Beamercub Posted August 3, 2018 Share Posted August 3, 2018 I have a 2015 3.6R.. While driving today I felt what I thought to be a blip or slight misfire... Then it happened again... And then was happening every 30 seconds.. I turned off the ac and it stopped for a few mins... Then it got worse.. Was chugging as I tried accelerating and the check engine light started flashing. Oddly the eyesight and traction turned themselves off as well? At a stop light I turned it off and back on.. Same thing.. I had no choice but to drive it about a mile home. Along the way it would act up. Then it would be fine.. no lights flashing? Could it be bad gas? Nothing like this has ever happened before.. I'm kinda freaking out. Any insight? I don't have a code puller.. Gonna get one tomorrow and or have it towed to Subaru. I'm just thankful it happened near home. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted August 3, 2018 Share Posted August 3, 2018 Its misfiring. Whats the mileage and have you ever replaced the spark plugs? Link to comment Share on other sites More sharing options...
Beamercub Posted August 3, 2018 Author Share Posted August 3, 2018 Thanks for the reply. Mileage is 43,400. No plugs haven't been replaced.... Any thoughts on bad gas? And being so hot/humid past few days? Link to comment Share on other sites More sharing options...
chowser51 Posted August 3, 2018 Share Posted August 3, 2018 When was the last time you changed your filter? Cleaned the maf sensor? Start cheap. I had issues on hot/humid days with rough starts. Cleaned maf sensor and that seemed to have fixed the problem. No more issues. Just passed 70k recently. Need to change my plugs soon. Link to comment Share on other sites More sharing options...
ehsnils Posted August 3, 2018 Share Posted August 3, 2018 When replacing plugs also clean the ignition coils using brake cleaner. Don't use WD40 since it leaves an oil residue that attracts dirt and can lead to misfires again soon. And check/adjust the plug gaps before installing them - sometimes the stock plugs can be "off" from what they should be. And use the NGK plugs designated for the vehicle - they are known to work. Other brands aren't as reliable in my experience. Whenever there's a detected fault it's automatically turning off all non-essential functions like eyesight and traction control so that's normal. After filter change and MAF cleaning also check for loose hoses and the PCV valve as well. Also get a code reader - it's going to help a lot since as soon as the problem manifests itself then read the code. You can of course go to some places like Autozone to get the code but that would not always be an option and some codes are elusive. When you know the codes it's time to step it up and check ignition coils and injectors. Link to comment Share on other sites More sharing options...
Beamercub Posted August 3, 2018 Author Share Posted August 3, 2018 I'm guessing the things possibly needed aren't covered under warranty... I have the gold plus warranty... Link to comment Share on other sites More sharing options...
ehsnils Posted August 3, 2018 Share Posted August 3, 2018 I'm guessing the things possibly needed aren't covered under warranty... I have the gold plus warranty... You don't know until you have had that checked - check with dealer and if the dealer denies it then SOA. Link to comment Share on other sites More sharing options...
securityguy Posted August 3, 2018 Share Posted August 3, 2018 When the check engine light comes on, it does turn on several other indicators and the eyesight is among them. Link to comment Share on other sites More sharing options...
Beamercub Posted August 3, 2018 Author Share Posted August 3, 2018 Translated it means Cylinder 5 is misfiring.. And parts recommended to replace are ignition coil and spark plugs. Spark plugs aren't covered, maybe the coil is? Is this something I should attempt or just have it towed, yet again to the dealership. .? Link to comment Share on other sites More sharing options...
Grnlantern1 Posted August 4, 2018 Share Posted August 4, 2018 Translated it means Cylinder 5 is misfiring.. And parts recommended to replace are ignition coil and spark plugs. Spark plugs aren't covered, maybe the coil is? Is this something I should attempt or just have it towed, yet again to the dealership. .?Did you try the Fuel Cap make sure it was on tight and yes possibly bad gas if its Hot you could be vapor locking. Maybe try some Seafoam In the tank before taking it to the dealer.. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
Tehnation Posted August 4, 2018 Share Posted August 4, 2018 dealership... again....??? Has someone recently worked on your car? If so I would just check to make sure all your wiring and connections are secure. Wiggle some wires while its running to see if anything changes. If they aren't covered by warranty..... i doubt they are, swap the coil with another one and see if the problem follows or stays, if it stays I would remove and inspect spark plug, if it looks fouled then replace. If the code moves to a different cylinder I would replace the coil. If the spark plug is fine, and the problem is the same with a swapped coil, I would then swap injectors..... if you get what i'm saying! You can pretty much diagnose without buying anything!! I learned the hard way. It pays to just do some simple troubleshooting first before running to the dealer etc. Unless you don't know how to work on a car, then yea go to the stealership! Link to comment Share on other sites More sharing options...
Tehnation Posted August 4, 2018 Share Posted August 4, 2018 You can get a cheap code reader for like 15 bucks off amazon, or a bluetooth obd2 reader and torque phone app(free one does cel codes). I would start with that first! Link to comment Share on other sites More sharing options...
securityguy Posted August 4, 2018 Share Posted August 4, 2018 Translated it means Cylinder 5 is misfiring.. And parts recommended to replace are ignition coil and spark plugs. Spark plugs aren't covered, maybe the coil is? Is this something I should attempt or just have it towed, yet again to the dealership. .? How did you know it is cylinder 5? Link to comment Share on other sites More sharing options...
Tehnation Posted August 4, 2018 Share Posted August 4, 2018 look at the title of post #9! The op is new and probably doesn't know most people don't look at reply titles, and he should have put that info in the post message box not title Link to comment Share on other sites More sharing options...
ehsnils Posted August 4, 2018 Share Posted August 4, 2018 Translated it means Cylinder 5 is misfiring.. And parts recommended to replace are ignition coil and spark plugs. Spark plugs aren't covered, maybe the coil is? Is this something I should attempt or just have it towed, yet again to the dealership. .? Spark plugs don't usually randomly dies unless they are exposed to something like an oil leak. Of course it may still happen but then they aren't that expensive to be a headache from a cost perspective. It's more likely that the coil or injector is the cause in your case. But a compression test is of course worth to perform when you are messing around in that area anyway - it takes some work but won't hurt anything. Link to comment Share on other sites More sharing options...
Beamercub Posted August 5, 2018 Author Share Posted August 5, 2018 Ok. I'm gonna attempt it on my own. Anyone know where I could get some type of repair guide? Online? I don't even know which cylinder is 5 or 4.. and there are six of them lol. Another clue is.. I drove thru a horrible rain storm last week... that's when I felt the first subtle hiccup... and it's been crazy humid here for awhile Link to comment Share on other sites More sharing options...
Jdog81 Posted August 5, 2018 Share Posted August 5, 2018 you could have gotten water in between the coil and the spark plug if you went through deep water. it thats the case you'll just have to blow the water out and you'll be good. Link to comment Share on other sites More sharing options...
Beamercub Posted August 5, 2018 Author Share Posted August 5, 2018 Blow the water out... hmmmm. Like with duster? Or brake clean? My first obstacle is getting the engine cover off, clueless as to how..... and the cylinder numbers... Link to comment Share on other sites More sharing options...
MrCobbs Posted August 5, 2018 Share Posted August 5, 2018 Lift the rear of the cover then slide it forward. Everything else I sent in a PM. Good luck! Blow the water out... hmmmm. Like with duster? Or brake clean? My first obstacle is getting the engine cover off, clueless as to how..... and the cylinder numbers... Link to comment Share on other sites More sharing options...
Beamercub Posted August 5, 2018 Author Share Posted August 5, 2018 Did you try the Fuel Cap make sure it was on tight and yes possibly bad gas if its Hot you could be vapor locking. Maybe try some Seafoam In the tank before taking it to the dealer.. Sent from my SM-G965U using Tapatalk Sea foam really? I dunno about that... Link to comment Share on other sites More sharing options...
Jdog81 Posted August 5, 2018 Share Posted August 5, 2018 compressed air Link to comment Share on other sites More sharing options...
legacyboy1991 Posted August 5, 2018 Share Posted August 5, 2018 Honestly, if you have the warranty it's better to just let the dealer habdle, repair, and document the issue. That way if there's a catastrophic failure of the engine, you'd be covered by letting them repair this. Link to comment Share on other sites More sharing options...
tornichoe Posted August 6, 2018 Share Posted August 6, 2018 Less likely it's within the 3yr/36, but if you are anywhere in the border, take it to the dealer rightaway and have the issue documented so its recorded to have happened in the warranty period. Link to comment Share on other sites More sharing options...
