LGT512 Posted July 22, 2016 Share Posted July 22, 2016 So I'm thinking and wanting to go stage downpipe an a full protune But I'm about to hit 140,000 mile on my LGT, what is recommended to do at this stage of the engine to make it safe to go stage 2 or should I have nothing to worry about an just go ahead and do it. Thanks in advance Link to comment Share on other sites More sharing options...
coldsoda Posted July 22, 2016 Share Posted July 22, 2016 every possible maintenance item due, plus any preventative maintenance you can think of. are you consuming any oil? how much? just a downpipe and a protune is very common and proven quite reliable with a good tuner. Just make sure the car is 100% mechanically sound. Link to comment Share on other sites More sharing options...
xtea Posted July 22, 2016 Share Posted July 22, 2016 Get a black stone oil test done too. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 22, 2016 Share Posted July 22, 2016 Where in Texas are you ? I think Cobb is in Austin. If you can do a etune, www.tuningalliance.com is the best place. Tell them I sent you. How does the idle and run, if it feels good you should be fine, if you think it's not running smoothly, a compression test make be in order before you add more HP. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RWebb Posted July 22, 2016 Share Posted July 22, 2016 I 100% advise against this because "140,000 mile" IMHO Link to comment Share on other sites More sharing options...
bdfreetuna Posted July 23, 2016 Share Posted July 23, 2016 Get compression and leakdown test and go from there. Then you'll know if your motor is up for it or not. Link to comment Share on other sites More sharing options...
Nyy8 Posted July 23, 2016 Share Posted July 23, 2016 140k miles on the motor... and I'm assuming the original turbo What could possibly go wrong? Link to comment Share on other sites More sharing options...
coldsoda Posted July 23, 2016 Share Posted July 23, 2016 Ive got about that much mileage on mine and its running strong at stage 2. I do have a good tune, which makes all the difference. that and I have done every possible maintenance item you can imagine to keep the car in good working order. all stock engine and turbo. I do not burn more than 1/4 quart over 3k mile OCI. it can be done safely, but you have to do your part to take care of the maintenance over the life of the car. I would agree with bdfreetuna that a compression/leakdown test would be a good indicator of current engine health Link to comment Share on other sites More sharing options...
Phate Posted July 23, 2016 Share Posted July 23, 2016 Do all maintenance, have a compression and leakdown test done to establish the health of the engine, and if everything checks out, go for it. If it's gonna blow up at stage 2 power levels, it's probably gonna blow up at stock power levels. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 23, 2016 Share Posted July 23, 2016 Have to also agree with coldsoda, it would be a good idea to check for shaft play in the turbo. My vf40 went at 142,000 miles. When the turbo goes in 95% of the cases it takes the engine with it. A little money spent now will have great payback in the future. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LGT512 Posted July 23, 2016 Author Share Posted July 23, 2016 ok thank for all the information very helpful will do all the right preparation if i do en up doing it Link to comment Share on other sites More sharing options...
LatentWagen Posted July 23, 2016 Share Posted July 23, 2016 I 100% advise against this because "140,000 mile" IMHO I went stage two at about 140k. 186k now and just got my Blackstone report back, car is running flawlessly with no indication of wear. IMO, if properly tuned, the car will be more reliable over the long term versus the stock tune. Especially after losing cats, and opening up the restrictive downpipe. As others have mentioned, check the turbo out. Do a compression test. Make sure you're up to date on maintenance. You might think about a fuel injector service, and maybe a new pump. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Merc6 Posted July 26, 2016 Share Posted July 26, 2016 Stage 2 50K miles I accidentally the 1st turbo. 2nd turbo was deemed contaminated and turned over to the proper turbo fixing authorities. Compression test UOA and swap turbo is my suggestion. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
RWebb Posted July 27, 2016 Share Posted July 27, 2016 What could possibly go wrong?:lol::lol: Best of luck! Link to comment Share on other sites More sharing options...
Tuning Alliance Posted July 27, 2016 Share Posted July 27, 2016 Shoot us a message and we can get you setup properly. Thanks again max for the recommendations! -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted July 27, 2016 Share Posted July 27, 2016 Your welcome, Brian. In case anyone missed this thread, http://legacygt.com/forums/showthread.php/going-stage-2-maintenance-needed-254777.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
