inthedeck Posted August 26, 2004 Share Posted August 26, 2004 Does anyone know what the specific torque specs are for the 17" LGT rims? I know the WRX's were 80 ft-lbs...just curious if the Legacy will follow the same specs? Thanks, i Link to comment Share on other sites More sharing options...
Drift Monkey Posted August 26, 2004 Share Posted August 26, 2004 I thought the WRX lugnut torque specs were 70ft-lbs? Link to comment Share on other sites More sharing options...
CombatCQB Posted August 26, 2004 Share Posted August 26, 2004 I believe anything between 80-100ft-lb is safe. Link to comment Share on other sites More sharing options...
rao Posted August 26, 2004 Share Posted August 26, 2004 It is in the manual. Look in the "changing a tire" section....... Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Opie Posted August 26, 2004 Share Posted August 26, 2004 [quote name='CombatCQB']I believe anything between 80-100ft-lb is safe.[/quote] From the service manual, 81.1 ft/lbs :) Link to comment Share on other sites More sharing options...
inthedeck Posted August 26, 2004 Author Share Posted August 26, 2004 Thanks all. I know, I know...I should have read the manual. Free time isn't one of the things that I have much of, as I have too many other reponsibilities to take care of, so maybe I will look into reading it cover to cover during this weekend. later, i. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 26, 2004 Share Posted August 26, 2004 Does anyone actually use a torque wrench to tighten their lug nuts? I just make sure my nuts are as tight as I can get them by hand. Link to comment Share on other sites More sharing options...
rao Posted August 26, 2004 Share Posted August 26, 2004 I do. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
inthedeck Posted August 26, 2004 Author Share Posted August 26, 2004 I do, which is why I asked. Link to comment Share on other sites More sharing options...
gtguy Posted August 26, 2004 Share Posted August 26, 2004 I always use a torque wrench...for everything that I fiddle with on the car. Too much torque is as bad as too little. Kevin Link to comment Share on other sites More sharing options...
CombatCQB Posted August 26, 2004 Share Posted August 26, 2004 Same here. Link to comment Share on other sites More sharing options...
Xenonk Posted August 27, 2004 Share Posted August 27, 2004 over-torque can be bad as well.. I torque my lugs to 95 lbs. 80 lbs is ok, but I opt to go a little bit more.. 120 lbs is too much stress on the stud. I read on the back of some McGard guidelines of torque specs (which are based on bolt pattern, stud sizing and threading specs). Keefe Keefe Link to comment Share on other sites More sharing options...
Drift Monkey Posted August 27, 2004 Share Posted August 27, 2004 [quote name='jedimaster']Does anyone actually use a torque wrench to tighten their lug nuts? I just make sure my nuts are as tight as I can get them by hand.[/quote] :o Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 30, 2004 Share Posted August 30, 2004 I was playing with my nuts this weekend and found that the dealer had them put on with an air wrench. I had to use my body weight to get my nuts off. Maybe a torque wrench would keep me from being too rough on my nuts. Link to comment Share on other sites More sharing options...
gtguy Posted August 30, 2004 Share Posted August 30, 2004 [quote name='jedimaster']I was playing with my nuts this weekend and found that the dealer had them put on with an air wrench. I had to use my body weight to get my nuts off. Maybe a torque wrench would keep me from being too rough on my nuts.[/quote] The problem with this is that too much torque can warp not only brake discs, but damage wheels, as well. It will also break wheel lock keys. When I am going somewhere that presents the opportunity of gorilla mechanics who just hammer away with the impact, I always check immediately after the car comes down off the lift. If I can't take the nuts off with a T-spinner, I have them retorqued. Getting shops to use hand tools when reinstalling wheels is out of the question, of course... Kevin Link to comment Share on other sites More sharing options...
DAP Posted August 30, 2004 Share Posted August 30, 2004 [quote name='jedimaster']I was playing with my nuts this weekend [/quote] Carefull how you word that... Link to comment Share on other sites More sharing options...
Xenonk Posted August 30, 2004 Share Posted August 30, 2004 [quote name='jedimaster']I was playing with my nuts this weekend...[/quote] sorry, it was just funny to read :P Keefe Keefe Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 31, 2004 Share Posted August 31, 2004 Will you guys stop thinking dirty thoughts about my nuts, please :P Link to comment Share on other sites More sharing options...
red beast Posted September 6, 2004 Share Posted September 6, 2004 wrx i believe 68 - 72 at least that's what i went by and i never saw a tire pass by me. :D Link to comment Share on other sites More sharing options...
inthedeck Posted September 7, 2004 Author Share Posted September 7, 2004 [quote name='red beast']wrx i believe 68 - 72 at least that's what i went by and i never saw a tire pass by me. :D[/quote] it's possible...but the tech guy at the local Suby srvc. dept stated 80 ft-lbs. on the WRX wagon. Maybe it was diff. for the sedan? Oh well, at least the manual in the Legacy has it written. Later, i. Link to comment Share on other sites More sharing options...
Drift Monkey Posted September 7, 2004 Share Posted September 7, 2004 [quote name='jedimaster']Will you guys stop thinking dirty thoughts about my nuts, please :P[/quote] That's kinda hard to do... Link to comment Share on other sites More sharing options...
shakenbake Posted September 19, 2006 Share Posted September 19, 2006 Yeah i have heard from many sources that not torquing the lug nuts will cause the rotors to warp prematurely and i have found this out by experience, unfortunately to be the case on my truck(99GMC sonoma lowrider). the factory specs for the truck is 115ft/lbs Link to comment Share on other sites More sharing options...
craesq Posted October 3, 2006 Share Posted October 3, 2006 I use a torque wrench and tighten to 90ft lbs. Link to comment Share on other sites More sharing options...
Yo Han Posted October 12, 2006 Share Posted October 12, 2006 lol.. that's pretty funny! I needed a good laff. Yeah I defainately torque my lugnuts in star pattern, very few tire shops I've been to do torque. Need a breaker bar to get the LUGnuts off after rotations sometimes.:icon_mad: [quote name='DAP']Carefull how you word that...[/quote] Link to comment Share on other sites More sharing options...
