SBT Posted January 16, 2018 Share Posted January 16, 2018 (edited) Continuing our server optimization. Previous "What did you do to your 2nd Generation Subaru today - V2 is found in the Archive Edited January 26, 2018 by SBT Unlocked thread - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
doublechaz Posted January 27, 2018 Share Posted January 27, 2018 Lately when I park the car after getting up to temp it sometimes makes a two inch coolant wet spot. I haven't been able to find where it is coming from until last night. I had to lay under there until it finally decided to drip. Looks like it's coming from the water pump shaft seal. Well, I was already going to get under there soonish to check out the oil pump. At least this car nearly never gives me trouble. The Plymouth OTOH... Link to comment Share on other sites More sharing options...
Setnev Posted January 30, 2018 Share Posted January 30, 2018 Chaz, true that. OTOH, if you come across a cheap Subaru let me know. I just sold our 3rd gen LL Bean and I need another Subaru. I'm already going through withdrawals. Link to comment Share on other sites More sharing options...
doublechaz Posted January 30, 2018 Share Posted January 30, 2018 There is a Forrester in u-pickit. Engine is gone, but the trans is still there. I didn't notice if it was auto or manual. I don't know what year either. I didn't think of it at the time, but just now when I saw your post. There was some kind of Subaru for sale at Hastings a while back. Not sure if it's still there, or what it was. I have a co-worker who points out all the Subies available in AZ to me, so if I come up with something... Link to comment Share on other sites More sharing options...
Setnev Posted January 30, 2018 Share Posted January 30, 2018 There is a Forrester in u-pickit. Engine is gone, but the trans is still there. I didn't notice if it was auto or manual. I don't know what year either. I didn't think of it at the time, but just now when I saw your post. There was some kind of Subaru for sale at Hastings a while back. Not sure if it's still there, or what it was. I have a co-worker who points out all the Subies available in AZ to me, so if I come up with something... I saw the Forester. It was an auto. I ganked the seat heater switches out of it for spares. The Subie at Hastings was a maroon one and he wants $2800 for it. It has only 106,000 miles, so he'll get it too. Keep me posted. Link to comment Share on other sites More sharing options...
monkeyposeur Posted February 2, 2018 Share Posted February 2, 2018 Replaced my center diff and transfer gear bearings. Took about 9 hours. Link to comment Share on other sites More sharing options...
twisty Posted February 5, 2018 Share Posted February 5, 2018 took one of the outbacks through emissions over the weekend. figured out that when you clear the codes in the 96 ECU there is no "NOT READY" code set. i have a bad wire somewhere in the harness for the rear O2 sensor, replacing the sensor didnt fix the P0136 code. i cleared the code, drove to emissions and it passed with no issues within 5 miles of driving. Link to comment Share on other sites More sharing options...
Setnev Posted February 9, 2018 Share Posted February 9, 2018 took one of the outbacks through emissions over the weekend. figured out that when you clear the codes in the 96 ECU there is no "NOT READY" code set. i have a bad wire somewhere in the harness for the rear O2 sensor, replacing the sensor didnt fix the P0136 code. i cleared the code, drove to emissions and it passed with no issues within 5 miles of driving. That is awesome! I wonder if 95 is like that too, not that I have to worry about emissions testing here in Prescott Link to comment Share on other sites More sharing options...
twisty Posted February 12, 2018 Share Posted February 12, 2018 doesnt matter for the 95, anything pre-96 gets sniffed. i tried to get them to put it on the 96 obd2 test but they cant Link to comment Share on other sites More sharing options...
Elysian Posted February 20, 2018 Share Posted February 20, 2018 Sold my Legacy last night, after the trans blew up I just couldn't bear to fix it one more time. Was able to sell it as-is to a kid who needed to replace the motor in his 07 Impreza that had rod knock. Should be just about a direct drop in since I put the Phase II SOHC heads on it. With that, I doubt I'll ever buy a Subaru again, so won't be around here anymore. Good luck everyone. Link to comment Share on other sites More sharing options...
Thor294 Posted March 1, 2018 Share Posted March 1, 2018 Removed tbelt and cams from my donor 2.2L. Cams on the way to deltacam for a regrind. Link to comment Share on other sites More sharing options...
twisty Posted March 1, 2018 Share Posted March 1, 2018 (edited) http://i63.tinypic.com/2w30z03.jpg smokey is going under the knife, his engine will be transplanted into the new outback sport for now. got the engine almost ready to pull, probably going to switch them out this weekend if everything works out right. Edited March 1, 2018 by twisty Link to comment Share on other sites More sharing options...
SW95GL Posted March 3, 2018 Share Posted March 3, 2018 Ok so i have this really wierd issue, it might be the light module just not sure. So when i have low beams on the park lights are not there, not even when just in park. They ONLY come on when high beams are turned on, so i got parks with high beams but that is the only time they do... So might be the module or any other tips? Link to comment Share on other sites More sharing options...
doublechaz Posted March 3, 2018 Share Posted March 3, 2018 Look at the grounds all through the system. Do you have a Service Manual? Link to comment Share on other sites More sharing options...
SW95GL Posted March 4, 2018 Share Posted March 4, 2018 Look at the grounds all through the system. Do you have a Service Manual?I do have the service manual yes, ill check the grounds Sent from my SM-G955F using Tapatalk Link to comment Share on other sites More sharing options...
doublechaz Posted March 5, 2018 Share Posted March 5, 2018 Failed to do my water pump job again this weekend. Did get some other things done, though. Link to comment Share on other sites More sharing options...
Thor294 Posted March 6, 2018 Share Posted March 6, 2018 put all LED bulbs in the interior, cleaned rear glass cause it was dirty af. Tinting the windows thursday, and also noticed my rear wiper stopped working zzzzz Link to comment Share on other sites More sharing options...
doublechaz Posted March 6, 2018 Share Posted March 6, 2018 Looked at mine parked in the back yard slowly bleeding to death. Shouldn't be long now until I get time to get her back to 10.0. Link to comment Share on other sites More sharing options...
Thor294 Posted March 9, 2018 Share Posted March 9, 2018 Link to comment Share on other sites More sharing options...
Le Gabbys Posted March 22, 2018 Share Posted March 22, 2018 Junked it [emoji20][emoji45][emoji22] Sent from my Moto E (4) Plus using Tapatalk Link to comment Share on other sites More sharing options...
doublechaz Posted March 23, 2018 Share Posted March 23, 2018 Unless it keeps raining every weekend... Link to comment Share on other sites More sharing options...
Setnev Posted March 23, 2018 Share Posted March 23, 2018 Looked at mine parked in the back yard slowly bleeding to death. Shouldn't be long now until I get time to get her back to 10.0. I know how you feel. It's been a month since I've daily driven my car. It is in desperate need of new tires and has developed a nasty oil leak. It leaked out about 2 quarts of oil onto my driveway in the last 3 weeks. It's not coming from the usual places, like valve cover and oil pan. It appears to be coming from between the engine and transmission. On the other hand, the strange noises inside my transmission on the Forester have completely disappeared so I have been driving that for the last month. Link to comment Share on other sites More sharing options...
doublechaz Posted March 23, 2018 Share Posted March 23, 2018 Is that the oil separator plate? I found out and replaced mine with a metal cover before it cracked and spewed. I did get a lot of something out of that area just before I swapped trans because of a bad input shaft bearing. I think it was the trans that leaked, but I did the rear main while I was in there. Link to comment Share on other sites More sharing options...
SBT Posted March 23, 2018 Author Share Posted March 23, 2018 ^If that much between the trans and the block, it's likely the oil separator cover (vapor plate), rear main, or a combination of both. These covers were a plastic/resin in stock form and need to be replaced with the upgraded metal one. P/N info is found here http://static.opposedforces.com/epc_img/366494900440.png - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
danr Posted March 23, 2018 Share Posted March 23, 2018 bought a 1995 subaru legacy L. Finally back into a subaru after selling my 1997 impreza brighton when i was 21. So happy to be back in the 90's subaru glory. https://photos.app.goo.gl/8v9I3BeD4eLgUNmg2 Link to comment Share on other sites More sharing options...
