youngtryhard Posted July 9, 2019 Share Posted July 9, 2019 Hey guys so I had a shop do my timing belt on my 07 LGT and the car was running amazing until about a week ago it just turned of on the way to work I towed it back home and put it in the garage. Than I took the timing covers of and I spun the motor and both cams were perfectly timed but my crank was 1 tooth ahead and the crank timing belt guide was never put back by the shop what should be my next step?, should I just re time the motor and put the guide in and hopefully nothing is broken? Sent from my SM-G973U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted July 9, 2019 Share Posted July 9, 2019 You should at least let the Shop know. May be it was a mistake. See what they say. If there's damage, they need to know and step up and fix it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DaveWaters Posted July 9, 2019 Share Posted July 9, 2019 (edited) If it’s an automatic there is no guide(s) from the factory, only mounting points for a guide. Was a holy shi.. who was in here? moment for me when I did my timing belt and saw no guide. After a quick search I discovered the autos don’t have one. If you think its off by one tooth double check as it takes a good amount of turn at crank to make a small difference in the marks at cam gears. Edited July 9, 2019 by DaveWaters Link to comment Share on other sites More sharing options...
youngtryhard Posted July 9, 2019 Author Share Posted July 9, 2019 It's a manual man, thanks tho. Sent from my SM-G973U using Tapatalk Link to comment Share on other sites More sharing options...
DaveWaters Posted July 9, 2019 Share Posted July 9, 2019 Yeah .. thats a problem.. I’m doubtful that it only would skip one tooth though. Any DTC come up? Link to comment Share on other sites More sharing options...
youngtryhard Posted July 9, 2019 Author Share Posted July 9, 2019 When the car turned of it said right cam over advanced on the accessport Sent from my SM-G973U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted July 9, 2019 Share Posted July 9, 2019 Which timing belt is installed ? Dayco, Gates, Aisin ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
youngtryhard Posted July 10, 2019 Author Share Posted July 10, 2019 Gates performance belt. Sent from my SM-G973U using Tapatalk Link to comment Share on other sites More sharing options...
m sprank Posted July 11, 2019 Share Posted July 11, 2019 Guide is there on MT only. It is there to stop the belt skipping teeth from shift shock. No shift shock on an AT. That being said it sounds like the belt skipped. Re-time it and cross your fingers. You cant perform a leak down without being in timing anyway. If it only jumped 1 or 2 teeth you should be fine. Link to comment Share on other sites More sharing options...
SageAbkatsor Posted July 14, 2019 Share Posted July 14, 2019 Scary. Would definitely give the shop a call before doing anything just to see what they say, and get the ball rolling, just in case anything is damaged. Doesn't sound like it should be damaged though Link to comment Share on other sites More sharing options...
