SoobyDoobyDoo Posted October 4, 2022 Share Posted October 4, 2022 Has anyone done this, or know much about it (or know who is still around who has)Or was it ever really discussed? Can’t find much. Basically have all the rear JDM aluminum trailing arms and diff cradle pieces. Just wondering if I can get new usdm bushings and put everything back together or if it’s more complicated. Would like to swap over when I re-do the suspension. Thanks in advance for any advice… Link to comment Share on other sites More sharing options...
GearJamr Posted October 7, 2022 Share Posted October 7, 2022 I have heard there is an issue with the usdm abs module connecting to the jdm trailing arms. AFAIK it would involve splicing the jdm module to the usdm wiring, but don't quote me. That was the reason I sold the jdm arms I had and picked up some usdm spec.b arms. Link to comment Share on other sites More sharing options...
KZJonny Posted October 7, 2022 Share Posted October 7, 2022 (edited) I have the trailing arms and aluminium control arms only. Speed sensors had wires cut, but no problem installing USDM versions.... You need some adaptors from Cusco, since there is nowhere to mount a sway bar endlink unless yours came with the Spec B type brackets still installed. In which case you also need the odd Spec B swaybar. Don't know anything about the diff cradle, but I would very much suspect the bushes would all be the same? Probably the serious JDM ones would be metal bushes tho, no? Edited October 7, 2022 by KZJonny Sent from my phone… ugh. Link to comment Share on other sites More sharing options...
seanyb505 Posted October 7, 2022 Share Posted October 7, 2022 (edited) Use just the aluminum pieces, no need to worry if they come with any wiring. Usdm speed sensor bolts up fine. Make sure you have the bracket as mentioned. It's shown in spec b part diagrams. No real need for cusco stuff unless you will sleep better with it on. Any Legacy sway bar should work, I've not heard of a spec b specific sway bar. All usdm bushings work. There's really nothing magical about the jdm pieces, at least that I found when swapping it all in. Edited October 7, 2022 by seanyb505 Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted October 8, 2022 Author Share Posted October 8, 2022 (edited) Cool thanks for the responses everyone. Was wondering if it was a mostly bolt-in deal. I was planning on getting all new bushings anyways. I can do wire splicing that’s not a big deal if needed. I figured the spec b should be the same as a standard GT? I’ll have to check out the spec b sway bar endlink bushing, thanks for the info! Will the usdm one work or does it need to be JDM? Thanks Edit: I’ve got avo rear sway bar brackets- would this work? Edited October 8, 2022 by SoobyDoobyDoo Link to comment Share on other sites More sharing options...
KZJonny Posted October 8, 2022 Share Posted October 8, 2022 I think I must have been under some kind of impression that the JDM Spec B endlink bracket was unique somehow. Seems not? So, if just depends on how complete the kit you got was. Around me, they mainly seem to come with the swaybar and mounting brackets sold separately, so I had to get my own (cusco) brackets, then got the mounting point reinforcements at the same time, since it all had to come from Japan anyway. Fits my aftermarket swaybar just fine now. Had to drill a new hole to make the support brackets work, but not a big deal there. traildogck on outback.org apparently makes then as a direct fit for usdm cars, if needed. Link to comment Share on other sites More sharing options...
Infosecdad Posted October 8, 2022 Share Posted October 8, 2022 The USDB rear trailing arms have a built-in bracket for the endlinks, the aluminum trailing arms (at least from japan) do not have a built-in bracket, it's a separate piece. I bought the Cusco set of reinforcement for the swaybar brackets and they came with reinforced endlink brackets as well, which I can't use until I go to aluminum rear trailing arms. Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted October 8, 2022 Author Share Posted October 8, 2022 Idk…I wouldn’t think it would be, but I have no idea…seems like there’s all sorts of little nuance things that are different between JDM and usdm models to make doing anything a pita lol. I’ve seen his kits…but gotta be honest, looks like some lowes/home depot angle stock w/holes cut to size…I can do that myself. Also tried to get a hold of him about some front sway bar bushings he sells and no response, so don’t get a warm fuzzy feeling about that avenue. Just my experience. Good to know about the Cusco stuff…don’t have to have Cusco necessarily but if they make stuff that’ll work then that’s what I’ll use. All good info thanks again everyone! Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted October 12, 2022 Author Share Posted October 12, 2022 By chance does anyone know the part # for the spec b bracket? Found the Cusco but wanted to see what I could get the stock bracket for… Link to comment Share on other sites More sharing options...
KZJonny Posted October 12, 2022 Share Posted October 12, 2022 Don't have a stock part number, but FWIW it's worth considering getting Cusco part # (if you go with Cusco) Cusco 684 316 S Rear Harder Sway Bar Bracket The "S" is the important part, it is the kit which has the sway bar brackets AND the pointing point reinforcment plates. Maybe you'r already on it, but the price is a lot better for both as a kit than seperately, and why not. The bracket seems to be a weak point..... You DO need to drill a new hole in either it, or the brackets tho, spacing of the bolts holes is not the same between JDM/USDM. Link to comment Share on other sites More sharing options...
Infosecdad Posted October 12, 2022 Share Posted October 12, 2022 2 hours ago, SoobyDoobyDoo said: By chance does anyone know the part # for the spec b bracket? Found the Cusco but wanted to see what I could get the stock bracket for… Driver Side: https://parts.subaru.com/p/Subaru_2008_Legacy-25L-TURBO-6MT-4WD-GT-Limited-Sedan/Suspension-Trailing-Arm-Bracket-Left/49229322/20264AG010.html Passenger Side: https://parts.subaru.com/p/Subaru_2008_Legacy-25L-TURBO-6MT-4WD-GT-Limited-Sedan/Suspension-Trailing-Arm-Bracket-Right/49229321/20264AG000.html Example from eBay: https://www.ebay.com/itm/334501666204 https://www.ebay.com/itm/334501669358 Yes, the image is a bolt, but those should be the brackets. Link to comment Share on other sites More sharing options...
KZJonny Posted October 12, 2022 Share Posted October 12, 2022 Hmmm. That price is a good reason to buy OEM. I'd never considered that they'd be available, and so affordable here. Didn't spent enough time digging in to those, but they're far from the priciest thing I bought in the upgrade project, so meh. Mine are blue tho!! Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted October 13, 2022 Author Share Posted October 13, 2022 Thanks @Infosecdad and @KZJonny! Helps if you search with that right terminology I guess…”rear sway bar brackets” instead of “rear trailing arm bracket” just makes too much sense…. @KZJonnydid yours bolt right up? From what I’ve read so far the holes don’t match up to the usdm bracket? Might be worth the extra $$ (or a lot of extra….) to have matching holes… Link to comment Share on other sites More sharing options...
KZJonny Posted October 13, 2022 Share Posted October 13, 2022 (edited) The sway bar mounts that affix to the trailing arms were totally fine. Direct bolt up. The sway bar mounting point reinforcing brackets that mount to the subframe points need a hole drilled to match. That can be in either the cusco part, or the subframe. Easy fix. I’ll take some photos of mine when I have a moment, but you’d figure it out fast enough. Edited October 13, 2022 by KZJonny Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted October 13, 2022 Author Share Posted October 13, 2022 (edited) Ok thanks, no worries. If you can get some pics I’d appreciate it but like you said, I’m sure once I get in there I can figure it out. edit: found some pics on Blackhawk japan. I see what you mean now. Might just go ahead and invest in the Cusco kit, seems like it’d be better/easier for install. Edited October 13, 2022 by SoobyDoobyDoo Link to comment Share on other sites More sharing options...
