SLegacy99 Posted March 30, 2006 Author Share Posted March 30, 2006 And you cant really abuse a speedometer. Link to comment Share on other sites More sharing options...
tekkitan Posted March 31, 2006 Share Posted March 31, 2006 And you cant really abuse a speedometer. Yes, but didnt you say some old lady owned it before you? A lot can happen between owners Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 1, 2006 Author Share Posted April 1, 2006 Yes, but didnt you say some old lady owned it before you? A lot can happen between owners Thats correct, for about 20,000 miles. Current Status: Legacy repaired. They knocked about $130 off. THe speedo itself was $150, still dont think I should be the one paying for that. However, the odometer was supposed to be set at the factory and it wasnt so I have started all over again. Still analog though, was hoping it would be a digital. Link to comment Share on other sites More sharing options...
Aczwild Posted April 1, 2006 Share Posted April 1, 2006 Thats correct, for about 20,000 miles. Current Status: Legacy repaired. They knocked about $130 off. THe speedo itself was $150, still dont think I should be the one paying for that. However, the odometer was supposed to be set at the factory and it wasnt so I have started all over again. Still analog though, was hoping it would be a digital.Um thats not good, if you try to sell the car you'll run into milage fraud JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 1, 2006 Author Share Posted April 1, 2006 Well they hide a sticker in your door frame with your mileage. Not that I would do it, but who's to say that someother person wouldnt just heat it up and peel it off? Link to comment Share on other sites More sharing options...
kkushner4474 Posted April 10, 2006 Share Posted April 10, 2006 with my 99 lgt i had blown headgasket, mssfireing 3 and 4 psitions, had to replace upper and lower radiator hoses and blew tire on a pot hole goin 60 around a turn and coll aitr sensor and still waitin on that tire and mean while drivin my 92 legacy which i have replaced the clutch twice and cv joints once...lol did it myself saved me shat load of money Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 10, 2006 Author Share Posted April 10, 2006 Acz you were right. The fogs dont fit. However I think I can do a good enough job to get em in. Just waitin on a new bumper. Link to comment Share on other sites More sharing options...
Aczwild Posted April 10, 2006 Share Posted April 10, 2006 Acz you were right. The fogs dont fit. However I think I can do a good enough job to get em in. Just waitin on a new bumper.Good luck with getting them in there! If you do it'll look pretty pimp on your red JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 11, 2006 Author Share Posted April 11, 2006 Good luck with getting them in there! If you do it'll look pretty pimp on your red They are awesome looking. I just have to cut some bumper. Be easier if the Legacy bumper were fiber glass though. Link to comment Share on other sites More sharing options...
Naproxen Posted April 24, 2006 Share Posted April 24, 2006 I have actually had similar issues. My CEL was on for awhile but without any noticable issues in performance so I stupidly let it slide. Then for awhile I had no speedo or odometer, but still no driving issues, and after about a week or so of intermittent outtages the issue seemed to go away. Started again this weekend, only now my (5 sp 1999 2.5GT) car would die while in neutral and going slow, then it got worse to doing it whenever I was stopped and the clutch would be shaking alot, have to rev the engine to keep from stalling. It's in the garage right now, the ignition coil was breaking down or something which might be the cause of the stalling, I will find out the rest in a day or so regarding the speedo/CEL Link to comment Share on other sites More sharing options...
Naproxen Posted April 25, 2006 Share Posted April 25, 2006 Final verdict: I had my master cylinder for the clutch replaced by the shop I bought the car from a few months ago. According to my new mechanic, in the process of taking everything out they mangled the speedometer connection and did a kindergarden job of "fixing" it. The wires are all green and corroded, put in with tape, etc. The CEL was on due to misfiring, most likely from the ignition coil. Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 25, 2006 Author Share Posted April 25, 2006 Now this is interesting because you have had the same 3 major problems that I had. My master cylinder had to be replaced after my clutch when they should have been done together. Question their work on the speedometer. After spending alot of $$$ I found out that the speedometer unit itself on these Legacies just goes bad. My misfire was because of inocorrect spark plugs. NGKs only. Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 25, 2006 Author Share Posted April 25, 2006 You have motivated me to revise my letter concerning my speedometer. Therefore I must ask anyone who expirienced problems with the speedometer on their '99 Legacy write a letter to SOA and let them know that this is intolerable. Link to comment Share on other sites More sharing options...
Naproxen Posted April 25, 2006 Share Posted April 25, 2006 Now this is interesting because you have had the same 3 major problems that I had. My master cylinder had to be replaced after my clutch when they should have been done together. Question their work on the speedometer. After spending alot of $$$ I found out that the speedometer unit itself on these Legacies just goes bad. My misfire was because of inocorrect spark plugs. NGKs only. When they replaced the cylinder they told me the clutch looked just fine, now im unsure whether to trust that or not. However, with the whole "it's AWD, everything has to come out!" approach for clutch replacements, this will have to be shelved as I'm not experienced enough yet with cars and can't afford the labor charges. I should probably replace the sparkplugs anyways, no idea how to. I hate to say its because im a girl, but ive honestly never had to do this for myself before. Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 25, 2006 Author Share Posted April 25, 2006 Well Ive never done my own spark plugs either. Usually any service center will determine if you need new ones without charging you. You just have to ask. Link to comment Share on other sites More sharing options...
