LegacyLexTek Posted March 27, 2006 Share Posted March 27, 2006 if anyone can get headlight assemblies out of a wrecked lexus 2004-2005 RX330, you can disassemble the headlight and take out the light assembly and it will bolt directly onto the projector housing on the legacy headlight. plus the lexus ecu is tiny and easy to hide. plus you dont have to do to much modification to the legacy headlight. kicks ass. i just checked ebay there are a lot of RX330 headlights for sale. all you need is the ECU and the light, the wiring can be done by a monkey. any questions let me know Link to comment Share on other sites More sharing options...
laz Posted March 27, 2006 Share Posted March 27, 2006 Yes, that is why these lights get stolen out of these cars more than any other cars. I can't believe the amount of RX330's that I have seen with the headlights missing overnight. X --- Link to comment Share on other sites More sharing options...
LegacyLexTek Posted March 27, 2006 Author Share Posted March 27, 2006 Yes, that is why these lights get stolen out of these cars more than any other cars. I can't believe the amount of RX330's that I have seen with the headlights missing overnight. X yeah tell me about it, i work at a lexus dealership as a tech, we are now installing an anti theft bracket on the RX's Link to comment Share on other sites More sharing options...
gt_ltd Posted March 27, 2006 Share Posted March 27, 2006 you can disassemble the headlight and take out the light assembly and it will bolt directly onto the projector housing on the legacy headlight. how about a walk thru? This Space For Rent Link to comment Share on other sites More sharing options...
Nsaglibene Posted March 27, 2006 Share Posted March 27, 2006 Hah my mom has an rx330 its getting the anti theft device right now... too bad I should have stolen them while it was easy. Link to comment Share on other sites More sharing options...
Th3Franz Posted March 27, 2006 Share Posted March 27, 2006 The "ECU"? Do you mean ballast? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
rony Posted March 27, 2006 Share Posted March 27, 2006 Any guess on the percentage of these on ebay that are stolen? 99.9999%? My Car vBGarage Link to comment Share on other sites More sharing options...
scans007 Posted March 27, 2006 Share Posted March 27, 2006 ^As the ebay CEO says......that's not their responsiblity. People suck.... Def interested but def need more info. And I can only assume by ECU he means ballast.... Link to comment Share on other sites More sharing options...
VXCL Posted March 27, 2006 Share Posted March 27, 2006 i've heard this is true, but good to see it confirmed. i would suggest perhaps just getting the projectors and then using a hella gen iv d2s system like i used in my retro for easy wiring and much smaller size. post more pics in the exterior section. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
godwhomismike Posted March 27, 2006 Share Posted March 27, 2006 Walkthough Link to comment Share on other sites More sharing options...
scans007 Posted March 27, 2006 Share Posted March 27, 2006 post more pics in the exterior section. Better Link to comment Share on other sites More sharing options...
LegacyLexTek Posted March 27, 2006 Author Share Posted March 27, 2006 how about a walk thru? basically you take the rx headlight remove the bottom cover 4 screws, remove the HID ecu, 2 screws. disconnect the wires and the bulb. then looking the back of the headlight, the silver cone that the headlight is attached to, is held down with 3 screws, remove the silver cone. and youre done with RX headlight. remove headlight from sooby. i did it the hard way, by not completely disassembling the headlight, which ever is easier for you do it that way. i installed the silver cone off the lexus without taking the headlight apart. i had to grind down the silver cone around the edges to get it into place. then the hard part was lining up the 3 holes on the silver cone with the holes on the projector housing. if you take the headlight apart by heating the glue and completely tearing it down its alittle easier i tryied both ways because i removed the oragne marker lens. basically the silver cone that holds the HID bulb from the Lexus will screw directly into the projector housing in the subaru headlight. its almost too easy. i can explain every step but if you just get the parts and look at it, its almost like it was made to be in there. the 2 wires that come off the RX HID ecu are pink and black, the 2 wires that come off the Subaru headlight bulb are pink and black. the back cover even screws back on its that good of a fit. i know i should have taken more pictures, but i was too busy getting it done. and i know i suck at explaining things because i am a tech and just do things with the instructions in my mind. Link to comment Share on other sites More sharing options...
LegacyLexTek Posted March 27, 2006 Author Share Posted March 27, 2006 yes the ecu means ballast, the good part about the lexus ballast or ecu as i call it is that it is really more on an ecu, relays are built in and its basically a better part. Link to comment Share on other sites More sharing options...
LegacyLexTek Posted March 27, 2006 Author Share Posted March 27, 2006 i will try to get more pictures up, soon, i just have to deal with the fact that i get in rear ended 5 hours after i did the damn install so taking pictures of the lights was the least on my worries Link to comment Share on other sites More sharing options...
AWDxBOOST Posted March 27, 2006 Share Posted March 27, 2006 hmmm... my friends get a ton of hid's from the lexus dealer he works at from totaled cars... Link to comment Share on other sites More sharing options...
gt_ltd Posted March 27, 2006 Share Posted March 27, 2006 waiting for night pics.. This Space For Rent Link to comment Share on other sites More sharing options...
gt_ltd Posted March 27, 2006 Share Posted March 27, 2006 hmmm... my friends get a ton of hid's from the lexus dealer he works at from totaled cars... could u get me a set? This Space For Rent Link to comment Share on other sites More sharing options...
BDII Posted March 27, 2006 Share Posted March 27, 2006 Im a panty waist Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
c-lo Posted March 27, 2006 Share Posted March 27, 2006 Hah my mom has an rx330 its getting the anti theft device right now... too bad I should have stolen them while it was easy. it's your mom, just switch them out, she'll never know:icon_bigg 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
lookslikeanevo Posted March 27, 2006 Share Posted March 27, 2006 post wall shots!!! and output pics!!! Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
TYNY Posted March 27, 2006 Share Posted March 27, 2006 i'd love to see more pics, cut-off lines and all. sucks that you got rear-ended, hope you're ok. Link to comment Share on other sites More sharing options...
mr_luv Posted March 28, 2006 Share Posted March 28, 2006 so are these directional or the normal projectors, there are 2 types of projectors, for the rx330 directional and non. Mr.350 Link to comment Share on other sites More sharing options...
TSiWRX Posted March 28, 2006 Share Posted March 28, 2006 Wait....this is just a bulb/ballast/ignitor retrofit, correct? not a full-optics retrofit? <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
mr_luv Posted March 28, 2006 Share Posted March 28, 2006 I think its a full retro, though our OEM cutoff sheild and lens are far better and are not frosted like the lexus, so we would just use some of our oem componets but the projector and bowls are true oem hid and we would use the ballest/ing/bulbs, add a washer or 2 for and bend the shield a little for a sharper cut off and more color at the cut off line. Wait....this is just a bulb/ballast/ignitor retrofit, correct? not a full-optics retrofit? Mr.350 Link to comment Share on other sites More sharing options...
LegacyLexTek Posted March 28, 2006 Author Share Posted March 28, 2006 i will post more pics when my car gets back from the body shop Link to comment Share on other sites More sharing options...
