Yonas Posted May 29, 2021 Share Posted May 29, 2021 Dealer said my rear left toe adjustment bushing is torn. Is there another name for this part? I'm trying to look up what it looks like. Link to comment Share on other sites More sharing options...
motorbreath Posted May 29, 2021 Share Posted May 29, 2021 Did they provide a part number? I am no expert, by any means, but my understanding is the only part of the rear suspension that is adjustable affects both camber and toe. I installed a set of adjustable rear lower links so that I could get an alignment with both toe and camber in spec for the rear wheels. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 31, 2021 Share Posted May 31, 2021 (edited) They said "bushing" so it should be one of the bushings here, https://parts.suburbansubaru.com/a/Subaru_2010_Legacy-36L-5AT-4WD-R-Premium-Sedan/_54106_6029048/REAR-SUSPENSION/B14-201-01.html Have you asked google to find that for you ? May be one of the aftermarket companies makes adjustable arms like for the 4th Gen's. https://www.google.com/search?q=2010+SUBARU+LEGACY+REAR+SUSPENSION+BUSHINGS&rlz=1C1OKWM_enUS906US906&sxsrf=ALeKk00bN1YcYrV-7LlxeqxwNyaKF52unA%3A1622488276985&ei=1DS1YKmnO4Tk5NoPq72p6Ao&oq=2010+SUBARU+LEGACY+REAR+SUSPENSION+BUSHINGS&gs_lcp=Cgdnd3Mtd2l6EAwyBAgjECc6BwgAEEcQsAM6BwgjELACECdQ4lRYn2VgroEBaAFwAngAgAGQA4gBowSSAQUyLjQtMZgBAKABAaoBB2d3cy13aXrIAQbAAQE&sclient=gws-wiz&ved=0ahUKEwip4Zrrz_TwAhUEMlkFHateCq0Q4dUDCA4 https://www.google.com/search?q=2010+subaru+legacy+rear+suspension+diagram&rlz=1C1OKWM_enUS906US906&sxsrf=ALeKk004eYu1MwPKc8wrFSYc5Ca0LyzSqg%3A1622488336621&ei=EDW1YKKTJbih5NoP2KS-iAU&oq=2010+SUBARU+LEGACY+REAR+SUSPENSION+&gs_lcp=Cgdnd3Mtd2l6EAEYATIECCMQJzIGCAAQFhAeMgYIABAWEB4yBggAEBYQHjoHCCMQsAMQJzoHCAAQRxCwA1DGL1jGL2DBPmgBcAJ4AIABmgKIAeACkgEFMS4wLjGYAQCgAQGqAQdnd3Mtd2l6yAEHwAEB&sclient=gws-wiz https://www.carid.com/2010-subaru-legacy-performance-suspension-bushings/ https://www.carid.com/2010-subaru-legacy-control-arms-suspension-rods/?filter=1&field%5B368204%5D%5B1%5D=Rear Also the car is 11 years old, take it to a local indi shop that has their own alignment rack and have them repair it. I have a trusted mechanic that I just dropped my 05 GT wagon back from who replaced the 6 rear suspension arms, trailing arm bushings with the parts I brought. It was all labor for them, it wasn't cheap but at 297,000 miles, I'd rather give them the money then fight the rust myself. I also brought them new OEM bolts and nuts. See my post below this thread. Edited May 31, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dgoodhue Posted May 31, 2021 Share Posted May 31, 2021 They said "bushing" so it should be one of the bushings here, https://parts.suburbansubaru.com/a/Subaru_2010_Legacy-36L-5AT-4WD-R-Premium-Sedan/_54106_6029048/REAR-SUSPENSION/B14-201-01.html The toe adjustment is part number 20250F in this diagram. Link to comment Share on other sites More sharing options...
