2.5i rules for stereos!!
Anyone have a sources for this Metra kit or a part no? There site is one of the worst on the web so I can't find this thing!
EDIT: I found a p/n 99-8901 in a press release. Does this match?
Edit 2: http://www.installer.com/kits/ guess I should have searched
You can get it from Crutchfield too, much cheaper than Installer.com. I've got one on the way 19.99 +shipping. part number is slightly different, they had 12... in front of the metra number. Just add a head unit to your cart taht they offer the kit for free with and then write down the part number and put it into their part # search box.
Tolly
07 Impreza 2.5i Special Edition
07 Kawasaki Ninja 250
Yes, they shipped to Canada without any issues. Shipment actually got split - I figure they drop ship. I specified USPS - that's key. I don't recall how much shipping and duty was - but it was very reasonable and well worth it. I think it was only taxes and the freight, no duty IIRC.
Some of the biggest savings were on the cables - I'm running two amps so three pairs of RCAs - they've got great deals on RCA patch cords. Cruise through the site and total up what you need and compare it to what you would pay locally... I think you'll find yourself ahead going through them, particularly with the dollar being good right now.
  • 2 weeks later...
So I installed this Metra kit yesterday with a new HU. Overall it's a pretty good product. I have some fitment issues though. The silve side pieces don't seem to fit up correctly anymore. I have a large gap on the drivers side where it meets the panel below the steering column. As well I hear a lot of plastic rubbing when I go over bumps. Anyone else have issues like this?
I didn't have those issues... It was a little tight, but nothing a little elbow grease couldn't fix. Keep in mind it's manufactured plastic, every kit may not be exactly the same...
I did have one issue, the hu is a little loose, and as I drove more and more, it started to creep out on the bottom. I can push on the bottom of the hu, and the fit gets better...I think there's a bracket in the back I'm missing...
If it still has gaps, it's not put back together correctly. It will fit exactly how it was prior to the new front panel. Just take it back apart carefully and make sure all the different tabs/slots/clips are lined up correctly - you should have no issues with plastic rubbing noises and the like...
  • 3 weeks later...
I took everything apart and re-fit it all. Turns out teh brackets that sit far in the back middle were cocked. Unfortunatly I have a new issue though! The shifter trim has a pretty large gap to the stereo bezel. Seems the gummy clip stuff has really worn out. I'm thinking it might affect the fit or something. The shifter trim has been removed quite a few times so I think I screwed myself here! In any case things are still looking and sounding good:
http://pages.videotron.ca/chaseme/shift.jpg
Here is my install. I took the stock stuff out of the MSP b4 I traded it in lol. The kit is a good color match but like posted above the texture is different. Trying to see if getting it cleared with automotive clear coat will help it
http://amykdean.com/albums/Legacy-Pics-06/Suby_Interior_2.sized.jpg
http://amykdean.com/albums/Legacy-Pics-06/Sub_1.sized.jpg
The channels on the sides of the car are definantly an awesome place to run wires, the install took only a couple hours for everything and it looks very professional.
Amy
04 FXT vf39 5mt
