apacman316 Posted December 18, 2023 Share Posted December 18, 2023 (edited) Hello all. Trying to figure out what is causing noise near/under intercooler. Its an automatic. Thanks in advance! https://photos.app.goo.gl/Vgz1hPRLsoDAcEKSA Edited December 18, 2023 by apacman316 Link to comment Share on other sites More sharing options...
KZJonny Posted December 18, 2023 Share Posted December 18, 2023 If all nuts and bolts throughout the area are snug…. Something in the clutch? How new/old is the throwout bearing? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 18, 2023 Share Posted December 18, 2023 Or, does the noise stop when you push in the clutch pedal ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
apacman316 Posted December 18, 2023 Author Share Posted December 18, 2023 I haven't check to see if bolts are snugged but I'm pretty confident they are since the only work I did beside maintenance in that area was to fix a vacuum leak that required me to remove the intercooler since owning the car in 2020. this car is automatic. thanks for the reply. Link to comment Share on other sites More sharing options...
KZJonny Posted December 18, 2023 Share Posted December 18, 2023 (edited) 30 minutes ago, apacman316 said: I haven't check to see if bolts are snugged but I'm pretty confident they are since the only work I did beside maintenance in that area was to fix a vacuum leak that required me to remove the intercooler since owning the car in 2020. this car is automatic. thanks for the reply. Yeah, sorry, didn't read the OP closely enough. Well..... if everything in that area is snug, then maybe it's bad news and something in the trans/front diff? A mechanics stethescope, or a long screwdriver held to your ear etc... etc... may help to pin down where it's coming from. Really no external moving parts in that section of the bay.... Edited December 18, 2023 by KZJonny 1 Link to comment Share on other sites More sharing options...
Deltaking Posted December 28, 2023 Share Posted December 28, 2023 Isn't that the tubro... Maybe play on the blade and the blade is wobbling inside of turbo... 1 Link to comment Share on other sites More sharing options...
apacman316 Posted January 3 Author Share Posted January 3 after getting a stethoscope, it's the turbo. thanks all. going to swap out this weekend Link to comment Share on other sites More sharing options...
Deltaking Posted January 3 Share Posted January 3 Maybe just a rebuild, you may not need to replace the entire turbo unless the price comparison is more or less the same with labor or if your planning to put a different turbo in like the VF46... Link to comment Share on other sites More sharing options...
