neeksimons Posted March 11, 2022 Author Share Posted March 11, 2022 Could it be my ground? I used a bolt right above the brake pedal? Is it not grounded properly?? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
neeksimons Posted March 11, 2022 Author Share Posted March 11, 2022 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
All_talk Posted March 11, 2022 Share Posted March 11, 2022 I see you put the tap in fuse #13 "Tail/Clearance", I believe that will only have power with the lights on. I used #14, which has power any time the key is on. Maybe that's the issue? Link to comment Share on other sites More sharing options...
neeksimons Posted March 11, 2022 Author Share Posted March 11, 2022 I see you put the tap in fuse #13 "Tail/Clearance", I believe that will only have power with the lights on. I used #14, which has power any time the key is on. Maybe that's the issue? Wow I'll definitely take a look right now. I could've sworn I used the ones you referenced earlier. I triple checked but I'll get back to you. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
whitexc Posted March 11, 2022 Share Posted March 11, 2022 (edited) What did you end up doing for a ground? The metal you found behind the radio may not be suitable. Either tap into factory wiring for a ground or find a good spot on the tunnel, footwell, etc. Sent from my SM-G996U using Tapatalk Edited March 11, 2022 by whitexc Link to comment Share on other sites More sharing options...
neeksimons Posted March 11, 2022 Author Share Posted March 11, 2022 What did you end up doing for a ground? The metal you found behind the radio may not be suitable. Either tap into factory wiring for a ground or find a good spot on the tunnel, footwell, etc. Sent from my SM-G996U using Tapatalk The last picture is where I put the ground wire. It's a nut behind the brake pedal. Is that a good spot? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
neeksimons Posted March 11, 2022 Author Share Posted March 11, 2022 I see you put the tap in fuse #13 "Tail/Clearance", I believe that will only have power with the lights on. I used #14, which has power any time the key is on. Maybe that's the issue? Isn't #13 12v plug and #14 tail/clearance??? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
neeksimons Posted March 12, 2022 Author Share Posted March 12, 2022 Okay so I retested everything and im 99% sure the taps are correct. So it got me thinking about the ground. I went and tested the ohms resistance on the bolt where I grounded it and it read 16 ohms. Isn't it supposed be as close to zero as possible?? Could that be my problem? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Ratmilk Posted March 13, 2022 Share Posted March 13, 2022 Okay so I retested everything and im 99% sure the taps are correct. So it got me thinking about the ground. I went and tested the ohms resistance on the bolt where I grounded it and it read 16 ohms. Isn't it supposed be as close to zero as possible?? Could that be my problem? Sent from my iPhone using Tapatalk You're correct, needs to be almost 0. Your circuit has a total resistance of 16 ohms. Try setting on lead on your chosen ground point and the other lead on various pieces of unpainted metal. Try one of the brass screws holding the fuse box. Even though the fuse box is plastic the screw is still a good ground. EDIT: Only use this kind of ground for low voltage applications. Link to comment Share on other sites More sharing options...
neeksimons Posted March 13, 2022 Author Share Posted March 13, 2022 (edited) Update I got them working, I'm not sure if this was my problem all along but when I connected the red, orange, and black wiring to the fuse taps (red, orange) and black to the ground using the supplied connectors by defi the connector never actually pierced the jacket of the wire to make a connection. So I had to open up the connector and strip back the jacket on all the wires and it worked! I used the ground in the engine bay next to the fuse box and battery too. Since everything is wired right now but the sensors aren't hooked up yet. Is it normal for the gauges to move up and down a little bit since they're wired up but not connected in the engine bay yet and not actually reading anything yet? Sent from my iPhone using Tapatalk Edited March 13, 2022 by neeksimons Link to comment Share on other sites More sharing options...
