VespaGTS Posted May 10, 2017 Share Posted May 10, 2017 Found the answer... Scroll down the page for a link, or click here: http://legacygt.com/forums/showthread.php/drl-disable-10-minutes-2117p40.html So I have tried the DRL disable where you unplug the wiring harness under the dash. This worked except it also disabled by high beams. Do you guys know if there is a different way to disable DRL in a 2007? Many thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted May 11, 2017 Share Posted May 11, 2017 There is a sticky about this at the top of one of the forums. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gimpydingo Posted May 11, 2017 Share Posted May 11, 2017 Strange my 07 doesn't have DRL... Guess I should check the connection. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 11, 2017 Author Share Posted May 11, 2017 There is a sticky about this at the top of one of the forums. I am sure its in here someplace. I did a search and found the instructions for 2005-06. Nothing on 07? If you know where to look and can help a newbie to the site that would be great. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 11, 2017 Author Share Posted May 11, 2017 It was 40 pages into the thread to find my answer. Whew! The search function needs some love or we need a Wiki page with all the best solutions on it. Something... Here is a link for the solution: http://legacygt.com/forums/showthread.php/drl-disable-10-minutes-2117p40.html Link to comment Share on other sites More sharing options...
Max Capacity Posted May 11, 2017 Share Posted May 11, 2017 FWIW, I only show 15 pages for that thread. Glad you found it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
solidxsnake Posted May 11, 2017 Share Posted May 11, 2017 It was 40 pages into the thread to find my answer. Whew! The search function needs some love or we need a Wiki page with all the best solutions on it. Something... Here is a link for the solution: http://legacygt.com/forums/showthread.php/drl-disable-10-minutes-2117p40.html That link doesn't work for anyone who changes the default "posts per page" option. You should link to the post like this (click on the post number on the top-right of the post): http://legacygt.com/forums/showpost.php?p=4526145&postcount=552 Or just quote it: It's underneath the driver's side dash, beneath the steering wheel. There's an underside plastic panel - you'll have to remove that panel, or at least take out a few pop-its (forgot how many) and maneuver the panel out of the way to get access to the connector. Relative to the steering column, I would say that it's tucked against the firewall to the upper left. I laid on my back and looked up to find it. You'll see a black box that's clearly labeled DRL with two connectors: 1 white, 1 black. Pull the white one out (I thought it was kind of a pain in the ass); pop the black/blue wire out of the white connector (use a jewelry flathead screwdriver set) + wrap the exposed end + zip-tie it off; pop the white connector back into the DRL box. You're set. Link to comment Share on other sites More sharing options...
