Can I run these tires with these wheels?
1-3-2-4
I think you will be fine, the only thing you will see is the tire popping out a more than the rim.
And I think thats one big iff.
I've ran some 255/45/17 on some 17 x 7, I loved the look, it made the wheels look wider than they really were.
anyone?
lol
I’m looking at some 245/45/17 tires for wheels that are 17x 7.5 is the wheel not wide enough?
I need tires bad so I’m trying to get my info right before I order.
they are quite tall for the LGT. 245/40/17 is the more optimal size. make sure you have front strut clearance in the lower spring perch by measuring your existing setup and comparing with willtheyfit.com
My car is lowered on h-tech springs I’m trying to get a tire with the largest tire to rim clearance as possible due to the millions of pot holes here.. I drive between NJ/NYC to CT every morning around 3am so not always are they easy to see.
I have some pretty mangled rims at the moment.. just waiting to make sure the tire size is right before I get the other two wheels lol
  • 2 weeks later...
