fweasel Posted September 8, 2006 Share Posted September 8, 2006 I've been searching, but can't find the post where someone had a picture of their stock heat shield and the pattern drawn out of what they cut away. Can anyone point me to that f#@ker? Thanks. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
rc0032 Posted September 8, 2006 Share Posted September 8, 2006 Its called Steve Link to comment Share on other sites More sharing options...
fweasel Posted September 8, 2006 Author Share Posted September 8, 2006 Its called Steve Will he set himself on fire? PB blaster mey be present. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
LGT Dave Posted September 9, 2006 Share Posted September 9, 2006 I think you mean this: http://www.legacygt.com/forums/attachment.php?attachmentid=12184&d=1133008193 Also a good pic here: http://www.legacygt.com/forums/attachment.php?attachmentid=22577&d=1155194337 And here: http://i6.photobucket.com/albums/y207/Pisadong/PerrinDP005.jpg Link to comment Share on other sites More sharing options...
rao Posted September 9, 2006 Share Posted September 9, 2006 Sharpie + cut off wheel = perfect heat shield Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
fweasel Posted September 9, 2006 Author Share Posted September 9, 2006 I think you mean this: http://www.legacygt.com/forums/attachment.php?attachmentid=12184&d=1133008193 Also a good pic here: http://www.legacygt.com/forums/attachment.php?attachmentid=22577&d=1155194337 And here: http://i6.photobucket.com/albums/y207/Pisadong/PerrinDP005.jpg No, that's not even remotely close to what I was talking about. Are you high? errr. I mean thanks, that's the one! ignore him, he'll go away. Link to comment Share on other sites More sharing options...
fweasel Posted September 9, 2006 Author Share Posted September 9, 2006 Sharpie + cut off wheel = perfect heat shield Will a dremel cut off wheel work or do you need something thicker? ignore him, he'll go away. Link to comment Share on other sites More sharing options...
rc0032 Posted September 9, 2006 Share Posted September 9, 2006 Will a dremel cut off wheel work or do you need something thicker? I got one you can use, let me know when Link to comment Share on other sites More sharing options...
rao Posted September 9, 2006 Share Posted September 9, 2006 Will a dremel cut off wheel work or do you need something thicker? It depends on how much time you have Something larger is better - a 4" cut off whell will get the job done in a few minutes, a Dremel will take a lot longer and it will be harder to get it done right. If just want it done I'll do it for you, if you want it perfect, I am sure the Doc will take care of it for you. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
fweasel Posted September 9, 2006 Author Share Posted September 9, 2006 I got one you can use, let me know when I'll probably need it right after you and Steve finish the UP:lol: ignore him, he'll go away. Link to comment Share on other sites More sharing options...
NutBucket Posted September 11, 2006 Share Posted September 11, 2006 Will a dremel cut off wheel work or do you need something thicker? Make your life easier. It took me about 5-10 minutes using tin snips, pliers, and vice grips. Dremel would have taken much longer. Link to comment Share on other sites More sharing options...
jagcars26 Posted September 11, 2006 Share Posted September 11, 2006 Make your life easier. It took me about 5-10 minutes using tin snips, pliers, and vice grips. Dremel would have taken much longer. +1 Link to comment Share on other sites More sharing options...
Waxiboy Posted September 12, 2006 Share Posted September 12, 2006 Will a dremel cut off wheel work or do you need something thicker? I used Dremel on mine...about 30 minutes and 4 cut-off wheels. Link to comment Share on other sites More sharing options...
SeeeeeYa Posted September 12, 2006 Share Posted September 12, 2006 I bought a cut off machine and wheels. I bought a proper fiber cut off wheel for my Dremel to augment the many regular ones. Then when I got right down to it I used a hacksaw. Zipped it right apart in no time. I started to use the other things and found them loud, messy, and slow. Siince then I've found other uses for the cutoff machine, so I'm not sorry I bought it. But for this job, and others like it involving thin metal, a hacksaw is your friend. Link to comment Share on other sites More sharing options...
Steiner Posted September 13, 2006 Share Posted September 13, 2006 I don't know what the frigg you guys do with your dremels, but I used one wheel and cut off way more than I needed to in less than five minutes. You know you can turn it on and not just move it back and forth like a saw, right? My advice would be to hack it up while you've still got the dp off the car so you can use it as a guide. Wish I had done that. Experience is something you don't get until right after you needed it. Link to comment Share on other sites More sharing options...
TSiWRX Posted September 13, 2006 Share Posted September 13, 2006 5 minutes using a pair of tin-snips. Done with DP already on-vehicle. Just a matter of trial-and-error. And no, I don't have an inhuman grip or anything of the like.... I'm still working on closing Captains of Crush #2. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
