1-3-2-4 Posted September 14, 2018 Share Posted September 14, 2018 I’m looking at some 245/45/17 tires for wheels that are 17x 7.5 is the wheel not wide enough? I need tires bad so I’m trying to get my info right before I order. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 14, 2018 Author Share Posted September 14, 2018 Anyone? Link to comment Share on other sites More sharing options...
MC_Legacy Posted September 14, 2018 Share Posted September 14, 2018 I think you will be fine, the only thing you will see is the tire popping out a more than the rim. And I think thats one big iff. I've ran some 255/45/17 on some 17 x 7, I loved the look, it made the wheels look wider than they really were. I think you will be fine, anyone? lol Link to comment Share on other sites More sharing options...
derp Posted September 14, 2018 Share Posted September 14, 2018 Willtheyfit.com Put new size and old size to compare. I could suck start a snow blower. Link to comment Share on other sites More sharing options...
whitetiger Posted September 14, 2018 Share Posted September 14, 2018 I’m looking at some 245/45/17 tires for wheels that are 17x 7.5 is the wheel not wide enough? I need tires bad so I’m trying to get my info right before I order. they are quite tall for the LGT. 245/40/17 is the more optimal size. make sure you have front strut clearance in the lower spring perch by measuring your existing setup and comparing with willtheyfit.com Link to comment Share on other sites More sharing options...
rhino6303 Posted September 14, 2018 Share Posted September 14, 2018 I think a 235/45/17 would be a better match than what you're looking at on a 7.5" rim. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 14, 2018 Author Share Posted September 14, 2018 My car is lowered on h-tech springs I’m trying to get a tire with the largest tire to rim clearance as possible due to the millions of pot holes here.. I drive between NJ/NYC to CT every morning around 3am so not always are they easy to see. I have some pretty mangled rims at the moment.. just waiting to make sure the tire size is right before I get the other two wheels lol Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 14, 2018 Author Share Posted September 14, 2018 I’m not sure of the outback sedan stock wheels which is what I have on now. Link to comment Share on other sites More sharing options...
LegacyJoe Posted September 15, 2018 Share Posted September 15, 2018 https://play.google.com/store/apps/details?id=com.mkw.wheels.calc You can use this app for calculate. I use always before change tires on my gt. Tapatalkkal küldve az én G3112 eszközömről Link to comment Share on other sites More sharing options...
fedaykin Posted September 19, 2018 Share Posted September 19, 2018 My rule of thumb: 7.0" = 215 7.5" = 225 8.0" = 235 8.5" = 245 Check the tyre specs, manufacturer would have a range of wheel widths recommended for the tyre. I wouldn't put 245 on a 7.5" but I think you'll be fine. Link to comment Share on other sites More sharing options...
grovlet Posted September 25, 2018 Share Posted September 25, 2018 Xekonk Sticky has all the info you need.... But 245/45 is not really recommended.... 245 = Min 8" Width & as noted 45 sidewall is too tall for that width.... Recommendation is actually 225/45/17 Link to comment Share on other sites More sharing options...
shralp Posted September 25, 2018 Share Posted September 25, 2018 IMHO a 245 on a 7.5 is just to big a tire on too narrow a rim. 225 would be more appropriate with a step up to 235 on a 8" wide rim.... Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 7, 2018 Author Share Posted October 7, 2018 Got them in I totally forgot about the valve stem however lol Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 7, 2018 Author Share Posted October 7, 2018 So I was looking in the service manual and I see the settings or what would be for the toe in/out I'm wondering if the bolt is maxed out on toe-out.. Link to comment Share on other sites More sharing options...
