rhino6303 Posted September 29, 2017 Share Posted September 29, 2017 You can also get a npw waterpump. I use this website to find high quality parts. I have the npw cast waterpump on my car. http://www.nitomainc.com/npsp3.php?masterno=21111AA240 Link to comment Share on other sites More sharing options...
boxkita Posted September 29, 2017 Author Share Posted September 29, 2017 Rallispec sells an electric water pump conversion for em motor. It's 500$ for the full kit. It would solve the cavitation due to excessive tomorrow problem. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
RacerX69 Posted September 30, 2017 Share Posted September 30, 2017 Looking at a racing alternator. Smaller size with a targeted rpm more in line with the race motor's speed. On track, the street car was in 4-6k range most of the time. On the street, it was more of 2500-3500. Vast difference in average rpm range. Having an alternator matched to the average rpm range should gve better performance and lower parasitic drag on motor. Assuming race car will have same working range. One maker of custom alternators gives a how-to choose guide - http://www.powermastermotorsports.com/which_alternator_a.html The stock car guys mount the alternator on the rear diff, and a pulley on the input flange to drive it. It only turns when the car is rolling, and since race cars don't spend a lot of time idling, the small amount of total loss is negligible. Link to comment Share on other sites More sharing options...
boxkita Posted October 1, 2017 Author Share Posted October 1, 2017 The stock car guys mount the alternator on the rear diff, and a pulley on the input flange to drive it. It only turns when the car is rolling, and since race cars don't spend a lot of time idling, the small amount of total loss is negligible. I'd like to do that. Would allow better routing for the fmic, too Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Sgt.Gator Posted October 2, 2017 Share Posted October 2, 2017 A couple of notes for you: The Silver Eagle already has an underdrive crank pulley. I'm 90% sure it has the old style water pump, and it's a new one, not the original. I replaced it after the first engine blew up. Unless it's contaminated badly it's should be good to re-use. I want to be on the Lucky Dog Team when you race it! Be sure to use Loctite on the DS pump pulley, the little tiny Allen head screws that hold it still on the shaft. Retro Racing just had theirs get loose on the shaft and threw the DS belt off. It may not have those screws, I may have used a Fenner Bushing when I went to a larger pulley, but be sure that's tight when you rebuild. Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
boxkita Posted October 2, 2017 Author Share Posted October 2, 2017 I've got to build 3 engines for lucky dog. One for Saturday, one for Sunday, and one because endurance racing. Co drivers will split the engine cost for the day. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
NSFW Posted October 3, 2017 Share Posted October 3, 2017 Sounds like a plan. Where do I sign up? Link to comment Share on other sites More sharing options...
boxkita Posted October 3, 2017 Author Share Posted October 3, 2017 Getting some help on the street car this week. Let's see how it works out. I may get a working engine sooner than later. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
legacybt Posted March 8, 2018 Share Posted March 8, 2018 How good are you at drawing? Need accurate measure of holes on section that attaches to wagon and same for those that attach to the suspension bits? Basically a 3d drawing of the whole thing. I can send that to msi and see they can modify a sti subframe s mount points to fit the lgt mount points. Or 3d scan it? Well I didn't take any fancy new-age 3D scan or anything, but I did finally confirm that the mounting holes for a STi subframe (2015) will not fit. Measurements from centre to centre of mounting holes Legacy, STi Rear width - 36 1/2", 33 5/8". Front width - 38 1/8", 41 3/4" Front to rear mount - 18 1/4", 23" Corner to corner - 41 5/8", 44" Link to comment Share on other sites More sharing options...
boxkita Posted March 8, 2018 Author Share Posted March 8, 2018 Well, that dream died. :-) Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted March 8, 2018 Author Share Posted March 8, 2018 AmCon runs Wednesday too. http://amconshows.com/spring-shows/seattle-wa/ Looks like I missed it again :-) http://amconshows.com/upcoming-shows/ Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
