MiniStiGuy Posted November 7, 2007 Share Posted November 7, 2007 to do basemap you connect green connectors. flash then turn off the car and disconnect them. then turn car to on again and flash real-time map. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
VTGT Posted November 7, 2007 Share Posted November 7, 2007 to do basemap you connect green connectors. flash then turn off the car and disconnect them. then turn car to on again and flash real-time map. I know. I have done that so many times. The base map flashes but the real-time does not. After a lot of aggravation TDC finally just made me a custom map with everything on the base map. Link to comment Share on other sites More sharing options...
parkergc8 Posted November 8, 2007 Share Posted November 8, 2007 Hmm. I have a 2005.5 AP and for some reason my ECU will never let me flash the realtime map. Only the base map flashes Maybe I should be using a 2005 AP. I think my vin is 5*213895 Call into Cobb and talk to tech support. This shouldn't be the case. If you can read live boost from the cfar you should be able to change RT maps. Keep inmind that the RT maps wont be listed in the show current map feature. Link to comment Share on other sites More sharing options...
VTGT Posted November 8, 2007 Share Posted November 8, 2007 Call into Cobb and talk to tech support. This shouldn't be the case. If you can read live boost from the cfar you should be able to change RT maps. Keep inmind that the RT maps wont be listed in the show current map feature. I know they are not listed. Only reason I know that the realtime map is not working, is because TDC puts a lot of their maps on the real-time map. My car was running horribly and I was boosting like 13-14 lbs when I thought I had the base and realtime flashed. However when TDC put all of their data on a base map it worked great.... Link to comment Share on other sites More sharing options...
VXCL Posted December 6, 2007 Share Posted December 6, 2007 reading more carefully over old threads... this only applies to auto trannys? im got a 5mt so im good then MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Leonardo Posted December 6, 2007 Share Posted December 6, 2007 Nope, applies to MT as well. It was a mid year model change on the platform. Link to comment Share on other sites More sharing options...
VXCL Posted December 8, 2007 Share Posted December 8, 2007 Nope, applies to MT as well. It was a mid year model change on the platform. SOB! lazy and dont feel like dealing with it MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
BigBad Posted December 9, 2007 Share Posted December 9, 2007 Applies to the MT too, really? On cobb;s site the map notes for the 2005.5 software only lists the AT. Where as the 2005 map notes list a choice of MT or AT Link to comment Share on other sites More sharing options...
