ehsnils Posted August 25, 2018 Share Posted August 25, 2018 Why a carbon fibre driveshaft? So when it breaks it's going to be sudden and spectacular! Link to comment Share on other sites More sharing options...
Imprzme Posted August 25, 2018 Share Posted August 25, 2018 Why a carbon fibre driveshaft? Less rotating mass = free up horsepower to the wheels Link to comment Share on other sites More sharing options...
fredrik94087 Posted August 25, 2018 Author Share Posted August 25, 2018 So when it breaks it's going to be sudden and spectacular! I used to think that way until I read the rating for my sti transmission CF driveshaft. the one for the q50 has been tested to 6800 ft lbs of torque and good for 1000+hp. it will be rather uneventful. i know stresses can happen in different ways that may weaken the structure. The image of a carbon fiber bike breaking in a downhill race comes to mind. Not worried about that happening to the driveshaft. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted August 25, 2018 Author Share Posted August 25, 2018 Less rotating mass = free up horsepower to the wheels it will also twist more. STORE Save time and search for your what you need here.... Home / INFINITI / Drivetrain / INFINITI Q60+Q50 Red Alpha Carbon Fiber & Aluminum AWD Driveshafts by DriveShaft Shop by Fmeaddons infiniti q50 q60 mods upgrade kitinfiniti q60 driveshaft upgrade mods kitinfiniti q60 q50 driveshaft mod upgrade kitinfiniti Q60 Q50 mods upgrade kitstock q60 driveshaftQ60 Q50 infiniti mods upgrade kitinfiniti Q60 Q50 driveshaft upgrade mods kit INFINITI Q60+Q50 Red Alpha Carbon Fiber & Aluminum AWD Driveshafts By DriveShaft Shop $944.99 – $1,522.49 Starting at $84/month with Affirm. Learn more We have partnered with the industry leader in driveshafts to give Alpha customers the best in getting the pavement shredding power of their VR30 3.0L Twin Turbo to the ground. Driveshaft 1 Add to cart Share, Tweet, Pin or Email a friend! Email SKU: ALP.28.03.0001-X Category: Drivetrain Description Additional information Reviews (0) DESCRIPTION infiniti Q60 Q50 driveshaft upgrade mods kit AMS Performance is excited to release the first in the line of INFINITI Q60 and Q50 Red Alpha products. Introducing the INFINITI Q60 + Q50 Red Alpha Driveshafts by DriveShaft Shop. We have partnered with the industry leader in driveshafts to give Alpha customers the best in getting the pavement shredding power of their VR30 3.0L Twin Turbo to the ground. This driveshaft helped us get to the world record quarter mile run in our shop Q60 Red Alpha with a 1.48 second 60′ time. The Strength of Alpha The Aluminum one piece INFINITI Q60 + Q50 Red Alpha Driveshaft is made from 3.5″ x .125″ wall 6061-T6 Aluminum and is rated to 3464 ft lbs of torque and spun at over 9000 RPM. Alpha’s superior one piece design eliminates the power robbing sloppy center knuckle which is a weak point in the stock system. Our one piece aluminum shafts are manufactured using a pulse welding technique as opposed to mig welding. The pulse type weld creates a lot less heat resulting in a stronger shaft. The CV used in the Alpha shaft is a purpose built high speed CV from GKN in Germany. The spline that the CV mounts to is made from 300m and is capable of transferring 6800 ft lbs of torque without failure. The INFINITI Q60 Red Alpha one piece carbon driveshaft version is manufactured using a new carbon fiber weave that was tested to 6800 lbs of torque! The main difference between the carbon and aluminum driveshaft is that the 3.25″ diameter carbon fiber tube is more torsional than aluminum, therefore it can twist more under load resulting in a smoother transfer of power at launch or between shifts. Aluminum is already much more torsional than steel, (about 15° under load vs about 5° for steel) but carbon fiber can go upwards of 30° to 35°. Carbon fiber is also typically quieter and there is typically a 2-3lb difference in weight which will help acceleration as well. It will be a significant upgrade over the stock 2-piece driveshaft. The one piece drive shafts will make more noise than their stock two piece counterparts "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fedaykin Posted August 28, 2018 Share Posted August 28, 2018 Wow it's only $1,500, cheap! I suppose if you're drag racing you'd want that kind of strength. Link to comment Share on other sites More sharing options...
fredrik94087 Posted August 31, 2018 Author Share Posted August 31, 2018 Wow it's only $1,500, cheap! I suppose if you're drag racing you'd want that kind of strength. Love it...are you trying to troll me? ROTFL "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted August 31, 2018 Author Share Posted August 31, 2018 I had my car in service to install Lo Jack. Since I had a Q50 3.0t RWD, I did a quick video of that and another of my car for comparison. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted August 31, 2018 Author Share Posted August 31, 2018 i love the work that went into comparing several intakes to the factory intake. dont miss minute 7:30 for some insight. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 2, 2018 Author Share Posted September 2, 2018 some interesting information... wife was not pleased. https://parts.infinitiusa.com/infinitiparts/?siteid=15&action=motorSportsLanding&catalogid=2371 sold and backed by infiniti "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fedaykin Posted September 3, 2018 Share Posted September 3, 2018 Love it...are you trying to troll me? ROTFL Nah I was thinking carbon fibre shafts would be $3k+ Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 3, 2018 Author Share Posted September 3, 2018 a custom one off may cost you a small fortune but you would be hard pressed to find one that expensive. none are made for your car, but if you want one, maybe these guys can do it. http://www.monstertransmission.com/Carbon-Fiber-Driveshaft-Custom-Built_p_6128.html?gclid=EAIaIQobChMIiuiXxZSf3QIVjfhkCh2G9Qc8EAMYAiAAEgKIDfD_BwE#.W41U2ullCeM "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Rhitter Posted September 5, 2018 Share Posted September 5, 2018 *Not yet approved for CARB - on the intake The heat exchanger seems nice. Does the intake do anything if you are "in hopes of limited mods"? My OBXT build Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 5, 2018 Author Share Posted September 5, 2018 I will stick with the assessment from youtube where the factory intake made more power than 4 other intakes on an otherwise "stock" car. Just an Ecutek tune may...just may come in time. Still can't justify another 30whp at 5250rpm and same power at 6000rpm and above. There is plenty of power down low. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Golferdude1087 Posted September 6, 2018 Share Posted September 6, 2018 (edited) I will stick with the assessment from youtube where the factory intake made more power than 4 other intakes on an otherwise "stock" car. Just an Ecutek tune may...just may come in time. Still can't justify another 30whp at 5250rpm and same power at 6000rpm and above. There is plenty of power down low. tunes get way more power than that. Im looking on facebook right on for R/T tuning at a q50 red sport with AMS iDP, Intake and cat back and its getting 427/462 at 17psi. thats 40/130 increase on only 17 psi (3 above factory)...the cars got huge potential some interesting information... wife was not pleased. https://parts.infinitiusa.com/infinitiparts/?siteid=15&action=motorSportsLanding&catalogid=2371 sold and backed by infiniti So uhm...this is good, and there will be more..wait for the tune from AMS that supports all that stuff..that'll get you roughly 500/500 at the wheels. Putting those on without a tune is the equivalent of adding raptors to your h6 and still running an 87 stock map Edited September 6, 2018 by Golferdude1087 Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 15, 2018 Author Share Posted September 15, 2018 2018 Nismo Z wheels added. Factory wheel specs: 19x9 +47 ~ 30# Nismo Z wheel specs: 19x9.5 +40 ~ 20# Running Michelin Pilot Sport 4s 265/35/19 on 9" wheel was not great. grip was only slightly better than factory run-flat 245/40/19. With the added 1/2", the tire has a very slight stretch. Response is improved and there is more grip. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 16, 2018 Author Share Posted September 16, 2018 A few photo comparisons. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 16, 2018 Author Share Posted September 16, 2018 Before and After videos: "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Rhitter Posted September 17, 2018 Share Posted September 17, 2018 Yep, them look like wheels My OBXT build Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 17, 2018 Author Share Posted September 17, 2018 almost a 50# drop in rotatiinal mass makes a noticeable difference (wheels and tires) the 2 piece rotors will not be very noticeable, but another 30# savings. and, yours truly is on a diet as well. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 17, 2018 Author Share Posted September 17, 2018 i still cant get over how good the nismo wheels look on the red sport "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
baconbits Posted September 20, 2018 Share Posted September 20, 2018 If I didn't have a wedding to pay for, I'd be seriously shopping a 3.0t Sport. I don't have the pocket for the RS but damn, I can want one. I'll probably end up in a 2013 M-Sport 535xdrive in the next week or so, which means I'll have to live my Q50 life vicariously through you. Get a tune, skinnies, slicks, and a couple bolt ons and run a 10.2 1/4 like AMS. Bolt ons don't count as mods, right? Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 21, 2018 Author Share Posted September 21, 2018 I already added a few bolt ons... or I should say snap ons. Nissan graphite color center caps to finish the look. I got pricing from Z1 motorsports for GTR Nismo seats and it was obscene. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 22, 2018 Author Share Posted September 22, 2018 I managed to remove 7# of sprung weight from the driver. 197 3 weeks ago. 190 today. More to come from car and driver. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted October 3, 2018 Author Share Posted October 3, 2018 Put it on the same dyno my wrx was on. 357whp/362wtq IIRC. Car is rated 400hp and 350 tq. That should be about 415 hp at the crank and not sure how much torque. The motor is definitely underrated. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted October 4, 2018 Author Share Posted October 4, 2018 first post updated "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
