide It Sideways Link to comment Share on other sites More sharing options...
GTTuner Posted October 27, 2006 Share Posted October 27, 2006 LOL, he has bald Nitto's on there. I told him he better get some DOT drag radial's for the rear tires. He will be putting it away for the winter soon. Hopefully tonight I will get to drive it.....I can't wait. Link to comment Share on other sites More sharing options...
GTTuner Posted October 30, 2006 Share Posted October 30, 2006 I drove the beast Friday night. Awesome to say the least. Link to comment Share on other sites More sharing options...
Hagarr Posted October 31, 2006 Share Posted October 31, 2006 I am looking to sell my Formula LS1 and buy a SpecB. It will be a huge sacrifice in power...hard to live life without a V8 once you've had one. I am sure I'll be mostly satisfied with the SpecB once tuned. Brian Link to comment Share on other sites More sharing options...
