Selds Posted January 14, 2006 Share Posted January 14, 2006 Hey Hey, Anyone have any experience shimming rear iON spirings to raise the ride height just slightly. I only want to do this for looks I'm not concerened if it changes the ride quality since the iON's ride soooo smoooth already! Is there any other way to raise the rear only slightly? Thanks Link to comment Share on other sites More sharing options...
tintinet Posted January 14, 2006 Share Posted January 14, 2006 According to the released specs, the rear oughta be lowered less than the front, no? Did you not find this to be the case? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted January 14, 2006 Share Posted January 14, 2006 The rear is lowered less then the fronts. With the IONs the car sits level, but does not look level because the rear wheel arches are cut lower then the fronts. I have had my ION springs on for a few months now, very happy with them, even in winter they work very well (just need better dampers now). But, I am going to shim my rear as well. Just does not quite look right to me. I am going to cut the rubber from a tread of a used tire and use this in the top hats of the rear suspension. I suspect I will raise it about 5mm. Just enough to look right. I have spoken with Jack about this, and he agrees it will likely work. He advises not go more then 5 mm though. I will be doing this when I get my new dampers, which I do not have yet, because there are not too many options out there. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
tintinet Posted January 15, 2006 Share Posted January 15, 2006 Thanks. I'm getting Ions, also, for the wagon. I'll be looking into shims as well. Link to comment Share on other sites More sharing options...
Selds Posted January 15, 2006 Author Share Posted January 15, 2006 LittleBlueGt can you post a walkthrough on this when you are done. What kind of tires and what dimensions are you cutting these pieces?In the mean time can you elaborate on your plan? Would be most helpfull. =) -Thx Link to comment Share on other sites More sharing options...
tintinet Posted January 15, 2006 Share Posted January 15, 2006 5 mm- do you think that will make any appreciable difference? Link to comment Share on other sites More sharing options...
sgt Posted January 15, 2006 Share Posted January 15, 2006 I shimmed the rear of my car about .25-.5" Link to comment Share on other sites More sharing options...
racerdave Posted January 15, 2006 Share Posted January 15, 2006 Since iON custom makes each batch, maybe they could make their rear wagon springs a tad taller? Link to comment Share on other sites More sharing options...
tintinet Posted January 15, 2006 Share Posted January 15, 2006 I shimmed the rear of my car about .25-.5" Or 6-12 mm. What did you use to shim? How does it look and function? Thanks! Link to comment Share on other sites More sharing options...
sgt Posted January 16, 2006 Share Posted January 16, 2006 I doubled the rear spring seats. Looks exactly how I wanted it to. No more silly subaru stance(down in back and up in front). When I fill the trunk and have people in the back seat then the suspension looks like it would if i didnt have the extra lift. Link to comment Share on other sites More sharing options...
emosound Posted January 16, 2006 Share Posted January 16, 2006 I doubled the rear spring seats. Looks exactly how I wanted it to. No more silly subaru stance(down in back and up in front). When I fill the trunk and have people in the back seat then the suspension looks like it would if i didnt have the extra lift. The lower spring seat, I presume? I don't have the car nearby to look at, and I don't remember from the install: It comes off the shock? It's available as a separate part from Subaru? Do you know a part #? That would be the perfect solution. I don't like the "droopy butt" look either. -Paul Link to comment Share on other sites More sharing options...
bluechipbmw Posted January 16, 2006 Share Posted January 16, 2006 I doubled the rear spring seats. Looks exactly how I wanted it to. No more silly subaru stance(down in back and up in front). When I fill the trunk and have people in the back seat then the suspension looks like it would if i didnt have the extra lift. Do you have any pics? Link to comment Share on other sites More sharing options...
sgt Posted January 16, 2006 Share Posted January 16, 2006 Its the upper rubber seat. The lower one is obviously welded to the shock and isnt that thick anyway. I dont have a camera so I cant take any pics. If anyone in the DC area wants to take some pics I'd be happy to meet up. But if you want a good example of how my car looks, think C55. All I need now are nicer wheels and a merc decklid spoiler hehe Link to comment Share on other sites More sharing options...
fweasel Posted January 16, 2006 Share Posted January 16, 2006 Its the upper rubber seat. The lower one is obviously welded to the shock and isnt that thick anyway. Do you have the part number? Think I need to order those... ignore him, he'll go away. Link to comment Share on other sites More sharing options...
sgt Posted January 16, 2006 Share Posted January 16, 2006 Should be this: 20375AE000 - Rear Rubber Spring Seat Link to comment Share on other sites More sharing options...
emosound Posted January 16, 2006 Share Posted January 16, 2006 Should be this: 20375AE000 - Rear Rubber Spring Seat Found them at: http://www.subaruparts.com/cart/?pn=20375AE000&submit.x=12&submit.y=2 Only $10 each, but shipping is $9. Not bad, but does anyone have different sources? -Paul Link to comment Share on other sites More sharing options...
bluechipbmw Posted January 16, 2006 Share Posted January 16, 2006 Does this improve or worsen the ride quality? Link to comment Share on other sites More sharing options...
Henkle Posted January 17, 2006 Share Posted January 17, 2006 Thanks for the info, sgt! I would guess that the change in ride quality (if any) isn't noticeable!? My local Subaru dealer told me $17 for the rubber seat (or sheet?). But I needed to special order them, which takes 3, 4 days! (I was going to install the iON springs tomorrow) Anyway, would the rubber seat be more than 5mm high (per Jack's suggestion)? Any higher might cause long-term problems? Link to comment Share on other sites More sharing options...
sgt Posted January 17, 2006 Share Posted January 17, 2006 Ride quality does not change. I cant see it causing any long term problems Link to comment Share on other sites More sharing options...
fweasel Posted January 17, 2006 Share Posted January 17, 2006 Should be this: 20375AE000 - Rear Rubber Spring Seat Thanks! ignore him, he'll go away. Link to comment Share on other sites More sharing options...
fweasel Posted January 17, 2006 Share Posted January 17, 2006 My local Subaru dealer told me $17 for the rubber seat (or sheet?). But I needed to special order them, which takes 3, 4 days! (I was going to install the iON springs tomorrow) Hah, yeah I was planning on an install possibly this weekend. I have a feeling my dealer is going to tell me the same thing. Luckily I have about 5 Subaru dealers within driving distance. Better odds anyway... ignore him, he'll go away. Link to comment Share on other sites More sharing options...
tintinet Posted January 17, 2006 Share Posted January 17, 2006 How thick is each seat? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted January 17, 2006 Share Posted January 17, 2006 No long term problems, as long as the spring is held firmly in place. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Gire Posted January 17, 2006 Share Posted January 17, 2006 This is a really great thread mainly involving a bunch of new members. As a member who had ordered his iON springs several months ago (GB #2?) and haven't put them on yet... I too have worried about the dumped-bum stance on my wagon once I install the springs. This thread (and some possible calls to Jack will help me get the 'PINK'-balanced stance with the iON- quality ride that I want. Link to comment Share on other sites More sharing options...
sgt Posted January 17, 2006 Share Posted January 17, 2006 How thick is each seat? Probably about .5" Link to comment Share on other sites More sharing options...
