LegacyLGT05 Posted April 7 Share Posted April 7 Yo gang always something haha, I took off 1 2 3 and when I got into 4th it started to hiccup and backfired and would go and now it runs like crap miss 2/3 and cam sensors code but swapped them still runs crappy vac is good but can't seem to fix it , maybe timing jumped ? Only thing I haven't checked thx Link to comment Share on other sites More sharing options...
KZJonny Posted April 8 Share Posted April 8 (edited) Was the replacement engine from an auto? Any chance the belt guides at the corners and crank pulley weren't swapped over from the dead engine? Shift shock can definitely cause the belt to skip a tooth or a few. Hopefully not enough to cause a valve touch. That would explain a misfire + running badly. Edited April 8 by KZJonny 1 Link to comment Share on other sites More sharing options...
LegacyLGT05 Posted April 8 Author Share Posted April 8 Thanks for the input kz. I shimmed the crank pulley guide and put new T belt kit a week after I dropped it in. It's also an manual and got new timing cover on er. Will defo check timing and go from there Link to comment Share on other sites More sharing options...
KZJonny Posted April 8 Share Posted April 8 Are there guards at the corners as well on the new timing cover? I forget exaclty where but I want to say passenger intake and drivers exhaust cams, but there may be more. If the crank guide is there and shimmed, the belt can still conceivably skip on the cam teeth if you bang-shift it hard enough... Either way, hope it's something simple. 1 Link to comment Share on other sites More sharing options...
LegacyLGT05 Posted April 9 Author Share Posted April 9 Timing ok, changed plugs runs better now think it was coils but now it miasfires bad after 4k, boost leak test and found none. Vac at 19hg no codes Link to comment Share on other sites More sharing options...
LegacyLGT05 Posted April 9 Author Share Posted April 9 Some reason 1 rad fan always on engine off key on or running its always on Link to comment Share on other sites More sharing options...
KZJonny Posted April 9 Share Posted April 9 Test (if possible) or replace coolant temp sensor? If ECU is getting bad coolant temp data, all sorts can go wrong. General check of wiring + grounds (again) isn’t a bad idea. You would not be the first to have a loose connection post engine install/swap etc… Link to comment Share on other sites More sharing options...
LegacyLGT05 Posted April 18 Author Share Posted April 18 Cutting out like at 4k - 4.5k rpm. Seen intake at 21psi is it possible I'm hitting boost cut, I'll have to check my wastegate Link to comment Share on other sites More sharing options...
KZJonny Posted April 18 Share Posted April 18 Yeah…. That is a big boost spike. Stock is like 14psi max. Definitely start with wastegate lines. Consider other failure points. How big is the exhaust? I peak at 17psi, and that was lifting my heads and blowing coolant out. 21psi on stock parts is gonna end badly. Link to comment Share on other sites More sharing options...
LegacyLGT05 Posted April 18 Author Share Posted April 18 No uppipe , catted bellmouth downpipe 3.5 inch I think it's a OBX racing .. Al vac or boost leak, I'ma check flapper and boost control solenoid. If I unplug the BC's will it default to spring pressure Link to comment Share on other sites More sharing options...
KZJonny Posted April 18 Share Posted April 18 21 minutes ago, LegacyLGT05 said: No uppipe ?? I assume you maybe mean catless up pipe? Big exhaust with no restrictions will cause boost spiking or overboost. 2.5" is all you need without a bigger turbo or a 3 port boost controller + tune etc... Yeah. Unplugging the BC will run on wastegate spring pressure. If you try that you can at least know if the wastegate control is working on springs. 1 Link to comment Share on other sites More sharing options...
LegacyLGT05 Posted April 18 Author Share Posted April 18 Yeah catless upper I bought the car like that so hard to tell if it's tuned for or not , I know it had 850cc injectors and when I got 550cc ones to replace it ran lean so idk Link to comment Share on other sites More sharing options...
KZJonny Posted April 18 Share Posted April 18 Is it a stock ECBS or something aftermarket. Leaks in any of those vacuum hoses are gonna be a problem as well. Link to comment Share on other sites More sharing options...
