CasopoliS Posted February 26, 2007 Share Posted February 26, 2007 I might consider 650s then. I don't plan on going larger than my 18G vf40 actually. I am happy where I sit, and have much more going on in my life that requires attention (and money!). Link to comment Share on other sites More sharing options...
bosco Posted February 26, 2007 Share Posted February 26, 2007 are the DW 740's i plan on using to large for my AVO 380 turbo? starting to get confused again. bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
fweasel Posted February 26, 2007 Share Posted February 26, 2007 are the DW 740's i plan on using to large for my AVO 380 turbo? starting to get confused again. bosco No. When properly tuned, the injector can never be too large (within reason, yada yada yada 1000cc will effect idle). Bosco, you're golden with your set-up. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
bosco Posted February 26, 2007 Share Posted February 26, 2007 No. When properly tuned, the injector can never be too large (within reason, yada yada yada 1000cc will effect idle). Bosco, you're golden with your set-up. just checking. bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
Joon525 Posted February 27, 2007 Share Posted February 27, 2007 I believe the 740's should be OK with the AVO420 as well correct? Link to comment Share on other sites More sharing options...
edmundu Posted February 27, 2007 Author Share Posted February 27, 2007 I believe the 740's should be OK with the AVO420 as well correct? I run them on an Avo450....what do you think;) Link to comment Share on other sites More sharing options...
fweasel Posted February 27, 2007 Share Posted February 27, 2007 I run them on an Avo450....what do you think;) I think the transitive property is a beautiful thing... ignore him, he'll go away. Link to comment Share on other sites More sharing options...
bosco Posted February 27, 2007 Share Posted February 27, 2007 I think the transitive property is a beautiful thing... quit making me look up words bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
fweasel Posted February 27, 2007 Share Posted February 27, 2007 quit making me look up words bosco quit posting to stay three ahead of me... ignore him, he'll go away. Link to comment Share on other sites More sharing options...
bosco Posted February 27, 2007 Share Posted February 27, 2007 quit posting to stay three ahead of me... i feel like your following me bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
CasopoliS Posted February 27, 2007 Share Posted February 27, 2007 get a room. this is not OT Link to comment Share on other sites More sharing options...
Joon525 Posted February 27, 2007 Share Posted February 27, 2007 I run them on an Avo450....what do you think;) *smacks forehead* I totally forgot you were running the 450. Link to comment Share on other sites More sharing options...
bugblatterbeast Posted March 18, 2007 Share Posted March 18, 2007 I installed a set yesterday. These things rock. Fuel scale was within 1% of predicted and latency was very close to stock (trimmed up just a hair to get a better idle). The injector noise at idle seems a little louder than stock but I attribute the extra noise to a fresh set (harder) of o-rings. Tip in was just a scaled version of my old table. For anyone installing these in the cold.... don't... or get a heated garage + heat gun. When the engine is cold and the injectors are cold, the o-rings are far too hard to allow easy removal or insertion. I had to warm the injectors to a bit above body temperature before the o-rings would flex enough to allow them to go in. I would avoid running these without a tune if you live somewhere cold. Just as an experiment, I left the scale value at the stock setting. At 0 degrees, I could barely get the engine to start and it wouldn't stay running (only tried once... it stalled in seconds). Link to comment Share on other sites More sharing options...
CasopoliS Posted March 18, 2007 Share Posted March 18, 2007 Mine should be here monday. I am installing them Friday since my tune is Saturday morning. The guy tuning has never tuned COBB stuff (I have Street Tuner).... but he has tuned everything else under the sun so I am sure he will figure out the COBB interface.... after all, that is the only thing different when it comes to tuning. I will keep everyone posted. Link to comment Share on other sites More sharing options...
rc0032 Posted March 18, 2007 Share Posted March 18, 2007 Mine should be here monday. I am installing them Friday since my tune is Saturday morning. The guy tuning has never tuned COBB stuff (I have Street Tuner).... but he has tuned everything else under the sun so I am sure he will figure out the COBB interface.... after all, that is the only thing different when it comes to tuning. I will keep everyone posted. The Cobb interface is easy. Have you married the ST to the AP yet? If so someone with these injectors can send you over the correct numbers for them so you wont have any issues. We could also build you a temp map to make it to the tuner on Link to comment Share on other sites More sharing options...
CasopoliS Posted March 18, 2007 Share Posted March 18, 2007 The Cobb interface is easy. Have you married the ST to the AP yet? If so someone with these injectors can send you over the correct numbers for them so you wont have any issues. We could also build you a temp map to make it to the tuner on niiice, but I dont have a WB AFR yet. Right now I am on a TDC map for my vf40 18G. I have not married yet because I did not want to eliminate that TDC map. Link to comment Share on other sites More sharing options...
rc0032 Posted March 18, 2007 Share Posted March 18, 2007 Stock intake? You don't need a WB to get a tune capable of getting you to the tuner. A/F is actually one of the last steps Link to comment Share on other sites More sharing options...
CasopoliS Posted March 18, 2007 Share Posted March 18, 2007 Stock intake? You don't need a WB to get a tune capable of getting you to the tuner. A/F is actually one of the last steps I think I will be able to get to the tuner, they are 10 minutes down the road. Is there a way to get my current ProTune map into ST format? I could then load that map and take logs for you guys. Yes stock intake. Link to comment Share on other sites More sharing options...
sgt Posted March 18, 2007 Share Posted March 18, 2007 ask your tuner to convert it for you Link to comment Share on other sites More sharing options...
CasopoliS Posted March 18, 2007 Share Posted March 18, 2007 ask your tuner to convert it for you k thanks. though... he is moving to Cali... I don't know how available he is. Link to comment Share on other sites More sharing options...
rc0032 Posted March 18, 2007 Share Posted March 18, 2007 Is there a way to get my current ProTune map into ST format? I could then load that map and take logs for you guys. Someone with a ProTunner can do it. Your tuner (using your ST) can not. But that shouldn't matter he can tune it from the ground up. Just let him tune it and be done no need to mess around Or bring it to the Columbus meet next week and I will do it for you Link to comment Share on other sites More sharing options...
CasopoliS Posted March 18, 2007 Share Posted March 18, 2007 Someone with a ProTunner can do it. Your tuner (using your ST) can not. But that shouldn't matter he can tune it from the ground up. Just let him tune it and be done no need to mess around Or bring it to the Columbus meet next week and I will do it for you you can road tune? I want this local guy to do it, so later on he is familiar with my car. It will end up costing me a ton though, cuz from the ground up he will take his time and get it right. which could be a few hours. Link to comment Share on other sites More sharing options...
rc0032 Posted March 18, 2007 Share Posted March 18, 2007 you can road tune? I want this local guy to do it, so later on he is familiar with my car. It will end up costing me a ton though, cuz from the ground up he will take his time and get it right. which could be a few hours. I'm road tuning mine (with rao's teaching along the way) so yes Read over this its not that hard -> http://www.cobbforums.com/forums/showthread.php?t=31214 Having the AP and ST married and the ST stage2 flash done before you get to him will save you at least an hour. From there its just a mater of time and logs to get your setup dialed in. This thread is way off track PM me or start a new thread if you have any more Q's -> some good info in here also -> http://legacygt.com/forums/showthread.php?p=759866#post759866 Link to comment Share on other sites More sharing options...
fweasel Posted March 18, 2007 Share Posted March 18, 2007 For anyone installing these in the cold.... don't... or get a heated garage + heat gun. When the engine is cold and the injectors are cold, the o-rings are far too hard to allow easy removal or insertion. I had to warm the injectors to a bit above body temperature before the o-rings would flex enough to allow them to go in. FWIW, mine were installed yesterday in 40* weather. They sat in the trunk of my car overnight, below freezing temps. No problems going in. Pulling the wire harness clips off the stockers was a little rough on the cold fingers, but that was about it for issues. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted March 18, 2007 Share Posted March 18, 2007 I can't remember where on cobbforums that I found this, but it explains how to tune the fuel injectors. You don't need a WB if the injectors have already been flow tested. For the 32bit DBW ECU, I believe you just type in the cc/min flow value. There are instructions on how to adjust the tip-in and latency. However, from reading edmundu's and bugblatterbeast's comments, it sounds like those don't need to be adjusted very much.How To Establish Proper Fuel Injector Table Settings v1[1].00.pdf Link to comment Share on other sites More sharing options...
