Risen Saint Posted June 22, 2017 Share Posted June 22, 2017 Soooo i got slightly irritated with some slow movers in front of me threw it in second and ran that bitch to red line for the first time... it felt like all power to the car just cut out I know governors are supposed to limit your top speed but is there any other sort of (maybe) a protection against the car being thrown into redline like a governor?? If im even spelling that right hah Link to comment Share on other sites More sharing options...
sunny5280 Posted June 22, 2017 Share Posted June 22, 2017 My 1991 300ZX Turbo reduced fuel delivery to prevent damage. Felt like it hit a wall when that occurred. Link to comment Share on other sites More sharing options...
subie bob Posted June 22, 2017 Share Posted June 22, 2017 Ive experienced something very similar getting out into some traffic i hit second gear pretty hard got loose and hit redline and it cut out a bit. So i would assume its to protect from over rev Link to comment Share on other sites More sharing options...
covertrussian Posted June 22, 2017 Share Posted June 22, 2017 That is called the fuel cut rev limiter. It basically cuts all the fuel by that point, to prevent the engine from going any further. It's harsh on purpose, to make you not want to hit it again. There is another way to rev limit, called spark cut, it's what you usually see (really hear) in racing application, spark cut lets you bounce of the redline. Spark cut rev limiter is used for lunch control systems too, creating that distinct sound. Spark cut redline bouncing: 05 LGT 16G 14psi 290whp/30mpg 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg Link to comment Share on other sites More sharing options...
rougeben83 Posted June 22, 2017 Share Posted June 22, 2017 Yup, you hit the fuel cut rev limiter. Keeps you from bouncing off the limiter like covertrussian said. It won't do harm to the car, but you'll know not to do it again purposefully. Link to comment Share on other sites More sharing options...
Risen Saint Posted June 23, 2017 Author Share Posted June 23, 2017 Hahaha ok sweet someone else pointed to fuel cut to.. lol incredible tho i guess ill say i dont mind the feature.. THANK YOU SUBARU Link to comment Share on other sites More sharing options...
CapnJack Posted June 23, 2017 Share Posted June 23, 2017 I'm not sure I would consider it a "feature". Most engines are not made to bounce off the rev limiter on a regular basis. That's where you start to lose rod bearings, float valves, and cause other potential damage. Link to comment Share on other sites More sharing options...
08Legacy-GT Posted June 23, 2017 Share Posted June 23, 2017 boost cut 2017 Subaru STI 2008 Subaru Legacy 2.5i limited Link to comment Share on other sites More sharing options...
grovlet Posted June 23, 2017 Share Posted June 23, 2017 boost cut ahhem - nope not that at all.... has nothing at all to do with boost pressure:p As noted it's the rev-limited fuel cut - designed to literally drop engine RPM back down - so as to implode the engine and keep it operating within it's mechanical limits. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 23, 2017 Share Posted June 23, 2017 ahhem - nope not that at all.... has nothing at all to do with boost pressure:p As noted it's the rev-limited fuel cut - designed to literally drop engine RPM back down - so as to implode the engine and keep it operating within it's mechanical limits. If you don't drop from 5th to 3rd Link to comment Share on other sites More sharing options...
