cacocker Posted January 14, 2022 Share Posted January 14, 2022 2009 2.5i Long story short, my exhaust system is essentially so rusted it wont exist in the spring. Everything behind the headers has to go. The brake calipers are also malfunctioning, for a reason yet to be determined. My shop says they basically aren't moving when the brakes are pressed and the pedal is SUPER soft. Exhaust: The headers are still good, but I have the opportunity to get the boxer rumble on a car that hasn't had it. Any parts better than others? Full kits, headers to tips, would be ideal; otherwise I can compile parts. Taking recs. Brakes: If its not just air in the lines, and I need to replace parts, I'd like to upgrade to better-than-stock 2.5i calipers, pads and rotors. Maybe the spec-b setup? Or other ideas... Link to comment Share on other sites More sharing options...
Max Capacity Posted January 14, 2022 Share Posted January 14, 2022 It's a 2.5i so not many if any upgrades for it. Any exhaust shop can replace your stock system. They may have some mufflers that will give a little more sound. One thing us GT guys do was to remove the mufflers or place some washers between the Y pipe flange and muffler flange. Spec B brakes are the same as GT brakes. Can should get rebuilt calipers from a local auto parts store and buy the best pads they have along with new rotors. I bought a Motive Power Bleeder to flush out the old brake fluid. I also ordered the large plate for my 1986 F150, you don't need that, just the Model 0107 bleeder. You can get DOT 3 fluid from any discount store by the qt. cheaper than auto parts stores, figure about $7.00 a qt. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Febreze Mee Posted January 14, 2022 Share Posted January 14, 2022 You won't get that boxer rumble without replacing your headers for unequal length units. I've read Infernofab makes a good UEL header for the 2.5i platform: https://infernofab.com/subaru-2-5i-uel-header-mild-steel.html There are various members who have tried over the years to achieve this through the 2.5i platform. A quick google search will yield many threads that show different ways of going about this, and different products used throughout these attempts. If this car isn't anything more than your daily driver, I wouldn't invest much into trying to change things up. Just grab a factory catback replacement. Replace the necessary failed braking components with stock units. A good set of pads, and a better set of tires goes a long way and is all that is needed. If you aren't racing the car, or going for extended periods of hard spirited driving, I would be pressed to think you are not out-driving your factory brakes, thus the stockers are sufficient. - A fellow 2.5i owner MILKRUN - Click Here Link to comment Share on other sites More sharing options...
shralp Posted January 14, 2022 Share Posted January 14, 2022 Aren’t NA exhaust manifolds unequal length just like the Turbo ones? Pretty sure they are. Any free flowing muffler should give you rumble. You’re just not hearing it with the restrictive OEM cans. Link to comment Share on other sites More sharing options...
cacocker Posted January 14, 2022 Author Share Posted January 14, 2022 Aren’t NA exhaust manifolds unequal length just like the Turbo ones? Pretty sure they are. Any free flowing muffler should give you rumble. You’re just not hearing it with the restrictive OEM cans. That's a good question. I don't know the answer. Bueller? Link to comment Share on other sites More sharing options...
Pleides Posted January 15, 2022 Share Posted January 15, 2022 (edited) They are unequal length. You'll get more of a monster truck sound than a turbo Subaru sound with less exhaust restriction on an NA. Remove the mufflers and see if you like the sound. If you do and your neighbors won't hate you, leave it or run it straight-through with some test pipe. Ideally, however, because the car is clearly rusting to death, you'd spend the minimal amount of money to get it where you like and leave it to die a slow death. Edit: oops I was wrong. They are equal length… Edited January 17, 2022 by Pleides Link to comment Share on other sites More sharing options...
ttnio Posted January 16, 2022 Share Posted January 16, 2022 keep it stock and be happy motto lives! Link to comment Share on other sites More sharing options...
Febreze Mee Posted January 17, 2022 Share Posted January 17, 2022 2005+ N/A Legacy/Outback/Impreza came with ELs. The 2005MY headers are a different layout than 2006+, however, all are still EL. Of course all turbo variants are indeed UEL. Having been under the car to confirm on both my 06 2.5i s, and taking the mufflers off, I do not produce the same sound out of my EJ that all the other N/A guys with UEL headers on their cars produce, and so I keep my mufflers so I don't sound like a tractor. MILKRUN - Click Here Link to comment Share on other sites More sharing options...
cacocker Posted January 26, 2022 Author Share Posted January 26, 2022 Screw it, who wants to buy this thing? Link to comment Share on other sites More sharing options...
VespaGTS Posted January 26, 2022 Share Posted January 26, 2022 Ha! Consider just going to a local exhaust shop and having them make up a system for you. Link to comment Share on other sites More sharing options...
Infosecdad Posted January 26, 2022 Share Posted January 26, 2022 So what else is wrong with it that you would rather move on? Link to comment Share on other sites More sharing options...
Febreze Mee Posted January 27, 2022 Share Posted January 27, 2022 Also curious why your ready to ditch the car, if that was a serious question. Hard to read through text. Why not just go to your local junk yard? My local Pick n pull is showing an entire exhaust/muffler combo for $33. Obviously it'll be used, and no telling the condition until you get there and pull it yourself, but it's $33! Even if, it lasted a year or two, I'd say you go your money's worth considering a factory midpipe alone goes for $250 brand new. Of course, you'll have to worry about sourcing a catalytic converter on top of your $33 OEM exhaust from the junkyard, as I'm sure they've been capitalizing on the palladium and platinum prices. As for brake calipers, you could also probably pick those up for super cheap at the junkyard, order a rebuild kit from Subaru, rebuild them yourself or have your shop do it. Ordering a rebuilt caliper from your local auto parts store as Max suggested above is a great option too. Probably best to fix the two know issues and keep the car, rather than fight the used-car market right now. Of course, I say this without knowing your entire situation. Goodluck! MILKRUN - Click Here Link to comment Share on other sites More sharing options...
