YeuEmMaiMai Posted February 26, 2018 Author Share Posted February 26, 2018 I do not think so as this is the second year in a row where they bled the system and heat was fine for the rest of the winter... question is, where is this car sucking air into the cooling system from? Link to comment Share on other sites More sharing options...
02LGTSNJ Posted February 26, 2018 Share Posted February 26, 2018 Could be something as simple as a new rad cap. I've had noticeable drops in fuel economy too when city driving in the dead of winter, I dont think thats too much to worry about. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 27, 2018 Author Share Posted February 27, 2018 going from an average of 30 mpg down to 21 is something to be concerned about.. even my old ass 2003 Subaru gives me 24 on the same route... you mean to tell me a 11 year newer car gets worse gas mileage despite only having 1/4 of the mileage... seriously... Link to comment Share on other sites More sharing options...
laz Posted February 27, 2018 Share Posted February 27, 2018 My 2005 Impreza 2.5rs gives me exactly the same MPG’s as my 2017 Legacy during city/hwy driving. All highway the Legacy wins over the Impreza. --- Link to comment Share on other sites More sharing options...
nads Posted February 27, 2018 Share Posted February 27, 2018 I do not think so as this is the second year in a row where they bled the system and heat was fine for the rest of the winter... question is, where is this car sucking air into the cooling system from? Possible blow head gasket? Ever overflow on coolant? Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 27, 2018 Author Share Posted February 27, 2018 well this morning was fun... go out to car and it is dead with only security light blinking like mad... manually open door and I hear relays clicking under dash.... so I pull out my Rockford Pocket Power Jump Starter, slap it on the battery and hit the boost button.. Car gets a shot of juice into battery and comes to life...starts up... now I am going to have to order a battery as once the go dead, getting them back is not really long term solution. Dekka AGM battery here I come... as for blown head gasket, I do not think so as the car would exhibit other symptoms like coolant in exhaust or crap on the plugs, or external leak and coolant level would not be low with no evidence of it all over the engine bay... Link to comment Share on other sites More sharing options...
dgoodhue Posted February 27, 2018 Share Posted February 27, 2018 as for blown head gasket, I do not think so as the car would exhibit other symptoms like coolant in exhaust or crap on the plugs, or external leak and coolant level would not be low with no evidence of it all over the engine bay... Not necessarily if the head gasket has a small leak from the combustion change to coolant. I have seen a few cars with no other obvious symptoms other than air in the coolant system and slowing losing coolant. Test the anti-freeze mixture and pressurize the coolant system. (I think some here mentioned sometimes Subaru coolant conditioner has false positives on the coolant test) The coolant has to be going somewhere. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 27, 2018 Author Share Posted February 27, 2018 been there done that 3x, negative on the results Link to comment Share on other sites More sharing options...
FLlegacy Posted February 27, 2018 Share Posted February 27, 2018 I have read on the Tribeca forum the H6 has passed the test strip test and then later found to have a headgasket leak. So take that for what its worth. I think you are going through a lot of BS. Link to comment Share on other sites More sharing options...
cww516 Posted February 27, 2018 Share Posted February 27, 2018 I actually had that same issue with my old Grand Am- it would run fine under about 45 MPH, but anything above that was enough to push a little exhaust into the coolant, which collected at the coolant temp sensor and immediately buried the needle on the temperature gauge and dropped the car into limp mode. This was a 15-year-old car, and I was also starting to notice the transmission slipping on the 2-3 shift after it was warm, so I dumped a bottle of stop leak in there and traded it in. I didn't see any evidence of coolant in the exhaust, just the air pocket showing up under higher load. I think I had a little coolant dribble out of the overflow tube, but that may have been because the system was full when I added the stop leak and just ran out of space. Mine did test positive for hydrocarbons in the coolant, but from what I read, those tests can be a little unreliable. Head gasket would suck, but I wouldn't rule it out. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 27, 2018 Author Share Posted February 27, 2018 it is not a head gasket issue. a blown head gasket would have absolutely nothing to do with mass air flow over reporting air going into the engine. just to recap On the days the car is running good. MAF shows 2.3 to about 2.7 at idle... on the days it is running like crap MAF shows nearly double that. when car idles like crap MAF is upper 4s and fuel trim jumps to 35%.... Link to comment Share on other sites More sharing options...
nads Posted February 27, 2018 Share Posted February 27, 2018 Things parallel to the running bad are cold start and cold driving until warmed up? Or is it intermittent, as in hot or cold it just comes and goes? Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 28, 2018 Author Share Posted February 28, 2018 today it was warm outside and I saw mileage climb above 30....it was low 20's last week on same route... This morning when it was cold again, car is not acting right so I am going to stick with assessment that MAF is broken when cold. Temp on the way to work was a nice 19F... yesterday it was a nice 50F Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted March 4, 2018 Author Share Posted March 4, 2018 resolution: New MAF installed and readings are normal at 2.5-2.7grams a second...car no longer hesitates or smells like gas... Link to comment Share on other sites More sharing options...
laz Posted March 4, 2018 Share Posted March 4, 2018 Will you bring this up with the dealership? --- Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted March 4, 2018 Author Share Posted March 4, 2018 I am bringing it up with them and SOA... Link to comment Share on other sites More sharing options...
laz Posted March 4, 2018 Share Posted March 4, 2018 You just have gotten a part built in a Friday afternoon. If. It then keep an eye out on what may have damaged the part. Good luck! --- Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted March 6, 2018 Author Share Posted March 6, 2018 Well we can consider the issue resolved from the car is now running properly pov. I wrote SOA with my concerns and their overall lack of concern regarding my initial complaint. I also asked them to reimburse me for the second dealer diag fee and the cost of the replacement DENSO OEM SUBARU sensor. for a total of $244. I personally talked to the Service Manager of the second dealer while I was in for an oil change on my 2003 Subaru and I e-mailed the first service manager detailing the issues, lack of understanding by the mechanic, and the general inconvenience of going there multiple times. Link to comment Share on other sites More sharing options...
raider600 Posted March 6, 2018 Share Posted March 6, 2018 Glad its fixed. That is a lot of crap to go through. I would be very disappointed in the dealer. Link to comment Share on other sites More sharing options...
nads Posted March 7, 2018 Share Posted March 7, 2018 Glad its fixed and you didn't give up. Sad to see what it entailed but I'm not surprised. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted March 7, 2018 Author Share Posted March 7, 2018 I know it sounds like I am mad when I post in here but that is not the case. I never yelled at the Subaru Dealer nor Subaru of America. I took my time to explain it to both of them and stated that I was none to pleased that I had to fix my own car. Link to comment Share on other sites More sharing options...
Flamario Posted March 8, 2018 Share Posted March 8, 2018 Here I am feeling like a jerk by having them write me a 700$ check for paint damage. You've been to hell and back with them.. glad to see this story has somewhat of a resolution. I'm curious as to what SOA will say back. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted March 8, 2018 Author Share Posted March 8, 2018 sent off the reply to the initial complaint on Tuesday at 6:30am....waiting to hear back Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted March 8, 2018 Author Share Posted March 8, 2018 SOA answered back and they are investigating the issue.. hopefully I'll see at least the refund of the diagnostic fee from second dealer and if I am really lucky, I will see the sensor reimbursement as well. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted March 22, 2018 Author Share Posted March 22, 2018 Final update: SOA got back to me and agreed to reimburse me for the diag fee paid to second dealer and the cost of the DENSO OEM sensor... Thank you SOA for standing up and doing what is right. Car is running about 25-26mpg now so it is a confirmed fix Link to comment Share on other sites More sharing options...
