Arcteryx Posted November 15, 2014 Share Posted November 15, 2014 So, does anyone know what aftermarket coolants are compatible with the Subaru Long Life coolant? I didn't have quite enough premix to fill the system, so I had to add (deionized) water to top it off, so it's now below 50/50, and I'd like to add straight antifreeze to bring it back to the right concentration. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 16, 2014 Share Posted November 16, 2014 add coolant that is the same color as what is currently in the car. Subaru uses green coolant so in a pinch, any green coolant will do. Do not mix coolants IE do not put Blue Honda/Acura coolant into the green stuff Link to comment Share on other sites More sharing options...
theflystyle Posted November 16, 2014 Share Posted November 16, 2014 ^ Subaru uses green and blue coolant The color of this coolant is blue and the first replacement interval is 11 years/220,000Km (137,500 miles). The second replacement interval after that is 6 years/120,000KM (75,000 miles). Subaru Super Coolant may be mixed with Subaru Long Life Coolant (SLLC); however when mixed the replacement interval must be followed for Subaru Long Life Coolant, 30 months/ 48,000Km (30,000 miles). - Cars101.com Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2014 Share Posted November 19, 2014 So, does anyone know what aftermarket coolants are compatible with the Subaru Long Life coolant? I didn't have quite enough premix to fill the system, so I had to add (deionized) water to top it off, so it's now below 50/50, and I'd like to add straight antifreeze to bring it back to the right concentration. Just use any coolant that the bottle say's mixes with, or something like Peak Global, I just used a Peak premix from Ace Hardware, they had a great sale price $5.00 for a gallon. It would mix with any coolant. I used it to top off my system after the new radiator went in last month. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AZP Installs Posted December 25, 2014 Share Posted December 25, 2014 Don't mix the Subaru Super Long Life Coolant (Blue) with Subaru Long Life Coolant (Green) You can put Green in with blue but your interval will go down to 30k. In actuality the best bet is to change it every 30k with the Green coolant regardless if you have the Blue or Green in your car (They switched somewhere in the 08 model year over to the blue coolant) Green = 30K intervals Blue = 100k intervals The good thing about the blue is that it can last until your Timing Belt/Water Pump change at 100K miles when the fluid is drained out anyway. We've had folks want to put the Blue in their older cars to cut down on the interval change but you never can get all the green out when replacing with blue so it's not suggested. DO NOT PUT the COOLANT CONDITIONER in TURBO cars. It is essentially a stop-leak fluid and can become coked up in the coolant lines leading to the turbo due to the excessive heat. -Mike Paisan http://www.pbase.com/paisan/image/153798190.jpg Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
kzr750r1 Posted December 25, 2014 Share Posted December 25, 2014 TO each his own. Trust me I get where your coming from. Having this shoved at us as "conditioner" to fix a design flaw is BS. I'm still probably going to put it in there. Because... It probably saved me from head gasket failure earlier than it did. Funny part is the flush performed just prior to full on HG failure was the nail in the coffin, IMHO. So well see once the motor is back together what I decide. Link to comment Share on other sites More sharing options...
AZP Installs Posted December 25, 2014 Share Posted December 25, 2014 The turbos are not prone to HG failures though so no real need for the HG conditioner in them. They use the metal HGs unlike the NA ones which use the cardboard ones. Mike Link to comment Share on other sites More sharing options...
