How to Install a Laser Jammer
this is how i installed a blinder xtreme m20 to my L7.
http://www.myradardetector.com/images/large_blinder.jpg
please use at your own risk, it may very well be illegal in every state... but this thread could be useful for installing other electronics, so please no ranting about that.
Supplies:
Phillips Head screwdriver
Contents of Blinder Xtreme (includes zipties, leveler, etc)
Dremel with cutting tool
Pliers
Flat-head screwdriver
Welding Glue or a drill
1. Read the directions a few times. It is very important the detector/jammer units are precisely leveled (horizontal to ground) and pointing directly forward. They should also be between 50-60cm apart.
2. I did not want to drill... JB Weld glue is just as strong a bond... so I cleaned the area, mixed the glue, and stuck the detecting units on. They fit plush against the bumper, see pic.
Press tightly for 4 minutes.
http://i114.photobucket.com/albums/n249/Triskite/flash.jpg
Barely noticeable.
http://i114.photobucket.com/albums/n249/Triskite/noflash.jpg
3. Feed the wire from the back of the detector unit up into the main engine bay. I first fed it through the grill.
http://i114.photobucket.com/albums/n249/Triskite/feedthrugrill.jpg
4. Place it along a suitable route to the rear of the hood... refer to picture in step 5 for where the wires will be fed through.
http://i114.photobucket.com/albums/n249/Triskite/wiring.jpg
Zip-tie it down.
http://i114.photobucket.com/albums/n249/Triskite/ziptie.jpg
5. The two phone-cord connectors should be fed through a hole concealed beneath this rubber stopper:
http://i114.photobucket.com/albums/n249/Triskite/rubberpopper.jpg
NOTE: MAKE SURE YOU CLOSE THIS when you finish, otherwise you will hear a loud whistling during acceleration. By "close" I mean ensure both pop-in sections are popped in place on both sides of the rubber.
6. Remove the driver's dash covers. You will need a phillips, and thats it. There are two screws here and some pop-its.
Start with the panel by the pedals, unscrew a few pop-its and one phillips.
Sorry for the lack of pics, refer to the DLR Delete walk-thru for specifics.
http://i114.photobucket.com/albums/n249/Triskite/coverofffusebox.jpg
Unplug the wires and remove the upper dash cover.
http://i114.photobucket.com/albums/n249/Triskite/backofdash.jpg
OK. Why are we doing this?
There needs to be a suitable location for the beeper/light and the on/off switch.
I was thinking about this as I took off the dash and realized something.
http://i114.photobucket.com/albums/n249/Triskite/notmycar.jpg
That is not my car, as I have a working left button there.
PS what is the right one do?
http://i114.photobucket.com/albums/n249/Triskite/whatdo.jpg
Anyway so we are going to make one of the two useless buttons useful.
7. Remove the crazy/useless button box.
http://i114.photobucket.com/albums/n249/Triskite/crazything.jpg
8. Open up the box. It requires one or two flatheads to unopop it.
9. Carefully remove one of the empty buttons and install the provided button.
http://i114.photobucket.com/albums/n249/Triskite/opencrazything.jpg
10. Dremel/cut a hole/area for the wires to go out.
http://i114.photobucket.com/albums/n249/Triskite/dremehere.jpg
http://i114.photobucket.com/albums/n249/Triskite/pickdremelspot.jpg
The red is where I dremeled, but the wire could be fed through holes marked by the blue dots.
http://i114.photobucket.com/albums/n249/Triskite/pickdremelspot2.jpg
11. Close it up. It should look like this:
http://i114.photobucket.com/albums/n249/Triskite/wiresthruthing.jpg
http://i114.photobucket.com/albums/n249/Triskite/littleguy.jpg
12. Wire the black (negative) wire to ground (anything metal, basically, I used a random screw I found up under the dash)
13. Wire the red (positive) to a fuse or directly to the battery. I used my cigarette power fuse (the fuse directly above the bottom left fuse) by splicing the red wire and wrapping it around the metal of the fuse.
14. Pop everything back into place. I wired the buzzer/beeper up by the steering wheel, but I may just leave it tucked in the dash completely... the buzzer is pretty loud.
15. Finished product
http://i114.photobucket.com/albums/n249/Triskite/done.jpg
Sorry for the convoluted logic/language...
Also this is my first time ever trying anything with electricals.
So.
Enjoy.
Nice job, except your pictures ARE TOO BIG!!!
I am not sure, but I think the units are placed too deep in the bumper. The beam my be blocked that way. Here are some pictures from my install of the same LJ:
http://legacygt.com/forums/647284-post53.html
OTOH, I think mine may be little bit too close too each other. Due to the bumper skin curvature I could not space them farther apart without running into levelling issues.
Besides with you read raderdetector.net forum Blinder M20 is not that effective, people say. Supposedly coating headlights with Veil helps. I don't know do not feel like putting some goo on the headlights. There better units made and sold in Europe (Antilaser).
i was pretty careful that nothing obstructs their view... keep in mind it will be a straight shot of many hundreds of yards so being far inside the bumper shouldnt matter as long as nothing is in the way..
does it work for you?
do you have a link for the european version?
Very nice! Pix are a little big, but nice work! :D
Brother unclemat - I think that the effectiveness of the jammers have a lot to do with the use of differing equipment by local/regional enforcers. It's the reason why I chose to go with the Escort ZR3, instead - but if I lived in another area, it may very well be that the Blinder would have suited my needs better.
I feel, actually, the same way of top-flight detectors....that they all work exceptionally well, and it's just a matter of choosing the right product to fit both your personal needs/preferences as well as to best counteract local enforcement practices.
<-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges
'16 Outback, '16 WRX, 7th Subaru Family
  • 2 weeks later...
Awesome work. How much does this radar cost, where did you get it? How well does it work compared to higher end radars like $300 Window mount for example? so many questions... it looks awesome though.
I was selling them here as a group buy just a while ago for $295 shipped...
I also took a video of the Blinder running on the car, with a DV camera. If you're interested, you can view it working here: http://www.filelodge.com/files/hdd6...u%20Blinder.avi (5MB AVI XVID file)
The video requires the freeware XVID codec (DivX will work too, I think?) XVid windows binaries can be obtained here: Koepi's Media Development Homepage
Haven't had a chance to "test it out" in real life yet (that's a GOOD thing)... trying to find a *friendly* cop who would like to give it a try :)
Triskite - nice, detailed install - especially the switch location. I installed mine on the fusebox "door" panel thingy... that way it's accessible, yet not visible. You certainly went the extra mile with your switch!
  • 7 months later...
I'm just now completing install on my second LPP setup (I'll now have two heads up front, with one out rear; plus the old ZR3, of course).
Stay-tuned for new Guys of LIDAR results from their latest round of countermeasures testing. :) Should be very interesting.
Cool. I feel I need to upgrade my Bilnder.... source for LPP? Reviews?
^ Don't upgrade *just yet* bruddah - GOL's results are due out within the next week to week-and-a-half, and that'll be worth waiting for. :)
For the LPP, there's now a North American re-seller:
For USA and Canada --
Email:sales@laserproparkusa.com
My contact there is Alex (Ian) Chang. I've gotten nothing short of *exceptional* service from them so far.
Here's a copy of the post I made on RD.net regarding my latest purchase:
Just keeping you updated, bro:
I *honestly* hadn't expected this until the 23rd! http://www.radardetector.net/images/smiles/icon_biggrin.gif At least that's what the "Expected Delivery" date said when I last checked DHL over the weekend. Go figure. http://www.radardetector.net/images/smiles/icon_rolleyes.gif
My nanny got the package yesterday (thankfully, as it was raining/snowing out, but regardless, DHL did do a very nice job of putting it in a thick plastic bag) but didn't call me, so I didn't know until I got home. What a nice surprise!
They did an *awesome* job on packaging! Everything stayed in-place, which had been a problem of my first purchase in that the heads and control-box came out of their boxed retaining slots. I'd suggested to the distributor/packer that they take a few minutes to secure everything in-place with packing tape, and it looks like they listened. http://www.radardetector.net/images/smiles/icon_smile.gif Also, it looks like they're checking the package more carefully now, as my first purchase was missing the small mounting hardware, but this one was again extra-secured.
I interrupt the copy-paste here to say that with my initial purchase of the dual-head unit through the NA LPP re-seller, it was when they were just starting-up, and they were rather inexperienced in shipping/packaging. My original shipment came without some of the smaller mounting hardware (bubble level, zip-ties, adhesives, etc.), and the control box and heads were loose-in-package as they'd shifted out-of-place during shipment.
I contacted Alex to let him know of the problems, and made courteous suggestions to help them better their packaging - and it looks like they took that to-heart. :)
Of my original purchase with them, it took quite a while (as it was their initial shipment), but Alex kept me well-aware throughout the entire lead-time, even during the holiday season. Again, excellent.
This time, they had built-up stock, and they were able to ship immediately. I ordered and paid on Friday, the unit arrived on Monday of the very next week. Well-done.
In any case, in-preparation for the coming install, I'd already re-configured my car's interior setup so as to allow for a better consolidated and easier to actuate x50/ZR3 controls (I reconfigured so that I could use the ZR3's mute on the x50, allowing for a faster and easier "shut down" of jamming transmission), as well as to allow for side-by-side mounting of the incoming LPP control with my current LPP switchgear.
My hope is that this will help cut down on the time/actions-needed when I encounter enforcement and give me a better chance to shut-down jamming. As I keep adding countermeasures, I find that to get a coordinated set of actions is something that is nearly impossible to "train for" as I simply can't practice the scenario ( I used to be a martial-artist, so I know the value of practice in situations of stress http://www.radardetector.net/images/smiles/icon_smile.gif ) - I hope that my consolidation of the controls will help.
When I'm done, as with what I had before, everything will be buried in the ashtray, which as you know is conveniently placed adjacent to the stickshift - allowing me to retain my preference of off-hand actuation of the switchgear while driving (I drive a manual, as you may remember, and, I also prefer to downshift-to-slow, if possible; thus my preference for keeping the controls near the stick, for use with my off-hand). I still need to fine-tune the mounting depth of my project enclosure within the ashtray cubby, so that I can again, as before, close the ashtray door to hide my switchgear out-of-sight, should I choose.
I've currently also had time to drill another hole in my custom gauge cluster panel in the central dash "cubby" in order to house the other LED. They're now in a vertical "up/down" vs. "front/back" relation. Fine-tuning of this will be to cut up a couple of rubber grommets so that they can serve as a visual "shield" from disturbing my passengers. The panel, for your reference, is one of Jon's "Cubbypods" - I have the dual-gauge model. You likely will not be able to utilize this due to your RHD (versus our LHD, as they configure the gauges to be tilted towards the driver) configuration - but he does have other panels available that should suit your needs.
Note that the RD.net enthusiast whom I'm writing to is the proud owner of an '04/05 Legacy SpecB, NZ-spec. :cool:
I've also completed running the additional main control loom by placing the speaker again over by the base of the stickshift's trim panel. They're now sticking out of the trim bezel, looking like "alien eyes on antennae." http://www.radardetector.net/images/smiles/icon_lol.gif Strangely, it looks better than having just one sticking up. http://www.radardetector.net/images/smiles/icon_redface.gif
I've also run out some extra wire lengths so that I can get the second control box positioned closer to the end of the rear LPP head's wiring length. This gives me a little better wire run, as I didn't want to have to fish-tape under the rear carpeting (which I've been told, on our cars, is a total pain in the butt). It's not a completely hidden install, but for me it's good enough. I just need to fine-tune this by weatherproofing the rear control box junction, which now resides under the driver's seat. As I've mentioned before, unfortunately, on our LGTs, the wire run length from the LPP heads is just-short of being able to complete a run to our trunk, so this is a remdial measure.
The only thing I have left to do, really, aside from the fine tuning stuff, is to trail-out the new front head, and re-mount both it, it's sister, as well as the ZR3 heads. This external step is actually going to take me the least amount of time, as I've already done it many times before. The interior work has taken me a total of about 4 hours so far, including stripping out my x50 SmartCord direct-wire. The most time-consuming step was actually making the cosmetic plate for the LPP controls, and the rather harrowing drilling of the custom face-panel that supports two of my auxiliary gauges.
Their on-line Support Forum is:
http://www.laserproparkusa.com/forum/index.php
Unfortunatley, there's a bit of static between several members of the community right now, leading to a lot of crap-talk and a rather bad signal-to-noise ratio. However, there is decent technical resource there (and the Admin and Support Staff, as well as fellow owners, are quick to answer questions, too, should they arise) - and this, combined with the RD.net Forums, should help guide your purchase decision (read: product reviews).
Aside from overall build-quality - which is excellent - I'm rather unable to render any testimony regarding performance vs. LIDAR.
My daily commute just doesn't see LIDAR enforcement but for the rare Blue Moon :redface: - and even then, I'm usually sticking so close to the PSL that by visual reference, LEOs rarely even bother to shoot me with RADAR/LIDAR. :lol: In-city, I drive like an old maid, and countermeasures is a confessed "hobby" for me. :)
On clear, open highways, that's another story, but I haven't taken any good road-trips lately. :(
Privately, there's at least one GOL member who still "loves" the LPP and AL - he's said that again and again even after the most recent round of testing - so even though the results are not yet public, I'd say that it's safe to assume that even if the LPP isn't the best, it does rank up there.
To me, even if the LPP isn't the "best performer," I'd still go with it, chiefly due to the ease of shipping and the customer-service that I've received from them.
While I'm no stranger to international purchases, the idea of incurring brokerage fees and the idea of international shipping does turn me off of the AL somewhat..... And I, for one, think that aside from the issue of the "full power" jam mode (which has the possibility of incurring true jam-codes, as it is a "brute force" method), the two products are truly comparable in terms of software/firmware.
Overall, I'd say that from the various hobbyist/independent testing, including various videos, it seems that either the AL or LPP would produce similar jamming results.
However, if you're truly worried about that extra ounce of performance (i.e. if you do practice JTG), it will certainly be worth it for you to await the GOL testing.
The wildcard is now Laser Interceptor.
Hope this helps, bruddah! :)
^ I will very soon.
I've promised it to the fellow RD.net NZ-LGT owner.
The weather is still nasty enough that washing the car is a no-win situation ( I just washed her last Friday, and now, she's filthy :( ) - so you'll have to excuse that, but you'll get a good view of what I did for the install both of my previous setup (one head out front, a temporary setup - and one out rear, which I'm keeping), as well as the current revision.
My rear install isn't pretty, though -- it's more "industrial" in appearance as I didn't want to tap through the tail-light housings nor body panel. :redface:
PS: Watch-out for my ninja-edits in the previous post above. :)
Install is done (mostly, still need to tidy-up on details) - need a bit of time on the pictures http://www.radardetector.net/images/smiles/icon_redface.gif
I'm very time-constrained in my work on the car - ever since the baby arrived, well, you can guess. http://www.radardetector.net/images/smiles/icon_lol.gif
I should have pix up tonight. There's unfortunately almost no "work in progress" pictures as I had a slight battery-charge issue with my digicam, and I couldn't wait to go ahead on the install because of the above-mentioned time-constraint issue. http://www.radardetector.net/images/smiles/icon_sad.gif For this, brother, I *deeply* apologize. However, I was able to snap a couple of pictures of my original single-front install for you so as to give you an idea of how it goes.
Also rather unfortunately, I could not get enough space to fit the x50/ZR3 mute control inside the ashtray cubby. As such, it's now wired "out" and placed over by the HVAC control knob on my (driver's) side, where I used to have my x50's SmartCord hardwire.
While I do prefer this location due to my natural proprioception (i.e. it's right next to my knee - thus enabling easy night-time find of the button), I do regret not being able to visually hide all controls.
To make-up for this, and also to help address the proprioception problem (or lack thereof, as those controls are too far away from my knee), I placed an LED "pilot light" adjacent to the LPP controls to allow for easier night/dark reference.
Subbed :munch:
So, let me get this straight - you are using the LPP (a parking assist device) as a countermeasure? Interesting... any reason why you chose the LPP over a different device (higher output power, etc?)
On a side note - I wonder if I should consider setting up another group buy here for the Blinder...
Hi schwinn and everyone. :)
First, for schwinn.
That's a very valid question - the name "Laser ProPark," as well as what that item is billed as ("parking assist/distance sensor") is truly only a cover.
Yes, it does work as-advertised (although one does have to be careful when using it as-such, since the emitted laser beam is very directional and can cause you to miss offset obstacles rather easily) as a parking distance warning device, but its main function is as a true active LIDAR countermeasure/jammer.
Currently on-market, the LPP, along with a similar product from AntiLaser (it was the forerunner of the LPP, but does without the parking assist function) are considered "top dogs" in the active jammer segment.
I chose the LPP because of shipping/import/Customs considerations that need to be taken into account with AntiLaser.
While the latter can be said to offer superior protection, in some sense of the word and depending on how one chooses to dissect testing data (i.e. the LPP had certain performance "holes," for which I'm very glad that I'm still using my ZR3, as paradoxically, this otherwise "defunct" system offers EXCELLENT protection of those "holes" - oh, and BTW, the newest round of GOL testing data was JUST released!), for me, personally, the shipping issues were a concern, and it was why I chose the LPP, which has a Stateside/NA distributor.
And to follow-up on your aside, don't worry, you didn't make a mistake going with the Blinders. They're good units with good performance, and you have the assurance of excellent C/S through Blinder. As long as you are well-matched in terms of either enforcement hardware and/or techniques, I am actually of the school-of-thought that says that neither the Escort ZR3 nor the Blinder are "bad" units at all, particularly considering their known-quantity C/S as well as price-points. :)
All -
My LPP installation:
http://www.laserproparkusa.com/forum/viewtopic.php?t=20&start=75 - the 6th page of that thread, 5th post from-top.
Thanks for the answer, TSi... so does the LPP need to be turned on all the time, or does it sense the presence of IR and activate accordingly?
I see from the GOL site that the Blinder and LPP are pretty comparable - so that's reassuring for me :) Of course, that Laser Interceptor looks impressive... might have to read up on that a bit!
^ Definitely, the Blinder isn't bad as long as you have enough coverage (distance-from-head -to- hardpoints) and as long as (as with everything else) it's hardware-matched. :)
And in so far as product support, honestly, it's the only one that I can just brainlessly say "don't worry about it."
With the LPP, it's "on all the time" - however, the parking sensor function can be turned down in sensitivity (i.e. shorten its range) so far that it essentially is useless as a parking distance detector, which would mean that it rarely, if at all, activates (the parking distance warning) in-traffic. Of course, even with such a setting, the jammer is still fully active and functional.
My daily-driving is all in-city, bumper-to-bumper type stuff at traffic lights. I rarely have to mute mine.
The AntiLaser also offers a full parking defeat/mute (there's a bit of debate as to whether or not it truly defeats this function, or if it just disables the alert) in addition to the usual triple-distance setting, which the LPP shares.
The LI does look very impressive, but I think that currently, all that can be said about it is that it's a pre-production unit. We'll need to wait until there's a full-production retail test before we can say anything further, especially as this has, unfortunately, been true of past jammer performances. :)
Definitely keep your eyes open and on that one, but don't jump too soon!
  • 1 month later...
Hey guys, sorry to keep tagging-on to this thread, but I figured that it was better than starting all-new, especially since all "interested parties" seem to have subscribed-to and continue to read this thread.
Just wanted to let everyone here know that I'm now confident in the after-purchase follow-up of Laser Pro Park's North-American (specifically, KMPH-Canada/Alex Hsiao), as I have *not* had direct experience with their US-based distributor; note that KMPH-CA does have a Stateside presence, and that my packages came from a Stateside shipping address origin) distributors.
After Canadian and Australian LPP owners voiced concerns of their respective 100 pulse-per-second UltraLyte issues (inconsistent and early punch-throughs), KMPH-UK stepped up and offered revised firmware that addresses this issue in a relatively reasonable time-frame. From there, KMPH-CA offered its customers, even in the States, who requested this upgrade a *free* firmware update.
I just received my updated-firmware boxes a few days ago, and re-installed (this simply requires clipping off the power/negative leads, and re-wiring - for me, and note that I have two control boxes [one front, one rear], this was a 10-minute job).
I am now fully confident that should anything go wrong with my LPPs, KMPH-CA will stand behind the product as much as KMPH-UK. :)
As for the 100 PPS UL fix, by all enthusiast reports, it seems to work very well.
Although the 100 PPS UL should *not* be in-use Stateside (and that I'm well-protected on this via my ZR3), it is good to know that my LPPs now do not carry this "weakness."
To update everyone here regarding the Laser Interceptor.
It seems like this unit should become available within the next month or two.
RadarDetector.com , previously owned by the famed "Radar Roy," has now been sold to another party. There's hotly contested back-door rumors as to why this happened, but due to the relationship of the enthusiast-Forum RadarDetectors.net to the .com site, I do *not* anticipate that there would be any trouble with purchases/services from the new commercial body.
Also, as a part of this transition, the US-based distributor of the Laser Interceptor has finally come on-line at RD.net to answer questions and semi-officially address some concerns.
Of course, we still do not know if the production-retail units, once they're truly introduced here in the States, will match-up to their outstanding performance seen at the latest GOL testing.
One item that has popped-up, to the chagrin and anger of many in the community, is that the LI will NOT be offered at its previously-anticipated low, low pricing. :( The newest cost projection for retail, Stateside, is around $600.
This still comes in at $200 to $300 lower than a comparable dual-head AntiLaser or Laser Pro Park, but this price-hike was the point of some bitter, bitter words between enthusiasts who felt like they had been "promised" a lower price-point by the developer of the LI, who had cited, at the time of the GOL testing, that it would come in at the unheard-of price point of $400 for a dual-head setup.
With regard to the AntiLaser G8, the latest product update was a quad-head enabled control-box. However, it does seem from various reports that there is some kind of quality-control issue that's *still* problematic, causing at least a fraction of the units to essentially "self destruct" after about 6-months in-service.
So far, it seems like the LPP, which is, by all counts, a "copy" of the AntiLaser, is enjoying a much more solid build and reliability record - and that this "time bomb" concern is currently not an issue with these UK-build products.
It is unknown, however, if the LPPs will or will not eventually show the defect that is causing the AntiLasers to self-degrade. It is also currently unknown as to exactly what is causing the AntiLaser units to behave the way that they do.
Finally, updating everyone on the Escort 9500i detector....
It does seem that this unit still has some issues with its GPS-enabled TrueLock feature. Various hobbyists and enthusiasts are still trying to figure out exactly why it's not quite functioning as-advertised.
To my fellow LGT brothers and sisters, I'd still advise anyone interested in the 9500i for its GPS-enabled features to wait-out.
Myself? I'm still tempted to get it for just the speed-enabled false-reduction features, but I'm not convinced that an item which is known to contain some bugs isn't also going to be unreliably buggy in another area. ;)
Allen - just to give you a head's up - that thing we talked about before....it's a go. I'll be posting more about LPP later, but, suffice it to say...there's a US presence now ;)
  • 2 months later...
Hey All -
Again, sorry to keep tagging-on to this thread, but as I mentioned before, I figured that it was better than starting anew, especially since all "interested parties" seem to have subscribed-to and continue to hit this thread.
Updating developments regarding the Laser Interceptor ("LI").
The RD.net Forum was just informed this past week, by Radar Roy, that apparently, the principal(s) behind the LI still has/have not been able to generate the legal notifications that was initially agreed-upon by Roy and themselves as being needed to justify opening the discussion sub-Forum for them, based on legal concerns voiced by Roy at the outset (and for which Roy has limited discussion on both the LPP and AL).
Last info. on the anticipated release-date for the LIs, according to Elvis, the stateside rep of LI, was to be mid-August.
No clue now as to when this may be.
I have not been successful in finding another on-line Forum/d-board with which to openly discuss the LI.
Some members of the community, including members of the GOL who initially were so vocal in their support of the LI and so hopeful that their prodution-retail pieces will test as well as the prototype seen during their testing, have now openly expressed sentiment that they fear the LI - in terms of a US release - may be vaporware. To be quite frank, this is my fear as well.
However, we were all reminded by a fellow enthusiast who cited that this kind of issue also surrounded the initial release of the AL and LPP, and that although, technically, neither product is "legal" for sale in the US (due to supposed/contested patent infringements), both are nevertheless easily available.
While some members of the community have gone to such lengths as to try to locate fellow enthusiasts, outside of North America, to purchase the LI direct from its European distributor, from what I know, they have not been successful in such attempts. Neither have members who truly live in other countries been successful in obtaining this, the latest version, of the LI.
