dukeneverwinter Posted May 6, 2019 Share Posted May 6, 2019 Playing around with springs on my BTS Outback kit. I would like to try some STI pinks or BTS-5056 springs. Anybody? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 6, 2019 Share Posted May 6, 2019 (edited) I don't have a set for you. I'd rather keep mine . You feel the springs are too soft? Edited May 7, 2019 by xt2005bonbon Link to comment Share on other sites More sharing options...
dukeneverwinter Posted May 7, 2019 Author Share Posted May 7, 2019 Didn't get the drop I was expecting. Didn't loose any height! The camber/caster plates I used took up the half inch of expected drop. Figured If I can get a set of springs I can experiment. Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 7, 2019 Share Posted May 7, 2019 Hang on a second. I don't understand, you have the BTS kit without the BTS springs? Then which springs do you currently have? Link to comment Share on other sites More sharing options...
dukeneverwinter Posted May 7, 2019 Author Share Posted May 7, 2019 I have what started as a full bts 5056 kit. If I had installed with the jdm soec b style tophats I would have maybe lost 1/2in if height in the front. As is, it is the same as the precious oe struts and springs. Front is Bts strut/spring/moorsport camber-caster tophat. Just about 17" from center to fender Rear is Bts strut/rallitek spring/usdm tophat. No drop even with the spring clip on the second from lowest settting. About 17.5 front center to fender Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
dukeneverwinter Posted May 7, 2019 Author Share Posted May 7, 2019 I'd like an extra set of bts springs to play with(i.e.) cut of an inch or so of the bottom coil. "For science" just for a tad more drop Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
