heybige Posted July 18, 2006 Share Posted July 18, 2006 Did some searching and came across a few numbers: 2 to -2.5 up front and -1 to -1.5 in the rear with 0 toe all around Can this apply to a lowered LGT (Pinks)? From what I understand, these numbers are geared more towards performance. I'm mainly looking for a good, comfortable daily driving set-up and good tire wear. Would the Factory/Dealership specs be ok? : Thanks in advance! Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted July 18, 2006 Share Posted July 18, 2006 I would recommend at least a little bit of negative camber, as it will help your handling tremendously. -2.5 up front is probably a bit extreme for a daily driver, I would try -1.5 up front with 0 toe all around. Rear camber is not adjustable. -Dan Link to comment Share on other sites More sharing options...
ebpda9 Posted July 18, 2006 Share Posted July 18, 2006 try to keep it to factory specs for the toe and caster, but the camber keep it around .75-1 degrees Link to comment Share on other sites More sharing options...
itsme Posted July 20, 2006 Share Posted July 20, 2006 I'm going to get rear adjustable control are so I can set the camber I get my h-tech springs. So what is the camber setting for front and rear and will I need to get camber plates for the front? Thanks Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
rporter Posted July 28, 2006 Share Posted July 28, 2006 I'm getting some Tire Rack tires installed on Monday, along with an alignment. Is -1.5 front camber doable with the stock suspension setup, meaning that I wouldn't need camber plates? Ron Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 28, 2006 Share Posted July 28, 2006 If the rear is about 1 inch lowered you will end up with about -1.0 degree of camber. At least that is what it ended up for me, so you may not have to get the adj arms. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
j255c Posted July 28, 2006 Share Posted July 28, 2006 yeah im riding on a non aligned suspension right now cuz im waiting for my springs to settle in. We eyeballed the fronts to make sure the camber was negative, but i think its REALLY negative right now and the car is handling just so so well. But i checked my tires, they are going so so fast 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
turbofied Posted July 30, 2006 Share Posted July 30, 2006 Can anyone tell me if i need caster/camber plates if i lower my GT. I never see them on any of the websites for sale, so it makes me worried. I am getting the H. Techs in soon and need to know if should look into getting some. Any info would be great thanks. Link to comment Share on other sites More sharing options...
ebpda9 Posted July 30, 2006 Share Posted July 30, 2006 i would not worry too much about caster, since a drop on the legacy doesn't seem to change it at all. on the other hand you could go with offset bolts to adjust the front camber. if you leave it to about -.75 degrrees the car will handle great with a minimal tire wear. Link to comment Share on other sites More sharing options...
shralp Posted July 30, 2006 Share Posted July 30, 2006 Sorry if this is a bit of a hijack guys, but this questions seems pretty related. I'm installing some Whiteline Control Springs, (30mm lower), soon on my GT wagon. How long should I let the springs settle before I go to get re-aligned? Is settle time even necessary? Thanks. Link to comment Share on other sites More sharing options...
Th3Franz Posted July 31, 2006 Share Posted July 31, 2006 I installed JDM GT Bilsteins with pinks on my car and got it aligned.. with the stock struts I had -1.1 camber (maxed out) and after the JDM suspension settled I went to a different shop and they could only get -3/8 degrees of camber.. were they being lazy or something? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
turbofied Posted July 31, 2006 Share Posted July 31, 2006 Hey thanks for the info...will the alignment shop have those offset bolts or do i have to buy them somewhere? Link to comment Share on other sites More sharing options...
ebpda9 Posted July 31, 2006 Share Posted July 31, 2006 most likely not. you would need to purchase them, or you could call in before and make sure Link to comment Share on other sites More sharing options...
