Artizan Posted July 10, 2019 Share Posted July 10, 2019 Wanted to get Eibach, but there doesn't seem to be a single set for sale on this planet. What options are currently available? Preferably with a similar drop of around 1 inch. If you have a link, even better! Link to comment Share on other sites More sharing options...
Southygarage Posted July 10, 2019 Share Posted July 10, 2019 I'm poor.. the usual scumbags offer up the full set of adjustable height/camber/damping coilovers for 300ish. Sent from my Z999 using Tapatalk Link to comment Share on other sites More sharing options...
VespaGTS Posted July 11, 2019 Share Posted July 11, 2019 I went with King Springs. But they lower more than an inch. Truth be told by the time I was done adding struts from Koni and doing the install I could have bought coil overs. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
grovlet Posted July 11, 2019 Share Posted July 11, 2019 (edited) Rallitek carries both Swift and King - My research led me to believe the Swift was the better option but the Kings have the exact drop OP is looking for and are also tried and true for the LGT.... RalliTek Springs LGT Partner either up with Konis / Sway Bars / new Bushings - you'll be very happy! Edited July 11, 2019 by grovlet Link to comment Share on other sites More sharing options...
grovlet Posted July 11, 2019 Share Posted July 11, 2019 I went with King Springs. But they lower more than an inch. Truth be told by the time I was done adding struts from Koni and doing the install I could have bought coil overs. Sent from my iPhone using Tapatalk LOL - NOT a coilover that would compare to the handling from that setup:p:cool: - Cheap Coilovers (BC/ISC/Raceland) are poorly setup for compression and rebound dampening - along with odd spring rates and typically fall apart in within 10K miles from reports on LGT... Cheap Coilover Thread I would go Konis & Springs all day over ANY Cheap Coilover.... Hell they change the car completely even with STOCK springs and sway bars / bushings Link to comment Share on other sites More sharing options...
amm203 Posted July 15, 2019 Share Posted July 15, 2019 https://subimods.com/hr-sport-springs-2005-2009-lgt-54425.html Running these with Koni yellow sport adjustable dampers. Great combo. Lowered about 1". Running them with 8"/225mm wheel/tire combo - no pulling of fenders required. They also fit fine with 8.5"/235mm combo and no pulling required on the fenders. Link to comment Share on other sites More sharing options...
GearJamr Posted July 17, 2019 Share Posted July 17, 2019 It's my understanding that the H&R springs are sedan only? Apologies if I am mistaken. For my wagon I got the Swift springs. Car now has a slight rake as the rear is just ever so slightly higher than the front (maybe a 1/4"). Personally, I think it looks great and it's about a 1" drop. They are paired with Konis as well. I went full on the Koni adjustment, but it's a little too bouncy, so I will probably dial them back about a 1/2 turn. Just fyi if you go that route. Link to comment Share on other sites More sharing options...
Tehnation Posted July 18, 2019 Share Posted July 18, 2019 i was a fan of koni's .... until i tried sending them in to get serviced and destroyed them trying to get them out the sleeves.... u can't find the eibach springs for 4th gen because they probably stopped making them lol.... Link to comment Share on other sites More sharing options...
lilredwagon Posted July 19, 2019 Share Posted July 19, 2019 (edited) I had Tein H-Techs, and replaced them with Swifts. I think I purchased them both from Amazon. I'm in an Outback, so I needed a saggy butt spacer in the rear. But they both lowered to what would be considered around 1" compare to stock LGT. Mine are on JDM LGT Rev A Bilsteins, but I generally LOVE Konis, so I think you have two good options for shocks. Any of these springs (Swift, H-Tech, King) plus either of those shock options would be worlds better than those cheap-o coilovers. Edited July 19, 2019 by lil'redwagon Link to comment Share on other sites More sharing options...
NORULZleggy Posted July 19, 2019 Share Posted July 19, 2019 I had run the Tein Green coilovers for as long as I can remember. they are the SDS street basis one's. I only raised them to the top, threw on my 18x8s, and never touch them. the car always settles with an index finger or more gap. many trips out of town for 2-3 hours each way with no problems. 6 years on them. Trick is to set it and forget it. I will buy them again. I also had all white parts I could put on suspension wise. Sways, endlinks etc... Link to comment Share on other sites More sharing options...
