Lie495s14 Posted April 26, 2007 Share Posted April 26, 2007 Understood. That is why I'm leaning towards getting the coilovers... instead of paying someone to remove the H & R's and re0install OEM. Hopefully someone will be interested in the H & R's since they are already compressed. I hate no clue what you mean by seting preload? Sorry... My last car was an Infiniti. Preload is when coilover setting on the floor, how much you make the spring teighter, determines your preload. Link to comment Share on other sites More sharing options...
subiedude Posted April 26, 2007 Share Posted April 26, 2007 Thanks... (starting to get it). But with 32 levels of dampening (like on the MR coilovers) I guess there is a fine line to get the optimal balance between preload, height, and dampening? Link to comment Share on other sites More sharing options...
Lie495s14 Posted April 27, 2007 Share Posted April 27, 2007 Thanks... (starting to get it). But with 32 levels of dampening (like on the MR coilovers) I guess there is a fine line to get the optimal balance between preload, height, and dampening? I don't know exactly what role does repload play when comes to dampening. But It is a must to have some to elimanate spring free play. So i set the preload 50lb in the front, and 75lb in the rear, which i was told by keefe, he's the master, and i'm very happy with the settings. Here are settings for lb to cm. Front Rear Spring rate (lb/in) or (kg/mm) : (336lb/in)or(6kg/mm) (448lb/in)or(8kg/mm) Preload of (25lb) or (11.3kg) : (1.9mm) (1.4mm) Preload of (50lb) or (22.7kg) : (3.8mm) (2.8mm) Preload of (75lb) or (34 kg ) : (5.7mm) (4.3mm) Preload of (100lb)or (45.4kg) : (7.6mm) (5.7mm) Preload of (125lb)or (56.7kg) : (9.5mm) (7.1mm) Link to comment Share on other sites More sharing options...
subiedude Posted April 28, 2007 Share Posted April 28, 2007 Thanks for explaining. How much did you lower the car? Any issue's other then chance of bottoming out on the L.I.E.? Link to comment Share on other sites More sharing options...
