Harsho1 Posted July 28, 2023 Share Posted July 28, 2023 looking for one of these clips. Of course they are discontinued from Subaru. It attaches to A/C compressor bracket and holds main alternator harness. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 28, 2023 Share Posted July 28, 2023 If you really have to have that exact part, maybe a junkyard. www.car-part.com Or just use a few zipties. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted July 28, 2023 Share Posted July 28, 2023 Is this it ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Harsho1 Posted July 28, 2023 Author Share Posted July 28, 2023 18 minutes ago, Max Capacity said: Is this it ? Yes. It is directly above the oil dipstick, and A/C compressor clutch wire in this picture. Link to comment Share on other sites More sharing options...
silverton Posted July 29, 2023 Share Posted July 29, 2023 If you absolutely need one the junkyard is the best bet. Otherwise just let it ride, or secure it with a zip tie. Enough heat cycles and years they just break no matter what you do. 1 Link to comment Share on other sites More sharing options...
KZJonny Posted August 1, 2023 Share Posted August 1, 2023 I was at least able to add one to my cart here: https://www.subarupartsdeal.com/parts/subaru-clamp~81904ag03a.html Maybe they still have actual stock? Link to comment Share on other sites More sharing options...
