sunny5280 Posted February 26, 2017 Share Posted February 26, 2017 What is the brown gunk? Link to comment Share on other sites More sharing options...
Dujo Posted February 26, 2017 Share Posted February 26, 2017 Looks like toasted bearing grease. Hate to say it, cause it ain't gonna be cheap and it's not how one would choose it, but boy are you gonna get a really nice wagon out of this. Look at the brighter side, I say. Good luck on your rebuild! Forged internals for 500awhp you say? Sure, why not we say. Enjoy! Link to comment Share on other sites More sharing options...
SupraLegacy Posted February 28, 2017 Author Share Posted February 28, 2017 Looks like toasted bearing grease. Hate to say it, cause it ain't gonna be cheap and it's not how one would choose it, but boy are you gonna get a really nice wagon out of this. Look at the brighter side, I say. Good luck on your rebuild! Forged internals for 500awhp you say? Sure, why not we say. Enjoy! Agreed! Lol. I don't think I'll be going straight into a 500awhp build.. How much do you think it has with its current mods? SPT Intake, Cobb Catted DP, Prodrive Cat-back exhaust, Cobb AP V3 with Shelf Map. I mean i know since the motor's out I might as well have all the work done. If i were looking to do the forged setup what setup would you recommend? Anyway, Got the heads off, doesnt look too bad. But what do I know... Bryan C. NorCal - SupraLegacy - 05 LGT Wagon 5MT - 15 FXT Premium Link to comment Share on other sites More sharing options...
Dujo Posted February 28, 2017 Share Posted February 28, 2017 How much do you think it has with its current mods? SPT Intake, Cobb Catted DP, Prodrive Cat-back exhaust, Cobb AP V3 with Shelf Map. Stock power is 250 at the crank which works out to about 193 at the wheels when new. That setup is basically stage 2 and the intake isn't really helping much over the stock intake because the stock intake isn't a restriction at that power level. Stage 2 is going to be anywhere from about 225 to about 275 at the wheels depending on the tune and the dyno and the temp on the day, etc, etc. You're probably in the 250 at the wheels range with that. As far as forged internals, I haven't done a built motor yet, so I haven't done the deep research to really recommend parts, but I'm sure you can find plenty of threads on there that can. Look in to pistons, connecting rods, and nitrided crank. No idea if you want to monkey with cams or not. Might consider new valves, but you may just be able to get away with a good valve job from a machine shop. Cause the inside actually doesn't look that bad based on a timing belt breaking. You may have gotten really really lucky. See what the machine shop says. You may be able to reuse everything if it's not damaged. Might be worth the savings in parts to reuse it all. See what the shop recommends at this point, I'd say. Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 28, 2017 Share Posted February 28, 2017 Like Dujo said it looks like you got extremely lucky. I'd still have all the valves pulled because some of them may be slightly bent but there doesn't appear to be any signs of piston and valve contact. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
SupraLegacy Posted February 28, 2017 Author Share Posted February 28, 2017 Thanks guys, I was kind of peeking around at some manly pistons and stuff also gsc s1 cams and turbos and injectors. Then started looking at tgv deletes... The list kept building up.. so I'm back to not knowing what I want to do. Lol. I think it may have made a little contact tho because some of the markings and some of the deposits off of the valves seem to have been broken off? @magnusonsubie do any of those shops mentioned in earlier posts do machine work? Also does anyone know of a kit to buy all new vacuum coolant fuel and oil hoses. I've broken quite a few trying to take everything apart... Bryan C. NorCal - SupraLegacy - 05 LGT Wagon 5MT - 15 FXT Premium Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 28, 2017 Share Posted February 28, 2017 I don't know if those shops do machine work of if they send them out. I bet you could call them to find out though. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
SupraLegacy Posted March 10, 2017 Author Share Posted March 10, 2017 Alright Folks little bit of an update. Went ahead and dropped off the heads last week to a machine shop in Hayward found out something was definitely messed up with one of the valves. http://legacygt.com/forums/attachment.php?attachmentid=246081&stc=1&d=1489128566 Also went ahead and went through and planned what i was going to buy and bought most of it? i think. PURCHASED : Tomei Timing Belt Guide Perrin Inlet Hose ACT Lightweight Flywheel 600480 Exedy Racing Clutch Kit 15804 Group N Subaru Motor Mounts Gates Racing Timing Belt Kit TCKWP328RB Gates Thermostat Subaru Gasket Kit ARP EJ25 Head Bolt Kit 2604701 IN CART : Killer B Oil Kit Tomei Poncam Camshafts Fumoto Valve MISC Vacuum / Fuel / Coolant / Oil Lines Timing Belt Rear Covers - Since I stupidly broke them trying to remove the cam gears. Also need to buy a stock LGT Airbox since everyone is telling me to get rid of the SPT intake So if you know where I could acquire one let me know! Bryan C. NorCal - SupraLegacy - 05 LGT Wagon 5MT - 15 FXT Premium Link to comment Share on other sites More sharing options...
Dujo Posted March 10, 2017 Share Posted March 10, 2017 Yep, you've definitely got a bent valve. I assume the heads aren't too damaged and can be machined to accept new valves. That SPT intake isn't helping you a bunch, but it's not really hurting you that much either. It may not be worth the trouble to go back to stock on that part if you don't have a stock intake in your possession. It would be one thing if you had a stocker on there and wanted to waste money on a new one, but since it's already on there ... Link to comment Share on other sites More sharing options...
SupraLegacy Posted March 11, 2017 Author Share Posted March 11, 2017 @dujo , you know what I actually just looked at the intake and i guess the SPT intake doesnt have a CARB legal sticker so i think i have to source a stock intake all the way from the accordian hose. But for some reason the last owner included the air duct that comes over the radiator. Bryan C. NorCal - SupraLegacy - 05 LGT Wagon 5MT - 15 FXT Premium Link to comment Share on other sites More sharing options...
Dujo Posted March 11, 2017 Share Posted March 11, 2017 Yeah, you probably can't pass visual in California with that on. Oh well, at least you won't have to give up any real horsepower to get rid of it. Link to comment Share on other sites More sharing options...
SupraLegacy Posted March 26, 2017 Author Share Posted March 26, 2017 Hey all just a little update. Finally got the heads back from the shop. Got a 5-angle valve job as well as the buckets properly machined for the Tomei Poncams. Also received and installed the killer B oil pick up. Now I gotta go to the store to get a good scraper and some liquid gasket to reinstall the oil pan as well as the oil and water pump. Can anyone suggest a good brand liquid gasket for this? Does it have to be different ones because oil and coolant? Can't wait to really start putting everything back in! Bryan C. NorCal - SupraLegacy - 05 LGT Wagon 5MT - 15 FXT Premium Link to comment Share on other sites More sharing options...
seanyb505 Posted March 26, 2017 Share Posted March 26, 2017 The right stuff. It comes in a cheeze whiz type can and is dispensed similarly. I used it for everything on my build except the short block that came assembled. Link to comment Share on other sites More sharing options...
SupraLegacy Posted April 3, 2017 Author Share Posted April 3, 2017 Alright some progress done on my EJ255. Still some reassembling to do... Is it normal for the intake manifold to be misaligned with the tgvs? I found it weird.. well hopefully I can get this car back up and running this weekend. Bryan C. NorCal - SupraLegacy - 05 LGT Wagon 5MT - 15 FXT Premium Link to comment Share on other sites More sharing options...
SupraLegacy Posted April 7, 2017 Author Share Posted April 7, 2017 Are these vacuum lines routed correctly. Saw a very low quality picture of the routing. Just need verification. TIA https://flic.kr/p/T3wfCY Bryan C. NorCal - SupraLegacy - 05 LGT Wagon 5MT - 15 FXT Premium Link to comment Share on other sites More sharing options...
seanyb505 Posted April 7, 2017 Share Posted April 7, 2017 Not sure if you've seen this, but it should help with vacuum lines. http://legacygt.com/forums/showthread.php/2005-2006-lgt-colored-vacuum-routing-diagram-143225.html Link to comment Share on other sites More sharing options...
pnmid Posted April 7, 2017 Share Posted April 7, 2017 Did you get the blue T replacement? Link to comment Share on other sites More sharing options...
SupraLegacy Posted April 7, 2017 Author Share Posted April 7, 2017 Not sure if you've seen this, but it should help with vacuum lines. http://legacygt.com/forums/showthread.php/2005-2006-lgt-colored-vacuum-routing-diagram-143225.html Did not see this thank you! Did you get the blue T replacement? I didn't replace the blue T everything seemed intact and didn't break when I pulled off the lines. I did replace the ones the lines that connected to it. Bryan C. NorCal - SupraLegacy - 05 LGT Wagon 5MT - 15 FXT Premium Link to comment Share on other sites More sharing options...
SupraLegacy Posted April 8, 2017 Author Share Posted April 8, 2017 I ordered the Exedy 15804 clutch kit. I notice quite a few of you have ordered this kit and liked it. But I am running into issues here. The throw out bearing is smaller than the stock one and will not slide into place. Also the clutch is significantly smaller than the stock one too. Import Image website says this kit fits 2005-2008 Legacy GT... Is there something I'm missing?! https://flic.kr/p/SpW84g https://flic.kr/p/T4LAPA Bryan C. NorCal - SupraLegacy - 05 LGT Wagon 5MT - 15 FXT Premium Link to comment Share on other sites More sharing options...
Silinc3r Posted April 8, 2017 Share Posted April 8, 2017 I am very interested to see how you like the cams. I have been looking into them. As for the clutch kit, not sure. I would contact them, they have very good customer service. Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
Silinc3r Posted April 8, 2017 Share Posted April 8, 2017 Did you remove a single or double mass flywheel? If it was single then the previous OP swapped to the WRX style which is bigger also I believe. So they disk would be smaller. Just my thought. Haven't done a swap on the 4th gen yet. Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 9, 2017 Share Posted April 9, 2017 OP, if you can still easily access your vacuum lines, zip tie as many as ends possible. The three ends attached to that blue T are notorious to pop off especially at higher boost levels. Link to comment Share on other sites More sharing options...
apexi Posted April 10, 2017 Share Posted April 10, 2017 Might not be a bad idea to get the barbed T just to avoid any possible headaches down the road. http://legacygt.com/forums/showthread.php/subaru-blue-tee-replacement-218783.html http://www.company23.com/VacuumT Link to comment Share on other sites More sharing options...
SupraLegacy Posted April 10, 2017 Author Share Posted April 10, 2017 I will need to throw some zip ties on these lines I guess. So I found out that my output shaft has a TSK3 kit installed that's the reason why the TOB wouldn't fit onto the output shaft. However, the EXEDY pressure plate does not align with my ACT lightweight Flywheel. Now, i forgot where I saw this, but is it correct that an ACT clutch and pressure plate should be used with the ACT Flywheel? Bryan C. NorCal - SupraLegacy - 05 LGT Wagon 5MT - 15 FXT Premium Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 14, 2017 Share Posted April 14, 2017 ^ Anyone know because I was looking at the same flywheel and clutch combo and if it's going to be issues I would like to know. Link to comment Share on other sites More sharing options...
