smp85 Posted November 14, 2006 Share Posted November 14, 2006 very nice, it will be the first thing i do when i bring my new SE home sometime next month Link to comment Share on other sites More sharing options...
alishelby Posted November 22, 2006 Share Posted November 22, 2006 did this mod today on my 05 auto lgt and it worked fine up until i tried starting my car! car wouldnt start until i replugged the white plug. anybody know why this is happening? Link to comment Share on other sites More sharing options...
forestir Posted November 22, 2006 Share Posted November 22, 2006 did this mod today on my 05 auto lgt and it worked fine up until i tried starting my car! car wouldnt start until i replugged the white plug. anybody know why this is happening? Wrong white plug? Link to comment Share on other sites More sharing options...
alishelby Posted November 22, 2006 Share Posted November 22, 2006 im almost positive it was the right one..it was right next to a black plug. and plus i tested it out. drl's were off and high and low beams worked fine. Link to comment Share on other sites More sharing options...
jaylene2004 Posted November 24, 2006 Share Posted November 24, 2006 Can you diable its DRL in 10 minutes too? it takes 15 min,its really easy .good luck. Link to comment Share on other sites More sharing options...
dr. pepper Posted November 25, 2006 Share Posted November 25, 2006 just did this mod 2 days ago, I LOVE it, the DRL's were fine for awhile, but they just annoyed me, occasionally I would find myself forgetting to turn the headlights on, and plus, the way the LGT looks with the parking lights on is to die for. Took less than 5 mins, one of the easiest mods to do, but probly one of the best appearance wise. Link to comment Share on other sites More sharing options...
undert0e Posted November 28, 2006 Share Posted November 28, 2006 Going to do this tomorrow. thanks for the info. Link to comment Share on other sites More sharing options...
Dr.Chu Posted December 3, 2006 Share Posted December 3, 2006 i gatta say, DRL for the 07 is pain in the ass to disable... South Coast Subaru l Firestone of Rowland Heights l Yimi Sport l Koyorad Link to comment Share on other sites More sharing options...
kidhyla Posted December 9, 2006 Share Posted December 9, 2006 How did you disable them on your 07. I have an 07 and pulled white plug like eveyrone says but lost the high beams. Someone said they think you can cut a brown wire. Does anyone have better details on getting rid of these things for an 07? Thanks Link to comment Share on other sites More sharing options...
laz Posted December 10, 2006 Share Posted December 10, 2006 Thre is another thread somewhere, but basically cut the brown wire and blue with black on same plug. Here is the thread: http://legacygt.com/forums/showthread.php?t=42292 X --- Link to comment Share on other sites More sharing options...
cyclewrks Posted December 18, 2006 Share Posted December 18, 2006 After reading thru several threads, I decided to take a shot on the DRL lights on my new 07 OBXT. I started with removing blue and black wire in the connector and that took care of mine. It disabled the headlamps, parking , and the indicator on the dash. Not sure what the Brown wire does but i don't see a need to remove it . Mike Link to comment Share on other sites More sharing options...
jmfspecb Posted December 19, 2006 Share Posted December 19, 2006 Looks like cyclewrks found another way to skin a cat. It depends what you are looking for - I put a switch in the brown wire so that when the switch is closed, the car works like factory. When the switch is open, the headlights from the DRL are disabled, but the other DRL functions still work (parking lights front and rear). Link to comment Share on other sites More sharing options...
Guinnesspower Posted December 20, 2006 Share Posted December 20, 2006 OK, DRL's are gone ...now, is there a way to run with the parking lights AND the fogs without turning on the headlights:icon_conf :icon_conf Link to comment Share on other sites More sharing options...
schwinn Posted December 28, 2006 Share Posted December 28, 2006 OK, DRL's are gone ...now, is there a way to run with the parking lights AND the fogs without turning on the headlights:icon_conf :icon_confYes - check out the top of the Performance walkthtough forum, or simply click here: http://www.legacygt.com/forums/showthread.php?t=35066 Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted December 29, 2006 Share Posted December 29, 2006 I wish it was easier to run fogs indepently for us "un" electrical technician minded. Link to comment Share on other sites More sharing options...
TRS Posted December 30, 2006 Share Posted December 30, 2006 I wish it was easier to run fogs indepently for us "un" electrical technician minded. To have fogs that can illuminate without any other lights: Follow the instructions here http://www.moojohn.com/subaru/fogmod.html but don't do the step where you tap into the purple wire. Instead, do as stated here http://www.legacygt.com/forums/showpost.php?p=60174&postcount=66. You can use an Add-A-Circuit or Access-A-Fuse to tap the CIGAR fuse that's mentioned. http://ec1.images-amazon.com/images/P/B0009U64H4.01-A385A0XNQBW8HY._AA250_SCLZZZZZZZ_.jpghttp://www.accessafuse.com/images/mini.jpg This will allow you to run fogs only, fogs & parking lights, or fogs & headlights. If swithced on, the fogs will extinguish when you use the high beams and also when you turn the ignition to off. http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/piaa_fog_only.jpg Link to comment Share on other sites More sharing options...
Flying Fossil Posted January 4, 2007 Share Posted January 4, 2007 Well, I dropped the panel under the steering column. twisted my 6 foot 1 inch 225 pound frame around under the dash, fired up the flashlight and saw nothing marked DRL. My poor little 07 Outback LLB is still burdened with those miserable lights. I assume there is no single plug to disconnect as on earlier models. I don't want to permanantly sever the connection just in case I want to sell it someday. Now what? Link to comment Share on other sites More sharing options...
cyclewrks Posted January 4, 2007 Share Posted January 4, 2007 My 07 OBXT wasn't marked DRL either but the relay box is on the firewall on the left side of the footwell, one white plug and one black going in. Pull the white plug trip the release and pull out the blue/black wire and no more DRL's. See my post above. - Cheers Link to comment Share on other sites More sharing options...
DukeTrout Posted January 19, 2007 Share Posted January 19, 2007 After reading thru several threads, I decided to take a shot on the DRL lights on my new 07 OBXT. I started with removing blue and black wire in the connector and that took care of mine. It disabled the headlamps, parking , and the indicator on the dash. Not sure what the Brown wire does but i don't see a need to remove it . Mike That is so key! Don't they know that amber lights on the dash are for warning the driver of a problem condition! Jeez. Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
DukeTrout Posted January 31, 2007 Share Posted January 31, 2007 "trip the release" - could you be more precise? I tried tripping the wire release from the wire side, from the opposite side, but no go. I'm still at it, but could you be more specific? Huge thanks. Nevermind, found a great walkthrough, halfway down on this thread: http://legacygt.com/forums/showthread.php?t=42292&page=2&highlight=2007+DRL My 07 OBXT wasn't marked DRL either but the relay box is on the firewall on the left side of the footwell, one white plug and one black going in. Pull the white plug trip the release and pull out the blue/black wire and no more DRL's. See my post above. - Cheers That bugger is difficult! You have to have the locking mechanism just right and then get the screwdriver inserted just right. Took a long time to get just the right combination to remove it. I'm glad I was patient and didn't snip it, though. Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
Greg Evans Posted February 19, 2007 Share Posted February 19, 2007 I just thought I would say thank you. This was such a huge help. I purchased a pair of Sylvania Silver Star head lights about four months ago. When I got in my car one night about a week and a half ago I realized that I had a head light out. I found this very disheartening given that I had just spent in the neighborhood of $40.00 to purchase these lights. I was very impressed with the performance, and the style of the lights. I had them in my previous vehicle and had absolutely no problems with their longevity. I wrote Sylvania an email regarding my problems. They were happy to replace the lights free of charge. I was in the process of getting the new lights (and driving the car with a headlight out) when the second light went out as well. Needless to say I was furious. This confirmed what I had originally thought. The Daytime Running Lights were burning these lights out very quickly. I went to the owners manual to figure out how to turn the DRL off. With absolutely no success. I didn't know where else to look. So I went to the internet. thats when I found this wonderfully drawn out list of instructions. So the next day I went to the local auto parts store and purchased a new set of lights while I was waiting for my replacements to arrive. I went and installed the lights. The following day I went and unplugged the DRL harness. This was a ten minute operation at most. Thank you legacygt.com. You were a huge help. I will be a reader from now on. Greg Link to comment Share on other sites More sharing options...
Flying Fossil Posted February 20, 2007 Share Posted February 20, 2007 Rats, still no easy solution for 07 owners. Link to comment Share on other sites More sharing options...
frathouse87 Posted March 21, 2007 Share Posted March 21, 2007 Subscribed...Getting HIDS on saturday, need to do this tonight maybe Link to comment Share on other sites More sharing options...
awdG35killer Posted March 23, 2007 Share Posted March 23, 2007 it took my noob arse 5 minutes! and that included running back to my computer to make sure i pulled the right plug but for some reason theres another white lookin plug just hanging out Link to comment Share on other sites More sharing options...
Bigkahuna808 Posted March 25, 2007 Share Posted March 25, 2007 Yeah I had the same situation, but when I pulled the plug the website was down. I freaking sacred, I said a f#$@ and yanked the white one. Lucky my phone finnaly connected with the site, and I was sure. mod time 5 min, time spent worrying if I did it right 2 hours. HID are in now 4300K legal white/ yellow Link to comment Share on other sites More sharing options...
