Max Capacity Posted April 20, 2017 Share Posted April 20, 2017 So, for a couple summers now, when its really hot and I have the AC running for 20 minutes or so the blower slows down its speed. I shut the HVAC off for a mile or then turn it back on and the blower is blowing the hair on my head. This past Sunday driving home from VT, outside air temp was 88F after about 90 minutes. I realized the blower was running slow, turned it off, for a mile or so and then back on. it was blowing the hair on my head. The AC continues to work fine during the blower running slow. So is that a http://estore.subarupartswarehouse.com/p/Subaru_2005_Legacy25L-TURBO-5MT-4WDGT-Wagon/POWER-TRANSISTOR/49283108/73533AG000.html issue or a Motor, http://estore.subarupartswarehouse.com/p/Subaru_2005_Legacy25L-TURBO-5MT-4WDGT-Wagon/POWER-TRANSISTOR/49283108/73533AG000.html issue ? Thanks, 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
relative4 Posted April 20, 2017 Share Posted April 20, 2017 Likely both. The typical failure sequence is the blower starts going bad, pulls excessive amps, and overheats the resistor. I'd buy both from a junkyard, swap the blower, and if it works perfectly, keep the resistor around for next time or eBay it. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 20, 2017 Author Share Posted April 20, 2017 That's kind of the plan, the local junk yard had a donor car that I got a rear wiper motor that's been working fine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LatentWagen Posted April 23, 2017 Share Posted April 23, 2017 I have a new OEM transistor that I mistakenly bought for my car. Same part that you linked above, Max. Let me know if you want it for cheepo. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Max Capacity Posted April 23, 2017 Author Share Posted April 23, 2017 Thanks, this week I'll have to stop by the local junkyard and see what they have for a blower motor. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 24, 2017 Share Posted April 24, 2017 They are not too expensive to purchase a new one and definitely worth the few extra bucks to not have to take it out twice. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted April 24, 2017 Share Posted April 24, 2017 FWIW, I had the same problem with a non-Subaru car. The bearing in the blower motor was seized. I was able to dismantle the motor, clean the bearing and re-lube it. As for the resistor ladder, I was able to re-solder the fusible links on it too. So although somewhat laborious, the repair cost was basically nil. Anyway, I guess my point is don't replace the motor if it just needs a lube job. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 24, 2017 Author Share Posted April 24, 2017 The motor dose not make any noise so I'm sure the bearing is fine. JmP...yea that thought keeps running through my mind. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DonnyJagaru Posted April 25, 2017 Share Posted April 25, 2017 Well, I disagree. You can have a silent bearing that is kaput too. Run the A/C until the motor slows down, turn the car off and try to spin the fan with your finger. If it spins freely you're right. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 26, 2017 Author Share Posted April 26, 2017 Just ordered a blower motor from the local junk yard, $40.00, 90 day warranty. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
2milehi Posted April 27, 2017 Share Posted April 27, 2017 At full speed there is full power at the blower motor. I'd say that you are on the right track on replacing the blower motor. Link to comment Share on other sites More sharing options...
pseank Posted April 27, 2017 Share Posted April 27, 2017 Resister will burn out if motor pulls excess amps. It will not be intermittent. Once it fails it will be permanent. Usually high speed goes out or only high speed works. The limited w/automatic HVAC sucks and can do strange things but Max is a smart fella which is why I listen when he posts. Checking amperage would tell the tale but you have to have expensive adapters tor the dvom or an inductive pickup. I would rig a direct hot wire from the battery and let it run. If it slows definitely motor. The resister is straight through on high speed. Hope this helps! So jazzed to see the most knowledgeable 4th gen on here ask instead of answering. You help me more than you know Max Sent from my XT1254 using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted April 27, 2017 Author Share Posted April 27, 2017 Thanks, I walked around the yard and looked at the 5 cars they had, a 05 2.5i and 4 Outbacks 2.5i's. There was not much left of the cars. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 28, 2017 Share Posted April 28, 2017 http://www.partsgeek.com/gbproducts/DC/18220-05366221.html?utm_content=DN&utm_term=2005-2010+Subaru+Legacy+Blower+Motor+TYC+Front+05-10+Subaru+Blower+Motor+2009&utm_source=google&utm_medium=ff&utm_campaign=PartsGeek+Google+Base&gclid=Cj0KEQjwrYbIBRCgnY-OluOk89EBEiQAZER58i0gUS6mTCrKm8YQ_oS0YRKxCnORM85s5ffy6XspoiwaAuWB8P8HAQ&ad=47433970452 Brand new for $42.00 Link to comment Share on other sites More sharing options...
Max Capacity Posted May 7, 2017 Author Share Posted May 7, 2017 Update, put the junkyard blower in today. Took about 20 minutes. Now just have to wait till July/Aug to see if it works when it on the 90'sF on the drive home. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted May 7, 2017 Author Share Posted May 7, 2017 http://www.partsgeek.com/gbproducts/DC/18220-05366221.html?utm_content=DN&utm_term=2005-2010+Subaru+Legacy+Blower+Motor+TYC+Front+05-10+Subaru+Blower+Motor+2009&utm_source=google&utm_medium=ff&utm_campaign=PartsGeek+Google+Base&gclid=Cj0KEQjwrYbIBRCgnY-OluOk89EBEiQAZER58i0gUS6mTCrKm8YQ_oS0YRKxCnORM85s5ffy6XspoiwaAuWB8P8HAQ&ad=47433970452 Brand new for $42.00 This link may work better, http://www.partsgeek.com/catalog/2005/subaru/legacy/climate_control/blower_motor.html No that link didn't work either, if you go to partsgeek and search for a blower motor you'll find them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted May 19, 2017 Author Share Posted May 19, 2017 Update, the past couple day's it's been 97F when I leave work, the blower has worked fine on the way home. The only difference in the DD home has been, I've taken the backroads over the mountain because the highway has had traffic issues. The old blower would give up about 28 miles into the after work drive home on the highway. Looks like it may be a while until its that warm again. I hate the heat. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted May 19, 2017 Author Share Posted May 19, 2017 Well today while driving on the highway to come home, 92F about 5 miles left on the highway...yes the blower began to slow down...;( PM sent to LatentWagen. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Darth SpecB Posted May 19, 2017 Share Posted May 19, 2017 It seems like the resistor gave out. Hopefully it's easily accessible! Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted May 19, 2017 Author Share Posted May 19, 2017 Looks like its on the outside of the housing, hopefully by the passenger feet area. http://estore.subarupartswarehouse.com/a/Subaru_2005_Legacy25L-TURBO-5MT-4WDGT-Limited-Sedan/_54104_6025949/HEATER-SYSTEM-BLOWER/B13-720-03.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DonnyJagaru Posted May 24, 2017 Share Posted May 24, 2017 $238 for a resistor ladder? That's a total rook. Crack it open and replace the whipped resistors. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 24, 2017 Author Share Posted May 24, 2017 No, no, no look again, the resistor is only $48. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DonnyJagaru Posted May 26, 2017 Share Posted May 26, 2017 Noted. It says transistor though, so guessing different from the more typical resistor ladder found in most every car for the past few decades. I'd still take a poke at repairing the old one though. Can't be much going on inside that plastic doodad. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 25, 2017 Author Share Posted June 25, 2017 Update, After some research, I learned the 2.5i and GT's are different because the GT's with Auto setting have a transistor where the 2.5i which don't have Auto HVAC has a resistor. I installed a new transistor a few minutes ago, took about 15 minutes to do. Two Phillips screws hold it in just ahead of the blower motor. It only goes in one way. Will update next time its hot on the drive home from work. The part was $48.00 on line from my local dealer. I stopped by the dealer and talked with the guy's and they had no problem giving me the on line price. http://www.suburbansubaru.com/buy-subaru-parts.htm 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LatentWagen Posted June 30, 2017 Share Posted June 30, 2017 Yep, I learned this the hard way. Bought the transistor first! That said, if anyone needs a transistor, I'll probably still have this one sitting around, new OEM in the box. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
