Marvick08GT Posted July 25, 2017 Author Share Posted July 25, 2017 Good luck! Appreciate it! Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 26, 2017 Author Share Posted July 26, 2017 Fixed a few boost leaks last night. Trans feels silky smooth with only 5 miles on the Amsoil SVG.. Beyond excited to see what this thing can do, i made sure there should be no issues (boost leaks, spark plugs etc) Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 26, 2017 Author Share Posted July 26, 2017 At agile auto.. Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 26, 2017 Author Share Posted July 26, 2017 Passed the pre dyno checks! Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 26, 2017 Author Share Posted July 26, 2017 Sorry guys! Ran into issues on the dyno.. Maf voltage is maxed due to a POS aem intake... and I'm leaning out up top at 17psi. Previous owner claimed a DW65C was installed but may not have changed the filter.. Either it has a factory fuel pump or the main filter is clogged. At 17psi it made 386hp, didnt get a sheet because we need to actually tune it once the fueling and maf issue are resolved. Right now I am running 13 psi. The car is quite a bit faster than the vf52 setup. The 10cm housing greatly improves off boost power and feel. Keeping in mind the car has not been tuned really at all. 17 psi @ 4k rpm. It feels great! Does anybody have a grimmspeed intake and know what size it is? Link to comment Share on other sites More sharing options...
MTBwrench Posted July 26, 2017 Share Posted July 26, 2017 I just stumbled upon this... Looks like a nice setup! (save for the stock internals... but I bet that'll change eventually) Does anybody have a grimmspeed intake and know what size it is? I have one, IIRC the intake tube is around 3". I can measure the ID/OD when I get home from work, if you want. Also: did you replace your turbo inlet? You may benefit from a larger aftermarket inlet. I'm not sure if these will be issues you run into, but it will flow better and resist collapse under spool. MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
rebourne Posted July 26, 2017 Share Posted July 26, 2017 Bummers! The fuel pump is really easy to get verify. just pull the rear seat, and a few bolts. There's a few tricks to keep it from spilling fuel, when you pull it, but i don't remember them offhand. I doubt it's a clogged filter. Might not be a DW65c in there, or the DW is tired. There's been a few instances of tired 65cs. The AEM that Cobb sells seems to be the go to lately. pic thread build thread Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 26, 2017 Author Share Posted July 26, 2017 I just stumbled upon this... Looks like a nice setup! (save for the stock internals... but I bet that'll change eventually) I have one, IIRC the intake tube is around 3". I can measure the ID/OD when I get home from work, if you want. Also: did you replace your turbo inlet? You may benefit from a larger aftermarket inlet. I'm not sure if these will be issues you run into, but it will flow better and resist collapse under spool. I have a perrin inlet. The GS is supposed to be 3" just wanted to be sure. Thanks for the words, we'll see how quickly I can grab these parts and set up another dyno. Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 26, 2017 Author Share Posted July 26, 2017 Bummers! The fuel pump is really easy to get verify. just pull the rear seat, and a few bolts. There's a few tricks to keep it from spilling fuel, when you pull it, but i don't remember them offhand. I doubt it's a clogged filter. Might not be a DW65c in there, or the DW is tired. There's been a few instances of tired 65cs. The AEM that Cobb sells seems to be the go to lately. Yeah I was looking at the aem, i can get a good DW65 locally, The car was a vf52 on ewg previously. It was tuned with the pump and it was fine. Didnt run into issues until i put larger injectors. Link to comment Share on other sites More sharing options...
xtea Posted July 26, 2017 Share Posted July 26, 2017 I've got a used grimmspeed intake I can see you for 33% off new. Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 26, 2017 Author Share Posted July 26, 2017 Appreciate it xtea, already got one! Link to comment Share on other sites More sharing options...
WRX USA Posted July 26, 2017 Share Posted July 26, 2017 Too bad they don't have a Mustang dyno, for comparison sake, but the graph should be interesting. Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 27, 2017 Author Share Posted July 27, 2017 You have a graph? How much boost are you running? Once he adds timing and wgdc it should spool faster. TBH, i like the way it feels already. I'll probably be going back next Thursday to finish it. I have a GS 76mm intake coming, a spare complete fuel pump housing with a dw65c in it. Pulled my pump, it is a DW65C pump, filter is ordered ~$70. It is the upper half of the housing the pump sits in. 150k i guess the filter is original? Even dirty still flows good for 330 hp Link to comment Share on other sites More sharing options...
MTBwrench Posted July 27, 2017 Share Posted July 27, 2017 Pulled my pump, it is a DW65C pump, filter is ordered ~$70. It is the upper half of the housing the pump sits in. 150k i guess the filter is original? Even dirty still flows good for 330 hp If it puts you at ease: I dealt with horrific fueling issues for the longest time on both my stock pump and a DW65C. Random starvation, leaning out under load, horrible AF trims. It was sporadic and would be fine one day and not the next. It turned out my fuel pump housing filter was clogged, and was causing the pump to cavitate under certain situations. Once I replaced that I was golden. Mine had 200k on it though... Also FWIW, I've got a DW65C and ID1000's at sea level. I see about 60% max IDC @17.5psi, sea level. The pump still has plenty left for pump gas, but ethanol at 350+hp would be a struggle. MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted July 27, 2017 Share Posted July 27, 2017 I'll be at Bethany Beach on Labor Day weekend....perhaps you can break another toe so you can get time off and take me for a ride I don't like the idea of breaking a toe but when you get to work on your own car and have time to get it tuned it doesn't sound so bad Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 27, 2017 Author Share Posted July 27, 2017 If it puts you at ease: I dealt with horrific fueling issues for the longest time on both my stock pump and a DW65C. Random starvation, leaning out under load, horrible AF trims. It was sporadic and would be fine one day and not the next. It turned out my fuel pump housing filter was clogged, and was causing the pump to cavitate under certain situations. Once I replaced that I was golden. Mine had 200k on it though... I appreciate the input! Exactly what's happening to me.. You have to come out for the ride Link to comment Share on other sites More sharing options...
WRX USA Posted July 27, 2017 Share Posted July 27, 2017 You have a graph? How much boost are you running? Once he adds timing and wgdc it should spool faster. TBH, i like the way it feels already. http://legacygt.com/forums/showpost.php?p=5552910&postcount=183 These are all on California 91 octane and on the conservative side, given my 130k stock block. Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 27, 2017 Author Share Posted July 27, 2017 Nice numbers on 91! If i can grab a filter from the dealer, ans grab the intake tonight, i can dyno tomorrow morning Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 27, 2017 Author Share Posted July 27, 2017 Going back to the dyno tomorrow morning :spin: Link to comment Share on other sites More sharing options...
rebourne Posted July 27, 2017 Share Posted July 27, 2017 sticking with the DW65? pic thread build thread Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 27, 2017 Author Share Posted July 27, 2017 Yeah, the filter is black lol, the pump is fine. Still excited 1 more day! Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 28, 2017 Author Share Posted July 28, 2017 Back at Agile! Intake is in, I'm changing the fuel filter now Link to comment Share on other sites More sharing options...
gkinslow Posted July 28, 2017 Share Posted July 28, 2017 Hurry up!! I want to see some numbers. Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 28, 2017 Author Share Posted July 28, 2017 On the dyno now, lol he's doing the throttle mapping and maf calibration. The filter was black btw.. Link to comment Share on other sites More sharing options...
rebourne Posted July 28, 2017 Share Posted July 28, 2017 ... I doubt it's a clogged filter. .... On the dyno now, lol he's doing the throttle mapping and maf calibration. The filter was black btw.. Looking forward to being proved wrong, lol! pic thread build thread Link to comment Share on other sites More sharing options...
