CasopoliS Posted May 7, 2006 Share Posted May 7, 2006 I just need to fiberglass the wood to the mold and smooth everything out. I will carpet the box, which will eventually mold to that entire side of the trunk. The sub is recessed so the floor can still raise up without hitting anything. I took pictures of every step and documented it. A full write-up will come once I am done with everything. Still a lot of work left. Oh.... here are the specs Xtant 3.1 amp - 300W RMS @ 2ohm Alpine type-R 10" sub - 300W RMS @ 2ohm Link to comment Share on other sites More sharing options...
CasopoliS Posted May 7, 2006 Author Share Posted May 7, 2006 Oh yea and the circle cut around the sub is crappy because I had to sand and sand then hit it again with the jigsaw then sand a little more. I got lazy and it looks bad. I will make a trim ring that hides this. This is my first time fiberglassing... it was not that bad, just painfull as I sat in the spare tire well and inhaled fumes. Link to comment Share on other sites More sharing options...
16psibrick Posted May 7, 2006 Share Posted May 7, 2006 looks great similar to a g35 i just did a while ago http://simplicity.elitecaraudio.org/tonyg21.jpg Link to comment Share on other sites More sharing options...
CasopoliS Posted May 8, 2006 Author Share Posted May 8, 2006 that looks cool.... that is a lot of space in the G35. I hope to do more work tomorrow night, have to go pick up some fabric for the remainding fiberglassing Link to comment Share on other sites More sharing options...
wcbjr Posted May 8, 2006 Share Posted May 8, 2006 Looks like a good start. Get a good mask, smelling those fumes WILL make you high in a non-ventilated space. Oh, and I hope you're not a golfer. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
CasopoliS Posted May 8, 2006 Author Share Posted May 8, 2006 I am not a golfer. Yea I got enough fresh air because I had to exit the trunk ever 4 oz. of resin!!! I only mixed 4oz at a time, so it took a while. Since you only have 12 minutes to work with once you add the hardner, 4oz is all I could handle. Link to comment Share on other sites More sharing options...
CasopoliS Posted November 2, 2006 Author Share Posted November 2, 2006 holy CRAP I need to get this done. It has been sitting in my garage for a loooong time now. There are like 3 screws stuck to my magnet... the sub is just sitting there (probably not good for it). When I did a test hook up, the bass was unreal. Could not hit low pitched tones (I think low frequency is the better term) though because the box had a hole in the side (I was not done yet). I used fabric to smoothly connect the two pieces (wood and fiberglass), but the resin did not want to dry on that fabric... didnt soak in well. It was like a spandex type fabric. But, once I layerd it on and on I finally got a rigid surface to build off of. The fiberglass job sucks, but once I sand a bit it will be masked by the carpet. Link to comment Share on other sites More sharing options...
BLACKonBLACK Limited Posted November 2, 2006 Share Posted November 2, 2006 lol, i made a complete mold of the same spot, 3 layers of fiberglass etc... got the MDF ready to go just need to buy my sub... Link to comment Share on other sites More sharing options...
Boulderguy Posted November 3, 2006 Share Posted November 3, 2006 Do you know about glassing the joints from the inside? If it didn't soak in well you should really do that. Oh and definitely drop the $25 for a ventilator mask - those fumes can seriously screw with your brain! I'm still dumb from it a year ago! Link to comment Share on other sites More sharing options...
wukindada Posted November 3, 2006 Share Posted November 3, 2006 I'd like to see that setup in the wagon Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
PGT Posted November 3, 2006 Share Posted November 3, 2006 Do you know about glassing the joints from the inside? If it didn't soak in well you should really do that. Oh and definitely drop the $25 for a ventilator mask - those fumes can seriously screw with your brain! I'm still dumb from it a year ago! a local Suby guy has some seizure issues from not using a ventilator. Seems there are two types of resin and one's a 'no no'. As for the install, plywood? Why not MDF? Much easier to work with and more dense. Also.....too late now, but a circle cutter is great for making short work of that cut. Link to comment Share on other sites More sharing options...
CasopoliS Posted November 3, 2006 Author Share Posted November 3, 2006 a local Suby guy has some seizure issues from not using a ventilator. Seems there are two types of resin and one's a 'no no'. As for the install, plywood? Why not MDF? Much easier to work with and more dense. Also.....too late now, but a circle cutter is great for making short work of that cut. yea there are some things I wish I did differently. circle cutter, mdf, etc. I had a bunch of old wood from my bar - so I deicded to use it. Seems pretty solid. I fiberglassed the two pieces together quite well, and used foam insulation on the inside edges. Link to comment Share on other sites More sharing options...
legz Posted November 3, 2006 Share Posted November 3, 2006 Link to comment Share on other sites More sharing options...
CasopoliS Posted November 3, 2006 Author Share Posted November 3, 2006 I have actually been looking but I cannot find the most recent. I thought for sure I took some. Link to comment Share on other sites More sharing options...
CasopoliS Posted November 3, 2006 Author Share Posted November 3, 2006 Ok here are pics I found of the supplies - I kept them large so you can read labels The fumes got to me.... http://img518.imageshack.us/img518/407/dscn1597mediumcr0.jpg Link to comment Share on other sites More sharing options...
PGT Posted November 3, 2006 Share Posted November 3, 2006 Warsteiner? My man! Link to comment Share on other sites More sharing options...
CasopoliS Posted November 3, 2006 Author Share Posted November 3, 2006 yup .... good stuff Link to comment Share on other sites More sharing options...
NickB34 Posted November 3, 2006 Share Posted November 3, 2006 LOL.... I did anywhere from 8-16 oz. of resin at a time, so much faster Link to comment Share on other sites More sharing options...
PGT Posted November 3, 2006 Share Posted November 3, 2006 yeah.....don't be afraid to use the hardener in ALOT higher quanities than recommended. Link to comment Share on other sites More sharing options...
ldc2335 Posted November 6, 2006 Share Posted November 6, 2006 keep us updated!!! Link to comment Share on other sites More sharing options...
ldc2335 Posted November 7, 2006 Share Posted November 7, 2006 HOW MANY CANS OF RESIN AND HOW MANY PIECES OF CLOTH?? AT $10 A CAN I DONT WANNA BUY MORE THAN I HAVE TO ALSO THEY HAVE RESIN THATS A GEL.....WOULD THAT BE EASIER??? Link to comment Share on other sites More sharing options...
PGT Posted November 7, 2006 Share Posted November 7, 2006 no need to yell. save your receipt - you can return unopened merchandise to most hardware places. Link to comment Share on other sites More sharing options...
ldc2335 Posted November 7, 2006 Share Posted November 7, 2006 Sorry have a habit of using caps..how about an estimate? 1 or 2 Link to comment Share on other sites More sharing options...
Boulderguy Posted November 7, 2006 Share Posted November 7, 2006 Depending on the thickness I'd guess 1/2 - 2/3 of a gallon of resin. Link to comment Share on other sites More sharing options...
CasopoliS Posted November 7, 2006 Author Share Posted November 7, 2006 I would buy a gallon and just save what you have left. It would have been almost the same amount of money for me... and I could have used the stuff. Link to comment Share on other sites More sharing options...
