VespaGTS Posted December 22, 2023 Share Posted December 22, 2023 I have an 07 LGT. I installed Perrin ELH and as we all know, one mod can necessitate another mod. I learned that there are several areas that need to be shielded. The first one is the AVCS Cam Sensor on the passenger side. I see a product from Verus that should work. If you know of others please let me know. Link to Verus: https://www.verus-engineering.com/blog/new-product-11/avcs-cam-sensor-heat-shield-for-2008-ej25-equipped-subarus-68?gclid=CjwKCAiAhJWsBhAaEiwAmrNyq63C04cokwwooozluiiAQNW05Z_uHSeVVKwNwmPxuPEzInlToCEGJxoCsd4QAvD_BwE Link to comment Share on other sites More sharing options...
shralp Posted December 22, 2023 Share Posted December 22, 2023 I’ve seen this from Verus and wondered if I need it as well with my ceramic coated Killer B. Seems like something is different in my ‘05? Don’t see anything plastic in that area that would get cooked? Link to comment Share on other sites More sharing options...
VespaGTS Posted December 22, 2023 Author Share Posted December 22, 2023 I am wondering if it’s even necessary if it’s not a tracked car? Sort of like an AOS (I have a Crawford). Is it overkill for a daily driver? I am installing a Rallitek skid plate as well and would prefer, if it’s needed, to get this shield installed prior to the skid plate going on. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 22, 2023 Share Posted December 22, 2023 Is that for the STI's which had dual AVCS ? 1 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
silverton Posted December 22, 2023 Share Posted December 22, 2023 Unless you've swapped the car, your 2007 Legacy GT should have an earlier EJ255 in it, which is intake avcs only. 10-12 ej255 legacies are dual avcs. Link to comment Share on other sites More sharing options...
VespaGTS Posted December 24, 2023 Author Share Posted December 24, 2023 On 12/22/2023 at 9:39 AM, silverton said: Unless you've swapped the car, your 2007 Legacy GT should have an earlier EJ255 in it, which is intake avcs only. 10-12 ej255 legacies are dual avcs. It’s an EJ257 with newer 2012 heads after rebuild. 1 Link to comment Share on other sites More sharing options...
