josholaveson Posted May 30, 2017 Share Posted May 30, 2017 So, my wife bought a 2001 legacy gt (ej 252 5mt) with a bad clutch. And by bad I mean completely beyond repair it was down to bare metal and there was clutch pad bits all over in the bell housing. Any way back to the matter at hand, I pulled the motor and noticed the head gaskets were leaking. So while i had the motor out I got a gasket set and replaced all seals and gaskets. Inside of the motor looked good No cracked pistons cylinder walls looked good etc.. Got a 6 puck clutch and brand spanking new flywheel. Threw it all back together gave it a crank. And a nice spray of royal purple came from the passenger side head (a result of letting my cousin do that head. Putting the damn gasket backwards!!!) did the valve adjustment and all new mounts from front to back. And took it for a spin. I've got no power.. It goes but it just feels like it's lacking power in the whole range. I'm kind of Sad to do all that work and get such a sad return. First gear goes good second feels okay then third goes okay. But fourth with the pedal to the metal feels like trying to start of in third gear. Anyone have any ideas? I've checked timing 3 times and spot on every time. New air filter and plugs and wires. Running 95 octane. Link to comment Share on other sites More sharing options...
fedaykin Posted May 31, 2017 Share Posted May 31, 2017 Got a boost gauge? If not, throw one on and see what's happening with the inlet manifold pressure. Link to comment Share on other sites More sharing options...
josholaveson Posted May 31, 2017 Author Share Posted May 31, 2017 Got a boost gauge? If not, throw one on and see what's happening with the inlet manifold pressure. I don't but I am getting a cable soon to hook to my laptop and see what the computer is telling me. Or I'll just go get one and see. Thanks for the reply. Sent from my LG-K540 using Tapatalk Link to comment Share on other sites More sharing options...
bdcvg Posted May 31, 2017 Share Posted May 31, 2017 Btssm Link to comment Share on other sites More sharing options...
birkhoff Posted May 31, 2017 Share Posted May 31, 2017 Btssm Would Btssm work with a 2001 EJ252? Link to comment Share on other sites More sharing options...
StkmltS Posted June 6, 2017 Share Posted June 6, 2017 Check the green plug down in the foot area by the front passenger seat. The two ends should NOT be plugged together. My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
josholaveson Posted June 7, 2017 Author Share Posted June 7, 2017 Went and got a vacuum gauge and i have no vacuum leaks. I hooked it up to a scan tool and for some reason it's running rich. Next thing on my list would be to check the knock sensor. But of course i was too concerned with fuel trims to even check the knock sensor readings. I also have a whistle around 3000 rpm and it changes pitch depending on engine load. I thought it could be a bad cat or muffler but i don't see any apparent restriction with the vac guage. Anyone have an idea what that could be? Sent from my LG-K540 using Tapatalk Link to comment Share on other sites More sharing options...
kaluce Posted August 8, 2017 Share Posted August 8, 2017 Possibly an air leak post MAF? I don't know enough about the 252, but I'd try doing a leakdown and a compression test to see if it was reassembled properly. It's possible that something was missed. Link to comment Share on other sites More sharing options...
StkmltS Posted August 9, 2017 Share Posted August 9, 2017 Did you check the green plug? My friend has an older forester and it ran like crap after he rebuilt the motor because the green connectors were mistakenly connected (to his credit I think he bought it that way). My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 9, 2017 Share Posted August 9, 2017 Did you have the heads resurfaced and do a good cleaning of the deck's on the block ? If so do, a compression test. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MilesA Posted August 9, 2017 Share Posted August 9, 2017 Unfortunately, that engine just does not have enough power for the weight of the car. Slow is a given. Handling can be very good, if you want to work on improving that, the car can still be fun to drive. Link to comment Share on other sites More sharing options...
