EJ from upstairs Posted December 4, 2016 Share Posted December 4, 2016 I have had my 2006 2.5i wagon for two years. The fob unlocks the doors as usual, but as of a few days ago there doesn't seem to be a response when I press the lock button. I just changed the transmitter battery a few months ago. I checked and made sure the alarm system was activated using the manual's directions (odometer reads "AL on"). It chirps to say it's armed when you lock the driver door from the inside and close the door, and all doors are then locked as usual. I don't think it's an actuator issue because the doors will lock electronically. Is it time for a new key fob transmitter? Thanks! EJ Link to comment Share on other sites More sharing options...
SpecBlitzed Posted December 5, 2016 Share Posted December 5, 2016 Ran into the same issue with mine and iam trying to solve the solution. My key fob is completely dead with nothing functioning. My alarm works when I manually lock the doors. Replaced the fob battery and did the reprogramming steps and nothing. Link to comment Share on other sites More sharing options...
amm203 Posted December 5, 2016 Share Posted December 5, 2016 My dad's old '05 started having the same issue a few years back. After taking the fob apart it was obvious the button mechanism under the plastic button separated from the circuit board. eBay replacements can be found cheap and reprogramming the fob to work with your car is not hard at all. This is a common issue for the earlier tear-drop style fobs - even one of the eBay replacement fobs I ordered already had the button mechanism broken off the circuit board. Link to comment Share on other sites More sharing options...
amm203 Posted December 5, 2016 Share Posted December 5, 2016 Not the same fob but helps illustrate your likely problem... Link to comment Share on other sites More sharing options...
Max Capacity Posted December 5, 2016 Share Posted December 5, 2016 My dad's old '05 started having the same issue a few years back. After taking the fob apart it was obvious the button mechanism under the plastic button separated from the circuit board. eBay replacements can be found cheap and reprogramming the fob to work with your car is not hard at all. This is a common issue for the earlier tear-drop style fobs - even one of the eBay replacement fobs I ordered already had the button mechanism broken off the circuit board. Having read your post about the early fob's, I'm thinking about my 09 Spec B, those fob's are a nightmare. My 05's will lock or unlock the car from a long distance away. The 09, at times I've had to use the key to unlock it. Next time the fob works from a long distance, other times you have to be within 10 feet of the car. One time at the dealership the wagon won't lock. I had the parts guy's replace the battery's in both fob's, still didn't work, drove the car home, worked great. They say that sometimes another Subaru close to yours will cause interference ...? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
amm203 Posted December 5, 2016 Share Posted December 5, 2016 Ah I noticed that with my square fob as well. Have the exact same issues you described. There are times I am 30+ feet away and not in line-of-sight and I can hear the car beep to the button presses. That's an interesting theory and makes sense - there is a Crosstrek that parks near my car sometimes. Going to test it out. Link to comment Share on other sites More sharing options...
EJ from upstairs Posted December 5, 2016 Author Share Posted December 5, 2016 Not the same fob but helps illustrate your likely problem... Thank you! I read the directions in the manual for programming a fob and it seems more lengthy than difficult. Looks like I'll be fob shopping soon... Link to comment Share on other sites More sharing options...
solidxsnake Posted December 6, 2016 Share Posted December 6, 2016 Alternatively, if it is just the button, it may be quicker to buy a new one from somewhere like Digi-Key or Mouser and swap it out, depending how comfortable you are with a soldering iron. A pushbutton switch like that should be cheap, almost guaranteed to be worth less than the shipping cost. Likely something you could find at a RadioShack (if any still exist near you ). Link to comment Share on other sites More sharing options...
Max Capacity Posted December 6, 2016 Share Posted December 6, 2016 Or may be stop by a radio install place and see if they can help you out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
