garygbnj Posted April 7, 2019 Share Posted April 7, 2019 Looking for a 6 Spd Mt from a Spec B. Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted April 8, 2019 Share Posted April 8, 2019 just the trans or the whole swap? Link to comment Share on other sites More sharing options...
garygbnj Posted April 9, 2019 Author Share Posted April 9, 2019 Do you have the whole swap? Formula B from the forums states 07-09 spec B.It doesn't mention an 06. Is an 06 the same as a 07-09? How many miles and what kind of use on the units? What shape are they in? Is the 06 shifter a non linkage type ie: not a cable shifter? What are you asking for what you have? I am in FL and would have to ship it. Link to comment Share on other sites More sharing options...
garygbnj Posted April 9, 2019 Author Share Posted April 9, 2019 What year is the Spec B units from? I just assumed from your ID that it was an 06 unit. Just read that the 06 Spec B was a 5 spd. Link to comment Share on other sites More sharing options...
Gtrekt Posted April 9, 2019 Share Posted April 9, 2019 The 06 Legacy GT "spec B" is a 5spd, the 07-09 is the highly valued 6spd. I'm sure your aware but in case your not, for the swap youll need the transmission, all 4 axles, rear diff, drive shaft, shifter linkeage assembly and the ash tray trim bezel from a 6spd Spec B. Also just in case make sure you get the engine cradle where the rack and pinion sits. You most likely wil not need it but get it if your able. I just sold my 6spd swap from my 08 Spec B parts car lol, otherwise I would love to sell you one. Good luck with search Link to comment Share on other sites More sharing options...
garygbnj Posted April 9, 2019 Author Share Posted April 9, 2019 Thanks. I will let the swap idea pass. Link to comment Share on other sites More sharing options...
