Gabo Posted August 17, 2017 Share Posted August 17, 2017 I'll keep this short and sweet. If anyone has a dyno plot for an unmodified VF52 please feel free to share. Vehicle Specs: 2007 Spec B Forged SB (9.0:1 Compression) SoCal Porting Stage 3 VF52 Ported ETS FMIC KSTech 73mm Intake with heat shield TGV deletes with phenolic spacers AVO Inlet Killer B Holy Header w/ uppipe Grimspeed Catted Divorced Downpipe Invidia Q300 Grimspeed 3 port EBCS DW 1300cc Injectors DW300 Southbend Stage 2 Endurance Clutch STI OEM SM Flywheel Delicious Tuning Flex Fuel Kit with custom dyno tune from Bill himself Accessport V3 Bill setup the SI-Drive as a boost controller. (I) is low boost (S) is 18 psi (Medium Boost) (S#) 24 psi. (High Boost) When I first drove the car I left it on (S) and did a quick pull from 3,000 rpm. The car didn't feel laggy at all, and immediately began to pull. The car on (S) is fast enough to earn me a felony, so believe it or not I have yet to try (S#). I see if I can build the courage to do so today Cliff notes; 91 Oct results 269 WHP (5300 rpm) 288 WTQ (4300 rpm) Full Boost at (4300 rpm , 21 psi) E60 Results 355 WHP (5300 rpm) 370 WTQ (4000 rpm) Full Boost (3900 rpm, 24 psi) The rpm's are an approximation because of the scaling on the dyno printouts. I was initially concerned with how late the SoCal Porting VF52 was spooling in comparison to a stock VF52, but on the street the car pulls strong from 3000 rpm all the way to redline. If I had gone to 1/2'' headstuds we would have pushed the turbo further. Mike and Bill both did not want to risk lifting a head with the standard ARP headstuds. I of course agreed, and yes Mike does refer to his dyno as a heart breaker. No complaints on my end though and I'm extremely happy with the results. Update 9/25/2017 Finally drove the car on 91 octane, and there are a few things to note. As expected the car makes less power, no surprise there. What is surprising is the fact the car is quieter (exhaust sound) and definitely not as smooth as E85. I really can't describe what I mean by less smooth, for all intents and purposes unless you've driven the car on E85 it isn't something you'll notice from the passenger seat. Acceleration on 91 octane is nowhere near as aggressive dare I say violent as on E85. I guess in a way I should be glad the differences between E85 and 91 octane are so drastic, otherwise I suspect I would get use to E85 power and want more. I should also note the difference though drastic specially when going full throttle doesn't necessarily translate into an otherwise boring driving experience while on 91 octane. Link to comment Share on other sites More sharing options...
Rhitter Posted August 17, 2017 Share Posted August 17, 2017 That flex fuel is some good stuff. Looks like fun. My OBXT build Link to comment Share on other sites More sharing options...
gkinslow Posted August 17, 2017 Share Posted August 17, 2017 No way I could resist S#. Do it immediately and report back. Glad you are happy so far. Link to comment Share on other sites More sharing options...
Gabo Posted August 17, 2017 Author Share Posted August 17, 2017 No way I could resist S#. Do it immediately and report back. Glad you are happy so far. I'll keep you posted. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 17, 2017 Moderators Share Posted August 17, 2017 Regarding the 91 numbers--is commiefornia pump gas just that bad? Those are like stage 2 numbers, no? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
rebourne Posted August 17, 2017 Share Posted August 17, 2017 I started writing why E60 and then I figured it out... You run the 91 tank as low as you can, then fill with E85 and you'll end up with E60ish. Will it scale up to make more power when running E85? I'd want to figure out how to get a full E85 tune, and come back again with a tank full of just 91. The 91 numbers look, especially considering Mustang dyno. The E85/60 numbers are probably over 400 ftlbs on a dynojet. You should probably add what clutch you have to your parts list up there ;-) My stock VF52 with Invidia 1.5 scroll single piece header hits full boost (23 psi on E85) at 3650 ish for comparison. But then it tapers to 18 psi. Your Socal VF52 is holding 23 psi to redline!!!! pic thread build thread Link to comment Share on other sites More sharing options...
rebourne Posted August 17, 2017 Share Posted August 17, 2017 Regarding the 91 numbers--is commiefornia pump gas just that bad? Those are like stage 2 numbers, no? Infamous Mike always refers to Bill's dyno as a heart breaker. pic thread build thread Link to comment Share on other sites More sharing options...
gkinslow Posted August 17, 2017 Share Posted August 17, 2017 290whp would still be stage 2 numbers Link to comment Share on other sites More sharing options...
Gabo Posted August 17, 2017 Author Share Posted August 17, 2017 Regarding the 91 numbers--is commiefornia pump gas just that bad? Those are like stage 2 numbers, no? Commiefornia 91 oct is that bad, notice how he also keep it at 21 psi as oppose to 23. Take a quick look at this Link to comment Share on other sites More sharing options...
Gabo Posted August 17, 2017 Author Share Posted August 17, 2017 I started writing why E60 and then I figured it out... You run the 91 tank as low as you can, then fill with E85 and you'll end up with E60ish. Will it scale up to make more power when running E85? I'd want to figure out how to get a full E85 tune, and come back again with a tank full of just 91. The 91 numbers look, especially considering Mustang dyno. The E85/60 numbers are probably over 400 ftlbs on a dynojet. You should probably add what clutch you have to your parts list up there ;-) My stock VF52 with Invidia 1.5 scroll single piece header hits full boost (23 psi on E85) at 3650 ish for comparison. But then it tapers to 18 psi. Your Socal VF52 is holding 23 psi to redline!!!! Infamous Mike always refers to Bill's dyno as a heart breaker. I'm honestly not sure how Bill sets it up as far as E85 vs E60, but that would be a good question to ask him when I see him next. Compared to your setup I lost some spool but you are correct it holds all the way to redline. On another note if I had gone to 1/2'' headstuds we would have pushed the turbo further. Mike and Bill both did not want to risk lifting a head with the standard ARP headstuds. I of course agreed, and yes Mike does refer to his dyno as a heart breaker. Link to comment Share on other sites More sharing options...
WRX USA Posted August 17, 2017 Share Posted August 17, 2017 Wow, I did 288/301 on a mustang dyno with a ported JMP VF52 with Cali 91: http://legacygt.com/forums/showpost.php?p=5552910&postcount=183 Link to comment Share on other sites More sharing options...
Gabo Posted August 17, 2017 Author Share Posted August 17, 2017 No way I could resist S#. Do it immediately and report back. Glad you are happy so far. Went and filled up my half tank of E60 and are now sitting on E72. Still can't bring myself to do (S#), (S) already scared the crap out of me lol. I'll start building courage now and maybe by the time I head home I'll hit (S#) :spin: Link to comment Share on other sites More sharing options...
Gabo Posted August 17, 2017 Author Share Posted August 17, 2017 Wow, I did 288/301 on a mustang dyno with a ported JMP VF52 with Cali 91: http://legacygt.com/forums/showpost.php?p=5552910&postcount=183 Our VF52's are not identical so I don't know if that has anything to do with it. Regardless those are great numbers. Link to comment Share on other sites More sharing options...
gkinslow Posted August 17, 2017 Share Posted August 17, 2017 Send it. Link to comment Share on other sites More sharing options...
hadvw Posted August 17, 2017 Share Posted August 17, 2017 This is so tempting.. I have an E85 station just around the corner.. Link to comment Share on other sites More sharing options...
Rhitter Posted August 17, 2017 Share Posted August 17, 2017 This is so tempting.. I have an E85 station just around the corner.. and you have the ClimberD valvebody mod right? That means do it. FlexFuel time. My OBXT build Link to comment Share on other sites More sharing options...
hadvw Posted August 17, 2017 Share Posted August 17, 2017 and you have the ClimberD valvebody mod right? That means do it. FlexFuel time. I do. Still need to find someone local doing the tunes, or drive down to LA.. Link to comment Share on other sites More sharing options...
Gabo Posted August 17, 2017 Author Share Posted August 17, 2017 This is so tempting.. I have an E85 station just around the corner.. I read and read about the advantages of E85 and now that I did it I have to say the results are beyond anything I imagined. The car is 100% transformed and I haven't even really stretched the Spec B legs. I feel like I don't know the car. Like you it also helps I have an E85 station just around the corner from where I work, plus two additional stations on my way home. Link to comment Share on other sites More sharing options...
Rhitter Posted August 17, 2017 Share Posted August 17, 2017 I do. Still need to find someone local doing the tunes, or drive down to LA.. Bill (delicious tuning) tunes up here occasionally I think. At least according to his website. My OBXT build Link to comment Share on other sites More sharing options...
gkinslow Posted August 17, 2017 Share Posted August 17, 2017 I'm going strictly e85. Flex fuel isn't completely necessary. I will say that I'm curious to see the long term results of the DT kit on this platform. Sure makes it easier to purchase knowing that Bill was going to tune it himself. Link to comment Share on other sites More sharing options...
Gabo Posted August 17, 2017 Author Share Posted August 17, 2017 I'm going strictly e85. Flex fuel isn't completely necessary. I will say that I'm curious to see the long term results of the DT kit on this platform. Sure makes it easier to purchase knowing that Bill was going to tune it himself. I want the flexibility of not having to switch maps or plan out my route to stay on E85. I will drive the car at least 5 times a week so I will definitely test reliability. Link to comment Share on other sites More sharing options...
FJuan Posted August 17, 2017 Share Posted August 17, 2017 Send it. [ame=http://www.youtube.com/watch?v=jT3ZWLOD4hk]I'm still gonna send it / Louisiana truck running from police - YouTube[/ame] My wife's balls are delicious. Link to comment Share on other sites More sharing options...
WRX USA Posted August 17, 2017 Share Posted August 17, 2017 Bill (delicious tuning) tunes up here occasionally I think. At least according to his website. https://www.mann-engineering.com/index.php/delicious_tuning Link to comment Share on other sites More sharing options...
MTBwrench Posted August 17, 2017 Share Posted August 17, 2017 Gabo, looks like you're getting great results on ethanol. The Killer B header is probably a good contributor to that! This is all making me want to put all my racecar parts to use with E85. I've still never been over 18psi and 60% injector duty cycle! MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
gkinslow Posted August 17, 2017 Share Posted August 17, 2017 I want the flexibility of not having to switch maps or plan out my route to stay on E85. I will drive the car at least 5 times a week so I will definitely test reliability. I won't be having multiple maps. Strictly e85. I'm fine with giving up the option to take road trips in the LGT. Link to comment Share on other sites More sharing options...
