SFerrell Posted September 23, 2016 Author Share Posted September 23, 2016 H&R springs should only lower the car about 1.3" from stock height. Sounds like someone cut and re-welded the front axle housing. It was way more than 1.3 inches. I couldn't get my shoulders under the front bumper before. Now I can crawl almost all the way under it. Link to comment Share on other sites More sharing options...
LatentWagen Posted September 23, 2016 Share Posted September 23, 2016 As soon as I find a trustworthy alignment shop I'm going to take it in and have this checked again. I don't know what 4 degrees of + camber looks like. Take another pic. Make sure you're from a little farther behind the car and with a 100% flat horizon. The pic you took could go either way, with perspective (since you were close) and a little tilt of your camera, we can't really tell. Looks like less than 4.0, though LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
LatentWagen Posted September 23, 2016 Share Posted September 23, 2016 This is the kind of shot that would help. The FRONT of this car is probably in the -3.0 to -4.0 range (just an eyeball guess). Image the reverse of that. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
GTEASER Posted September 23, 2016 Share Posted September 23, 2016 And that back wheel is at like -15 degrees. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
SFerrell Posted September 23, 2016 Author Share Posted September 23, 2016 Okay. Well I appreciate the help. I have grocery shopping to do. I will try and get a decent picture of my Frankenstein Legacy. Anyone want to buy it?? Or trade me a Saab 92X Aero? Maybe a MazdaSpeed 3? Link to comment Share on other sites More sharing options...
magnusonsubie Posted September 23, 2016 Share Posted September 23, 2016 I had H&R springs on my wagon and one point and I couldn't crawl under the front bumper with the car just sitting on the ground. Using that as a measurement for being ~3 in lower is inaccurate. Please post some pictures of farther away like latent suggested and then we can give you an idea of how much camber you have. For instance my car has -1.5* in the front and -2.5 in the rear because I haven't bought white line arms yet to adjust the rear. But I've got the print out from the alignment shop. http://uploads.tapatalk-cdn.com/20160923/27fd2781933b06c50989ba28844f0724.jpg 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Phate Posted September 24, 2016 Share Posted September 24, 2016 I don't know what 4 degrees of + camber looks like. It's literally a 1.75 inch difference between the top of the tire and the bottom. Visible from space From the picture, the car looks like it's around stock height with less than a degree of positive camber. Take the wheel off, loosen the two nuts holding the strut to the knuckle, and rotate the upper one until you see the top of the knuckle get pulled in as far as it will go. Put a wrench on the bolt to hold it in that position, Tighten the nut, then tighten the nut on the bottom bolt again. If things aren't completely bent to shit, it should now have negative camber. Link to comment Share on other sites More sharing options...
joe r Posted September 26, 2016 Share Posted September 26, 2016 I will tell you right now, if you have +4 positive camber the dealership smashed your car into something or you have outback rear control arms and other pieces. Lowering our cars always nets you negative camber in the rear. Link to comment Share on other sites More sharing options...
Dre617 Posted September 26, 2016 Share Posted September 26, 2016 I will tell you right now, if you have +4 positive camber the dealership smashed your car into something or you have outback rear control arms and other pieces. Lowering our cars always nets you negative camber in the rear. i think he mentioned +4 camber in the front not rear Link to comment Share on other sites More sharing options...
