Reags8 Posted June 23, 2021 Share Posted June 23, 2021 Ok searched the forum and really didnt find anything that worked. I picked up a 05' GTL wagon and looking for a winter tire rim set up. In the past I could find tons of used VW setups on craigslist, marketplace etc ... but I can't find anything that is a simple bolt on ? Do I need to purchase spacers and look for another bolt patterns ? tire size etc ... ? Thanks in advance Reags Link to comment Share on other sites More sharing options...
NoOne1223 Posted June 23, 2021 Share Posted June 23, 2021 What you're looking for are 5x100 bolt pattern wheels and a bore of 56.1 there is a whole thread about tire sizes. Sent from my SM-N960W using Tapatalk Link to comment Share on other sites More sharing options...
Rcnesneg Posted June 23, 2021 Share Posted June 23, 2021 Yep - 5x100 with a 56.1mm center bore. So basically any 5x100 subaru wheel. Wheels from other manufacturers don't generally work since they don't have the right center bore. These are basically all fair game: https://forums.nasioc.com/forums/showthread.php?t=2239019 Link to comment Share on other sites More sharing options...
Max Capacity Posted June 23, 2021 Share Posted June 23, 2021 I run 225/45-17's or 18's on both my cars for winter and summer tires. You may be able to find used rims on the for sale forum on here. Or many online places will sell you new rims. I have two sets of OEM wheels for both my cars. I like the way they look. Tirerack.com will have a large selection of wheels. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Beeswax Posted June 26, 2021 Share Posted June 26, 2021 Brand new steels are around 100 ea on tire rack Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted June 26, 2021 Share Posted June 26, 2021 Junkyards may have OEM wheels for cheap. https://www.car-part.com/cgi-bin/search.cgi Lot's of body shops will know of someone to fix them if needed. Or search for wheel repair shop near you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
