praedet Posted March 28, 2008 Share Posted March 28, 2008 I believe I had a eureka moment. It wasn't the startup enrichment that is the problem, it's entering closed loop too soon and can't get a good enough mixture to do this in a stable way. It's already too rich IMHO. Left all the coolant temp enrichment tables alone except for "Minimum open loop enrichment idle (coolant temp)". I changed the 0.70 load row to 13.34 AFR up to the 68 degrees column. The car went from very rich to 13.34 AFR quickly, usually at this point I'd expect idle to start bouncing around, but instead it stayed at 13.34 AFR all the way until 93 degrees (~15 seconds after is crossed into unenriched vales). Smooth, no problems. You wouldn't guess it was modifed. Leave the other tables alone!Hmmm, I guess I will be changing this w/ the TGV deletes in a few days... Link to comment Share on other sites More sharing options...
