brandon.mol Posted October 2, 2016 Share Posted October 2, 2016 Two things. 1. If you press the trip knob/button with the key off it cycles through two settings "1" and "2" which you can turn on and off. "2" is the gear selection indicator in the cluster, I know that, but does anybody know what "1" is? I didn't see anything in the manual. 2. If you press the stability control button it disables it, and a light turns on in the cluster. But if you hold it... I forget how long, say 30 seconds, it turns off the light again and won't turn back on until you shut off the car and start it again. Thoughts on what this might be doing? ... Cheat mode? [emoji356] Link to comment Share on other sites More sharing options...
acumenhokie Posted October 2, 2016 Share Posted October 2, 2016 Try Up, Up, Down, Down, Left, Right, Left, Right, B, A, Start. It turns the boost up 10psi! Link to comment Share on other sites More sharing options...
ehsnils Posted October 2, 2016 Share Posted October 2, 2016 Two things. 1. If you press the trip knob/button with the key off it cycles through two settings "1" and "2" which you can turn on and off. "2" is the gear selection indicator in the cluster, I know that, but does anybody know what "1" is? I didn't see anything in the manual. 2. If you press the stability control button it disables it, and a light turns on in the cluster. But if you hold it... I forget how long, say 30 seconds, it turns off the light again and won't turn back on until you shut off the car and start it again. Thoughts on what this might be doing? ... Cheat mode? [emoji356] The stability control button has probably been detected as a "stuck" button and is therefore turned off. I tried the same thing with my lane change warning button but the result was that I lost all related automatic functions depending on the EyeSight system so it was just to stop and power-cycle the car. We are now in the state where minor problems requires the car to be rebooted. Link to comment Share on other sites More sharing options...
dgoodhue Posted October 2, 2016 Share Posted October 2, 2016 1 turns on/off the initial gauge sweep when the car is turned on. Link to comment Share on other sites More sharing options...
FLlegacy Posted October 2, 2016 Share Posted October 2, 2016 1 turns on/off the initial gauge sweep when the car is turned on. That's what I was going to say. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
Unsp0kn Posted October 2, 2016 Share Posted October 2, 2016 Why would you turn off the awesome gauge sweep? Link to comment Share on other sites More sharing options...
Captain Ned Posted October 2, 2016 Share Posted October 2, 2016 And all of this is in the owner's manual. Link to comment Share on other sites More sharing options...
brandon.mol Posted October 2, 2016 Author Share Posted October 2, 2016 And all of this is in the owner's manual. What page? I looked and didn't find it. Link to comment Share on other sites More sharing options...
Rutchard Posted October 2, 2016 Share Posted October 2, 2016 page 125-126 in the 2010 manual. Assuming 2012 manual will be somewhere around there... Link to comment Share on other sites More sharing options...
brandon.mol Posted October 3, 2016 Author Share Posted October 3, 2016 Yup, on page 3-6, thanks. No page numbers in the paper manual. Found it in the PDF. The PDF version, being searchable also helped me find this, regarding the "vehicle dynamics control off switch": If the switch is held down for 10 seconds or longer, the indicator light turns off, the Vehicle Dynamics Control system is activated, and the system ignores any further pressing of the switch. To make the switch usable again, turn the ignition switch to the “LOCK” position and restart the engine. Link to comment Share on other sites More sharing options...
fedaykin Posted October 6, 2016 Share Posted October 6, 2016 We are now in the state where minor problems requires the car to be rebooted. Funny thing is, on my R32 GT-R, the AWD system craps out randomly (sensors, it was released in 1989...), so I have to cut power to the ATTESA computer (i.e. power cycle the car). Gets annoying during track days lol. Link to comment Share on other sites More sharing options...
