PhilT Posted December 27, 2005 Share Posted December 27, 2005 I can't find the plug in the area i was told it would be (drivers left leg, fuse compartment).... anyone got a pic? No pic, but they are there. You will have to fish around a little though, then you will find two sets of connectors, each secured together with green tape. One white connector and one green one in each pair. Remove the tape, then connect the two white ones together. Turn the ignition on, but do not start the car, then as the gauges are sweeping, press the odometer reset, et voila ! A flashlight and a pair of long nosed pliers will come in handy. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
mlloydlgt Posted December 27, 2005 Share Posted December 27, 2005 Cool... Will look tomorrow am. Just to be clear, looking to *undo* two pair of white/green connectors w/ green tape and then connect the whites together. Reset the odo as the needles sweep.... ok.... if i do get to it tomorrow i'll take some pics for sure! Link to comment Share on other sites More sharing options...
red_suby Posted January 24, 2006 Share Posted January 24, 2006 P0500 - Vehicle speed sensor C0108 - Front ABS wheel speed sensor LH malfunction (ABS Wheel speed sensor abnormal signal) Have you noticed these CEL codes before and what did you do to resolve it? Thanks Link to comment Share on other sites More sharing options...
red_suby Posted January 24, 2006 Share Posted January 24, 2006 bump .. any ideas? Link to comment Share on other sites More sharing options...
mlloydlgt Posted January 24, 2006 Share Posted January 24, 2006 sounds like an abs problem to me. Link to comment Share on other sites More sharing options...
red_suby Posted January 24, 2006 Share Posted January 24, 2006 Just got a call from dealer and everything is fine now. According to them it was happened because of wheel slippage and the front whell ABS sensor was having problems with ice buildup on wheels. They have checked the circuits and it is looking fine Now I have to return the loaner Jeep Grand Cherokee Link to comment Share on other sites More sharing options...
NatesGr8 Posted January 24, 2006 Share Posted January 24, 2006 bring to a dealer, make them fix it for free. Link to comment Share on other sites More sharing options...
laz Posted February 13, 2006 Share Posted February 13, 2006 This happened to me today whle I was backing out of a snowy/slippery surface here in NYC. I gues the wheels all spunned at different speeds, and it came on. I drove later on, and at one point I had to backup again. This time I backed up normally and the light reset itself. It seems that it was the sensors that gave the false readings due to the wheels spinning at different speeds. X --- Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted March 4, 2006 Share Posted March 4, 2006 Well, I just got my engine light and cruise flashing. I was driving along and couldn't resist a big snow drift that wound up in the road. Instead of going around it like everyone else, I dove in headfirst and got stuck up to the doorwells in snow Who says SRT4 drivers are assholes? One stopped and offered to help me push. I told him no thanks and that this is what I get for screwing around. Actually, I just refused to believe that AWD couldn't get me out of this- but it did! Link to comment Share on other sites More sharing options...
Rexmobbin Posted March 26, 2006 Share Posted March 26, 2006 well, I got mine last night. Was driving home on the freeway, doing a steady 70mph in 5th gear, when the car kinda shuddered, the CEL came on, and the cruise started blinking. I've started the car 3 times since then, it's been about 12 hours, but it's still on. I'm gonna pull the code with my laptop when I get home, but based on my description, does anyone have any ideas? Link to comment Share on other sites More sharing options...
derffred Posted March 26, 2006 Share Posted March 26, 2006 if the car stuttered a bit.. my guess would be a misfire code.. maybe for a specific cylinder or a random misfire.. how does it run now? can you duplicate the complaint again? Link to comment Share on other sites More sharing options...
blacky Posted April 4, 2006 Share Posted April 4, 2006 Me be familliar- happend two times. Only winter, once when stuck in snow:lol: , second time was with a bit rev driving. Checked with AP which shows something with speed sensor , don't remember code#. Disapp. by it self:lol: Link to comment Share on other sites More sharing options...
LivNLegacy Posted April 4, 2006 Share Posted April 4, 2006 codes FTL If you can read this, you're following too close. Click Me Link to comment Share on other sites More sharing options...
blacky Posted April 6, 2006 Share Posted April 6, 2006 mine is also AP stage2 and I'm close to 15ooo miles Link to comment Share on other sites More sharing options...
iyamdman Posted April 8, 2006 Share Posted April 8, 2006 Last night drove my Leg - no problem. Today, got in car started. Engine light on, CC blinking. What happened while the car was parked? It is OC winter - no snow - lows in the 50's. Will try an ECU rest tomorrow morning and see if that does it. Link to comment Share on other sites More sharing options...
blacky Posted April 14, 2006 Share Posted April 14, 2006 leave it- it will disapear by it self:icon_bigg . Or if not just read the code Link to comment Share on other sites More sharing options...
selfish1 Posted April 2, 2008 Share Posted April 2, 2008 For what it's worth... My girlfriend's 2004 Legacy began exhibiting symptoms of CEL + flashing cruise control light immediately after she had her car serviced. We poked around under the hood and found that the technicians had disconnected an electrical connector adjacent to the air filter and hadn't re-connected it. After plugging it back in and starting the car twice, the CEL + flashing cruise light problem went away. It wouldn't hurt to check all the electrical connections under the hood. Unplug any connection you can find and re-plug them to possibly re-seat the electrical contacts that may have become corroded or tarnished. Link to comment Share on other sites More sharing options...
Mr. Cakes Posted April 2, 2008 Share Posted April 2, 2008 my car did this yesterday, it is socal so no snow, got home from work shut the car off and everything was normal, went to work and the cel + blinking cc lights were on, dissconnected the battery and everything is fine so far. Link to comment Share on other sites More sharing options...
Hanger Posted April 3, 2008 Share Posted April 3, 2008 same thing happened to me today... and i've just read this thread this morning samething in Socal, no snow, temp in the middle 50's ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
btketron Posted April 18, 2008 Share Posted April 18, 2008 I had this happen this past Sunday on a trip back from vacation in my 2005 Legacy (automatic/non-turbo). Took it to Advance Auto and the code reader came up with the oxygen sensor being bad. However, it's still running great--had a friend of mine that knows cars/engines drive it around and put it thru its' paces. Just like me, says it's still smooth, no weird noises, no loss of power, etc...so I am at a crossroads. Note that I have 78K miles on the car and it's out of warranty, and also that for the vacation trip I decided to put in a higher grade of gas than I usually do--which probably contributed to higher emission temps causing my oxygen sensor to go goofy. Let me poll for some opinions on what I should do: 1. Is it possible that this will not cause me engine/gas mileage problems in the future? 2. Depending upon that answer, should I replace the oxygen sensor or just let it ride and reset the computer since I'm currently having no problems? 3. If I need to replace it, does anyone have any tips/directions on how to replace the oxygen sensor? 4. Is it possible that running this tank of higher grade gas out and refilling with something more temperature friendly will cause the problem to go away? Thanks in advance for any replies. Link to comment Share on other sites More sharing options...
atcheng Posted April 21, 2008 Share Posted April 21, 2008 Interesting...same thing happened to me this weekend and I'm in SoCal as well. That's 3 SoCal in 3 days. Things that make you go hmm.... Link to comment Share on other sites More sharing options...
fishbone Posted April 21, 2008 Share Posted April 21, 2008 btketron, just so you know, your Legacy has a built in code reader so you can read your own codes and then cross-reference the code with a topic on this site to find out what it is. I would personally run 2 or 3 tanks of your usual gas and see if the CEL comes back on/resets itself. Link to comment Share on other sites More sharing options...
btketron Posted April 21, 2008 Share Posted April 21, 2008 btketron, just so you know, your Legacy has a built in code reader so you can read your own codes and then cross-reference the code with a topic on this site to find out what it is. I would personally run 2 or 3 tanks of your usual gas and see if the CEL comes back on/resets itself. Thanks for the input--I appreciate it. Can I get a quick explanation of how the built-in code reader works for future reference? A link to another post elsewhere will suffice if you or someone else doesn't feel like explaining. Link to comment Share on other sites More sharing options...
fishbone Posted April 21, 2008 Share Posted April 21, 2008 If I remember correctly: -shut the car down -open the fuse box in the car, to the left, near the hood open lever -connect two white cables -turn the car in the ON position and as your dashboard does it's typical swipe, hit the mileage reset on your daskboard -the error code will show up If not, I screwed up a step and you should read this: http://legacygt.com/forums/showthread.php?t=23292 I know it's free at Autozone to have it checked but why drive there every time? Link to comment Share on other sites More sharing options...
btketron Posted April 22, 2008 Share Posted April 22, 2008 Advance Auto does it free too, and it's just 2 minutes from where I work, plus my uncle works there and will do it for me quick and give me pretty good advice--though he's a lot better at domestic models than foreign...thusly why I came here for advice on this particular problem. I'll do that next time though fishbone...thanks! Link to comment Share on other sites More sharing options...
