Merc6 Posted January 28, 2016 Share Posted January 28, 2016 I'm sure there is probably a difference in mileage, engine condition etc. between your two cars. Maybe some more info will shed some light on that. Short list: 10103AC050 EJ257 shortblock 10105AA720 Gasket Kit Gates TCKWP328 Timing belt+water pump kit FJK1001 Exedy Replacement clutch kit. 15049AA070 Oil pickup (no cracks in mine, but screen has a hole in it) I simply glanced at the TOB snout, should dig deeper into it's condition before I pull the trigger on a simple clutch replacement kit. Also need to inspect the oil pump, everything is telling me to just get a new one but the broke side of me is saying inspect it first. I don't remember who, but someone said the gates water pump didn't last as long as the OEM ones. I ended up getting the OEM belt 13028AA240 and OEM closed (not stamped) impeller water pump 21111AA026 instead. Since I actually had turbo and engine failure, I got a EJ257 shortblock *Cough* (many years back) 10103AC040 B25C 704 with BBBB pistons, VF52 turbo(JmP 11 blade rebuild/upgrade painted black), oil pump 15010AA300, oil cooler 21311AA151, head bolts 11095AA042, and 2 OCV's 10921AA020 as well. For the half moons I splurged and got the LIC aluminum ones and the cam bolts I went TIC FU. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted January 29, 2016 Author Share Posted January 29, 2016 Well, if this pump and belt last the next 20 months that will be fine with me. Just needs to last me through school. Link to comment Share on other sites More sharing options...
MTBwrench Posted January 29, 2016 Share Posted January 29, 2016 school? Are you an engineering major too? Seems to be the fad around here! Sent from my iPhone using Tapatalk MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 29, 2016 Share Posted January 29, 2016 I'm one of the ones that had to replace the Gates water pump after a few month's. It leaked out the weep hole. But there are others that do ok with them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
StkmltS Posted January 29, 2016 Share Posted January 29, 2016 school? Are you an engineering major too? Seems to be the fad around here! Sent from my iPhone using Tapatalk They're the only people with projected incomes high enough to support owning an LGT My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted January 29, 2016 Author Share Posted January 29, 2016 Instrumentation/Industrial automation. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted January 30, 2016 Author Share Posted January 30, 2016 Any idea what kind of flywheel this is? Looks like a Cusco 10lb one. Currently don't have access to an accurate scale. Link to comment Share on other sites More sharing options...
Harsho1 Posted January 30, 2016 Share Posted January 30, 2016 Any idea what kind of flywheel this is? Looks like a Cusco 10lb one. Currently don't have access to an accurate scale. Since there are hot spots on the BACK of the flywheel, I would say it looks like a chunk of scrap metal. Any transmission or machine shop should tell you the same thing. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted January 30, 2016 Author Share Posted January 30, 2016 Yeah it's been run pretty hard by the looks of it. It just doesn't make sense why such an expensive/light flywheel would be on a basically stock car. The car was already switched to SMFW with a simple exedy oem replacement clutch by someone else. It's whatever at this point, I'm just going to put an OEM SMFW in it. Link to comment Share on other sites More sharing options...
MTBwrench Posted January 31, 2016 Share Posted January 31, 2016 Yeah it's been run pretty hard by the looks of it. It just doesn't make sense why such an expensive/light flywheel would be on a basically stock car. The car was already switched to SMFW with a simple exedy oem replacement clutch by someone else. It's whatever at this point, I'm just going to put an OEM SMFW in it. This reminds me of when I discovered that the brake dust shields on my seemingly "stock" outback had been cut to clearance LGT rotors... And holy hot spots, Batman. That flywheel is roasted! Sent from my iPhone using Tapatalk MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 1, 2016 Share Posted February 1, 2016 I happen to have a Spec LWFW which has a replaceable friction surface on if your interested. It works great with a Spec clutch. I think it's 17lbs. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted February 2, 2016 Author Share Posted February 2, 2016 OEM already on the way, thanks though. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted May 21, 2016 Author Share Posted May 21, 2016 No serious updates except that the heads are bolted to the short-block and got the timing belt on. Just need to finish running some new vacuum lines, prime it and stuff it back into the car. The right side timing covers were both broke and plasti-welded together. I cant believe Subaru doesn't sell them WITH the seals. http://i1308.photobucket.com/albums/s617/boostedturbododge/WP_20160514_11_21_50_Pro_zpshsvyzqqm.jpg http://i1308.photobucket.com/albums/s617/boostedturbododge/WP_20160514_11_22_14_Pro_zpshskgeuar.jpg http://i1308.photobucket.com/albums/s617/boostedturbododge/WP_20160514_11_22_26_Pro_zpsgkbfwdzs.jpg Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted June 11, 2016 Author Share Posted June 11, 2016 Couple questions. First, where did this little guy go towards the front of the engine? [/img] Link to comment Share on other sites More sharing options...
seanyb505 Posted June 11, 2016 Share Posted June 11, 2016 Question 1: Power steering pump. Question 2: I used an aftermarket Boost control, so I'm not positive on stock routing. But yes I think that inlet port is for boost control. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted June 11, 2016 Author Share Posted June 11, 2016 Question 1: Good, I thought I was going crazy sitting there looking for a place for that. Question 2: Yeah the only really good diagram I have found has an electronic boost control solenoid. I'm pretty sure the second port on the OEM boost solenoid goes to the wastegate tee. Link to comment Share on other sites More sharing options...
seanyb505 Posted June 11, 2016 Share Posted June 11, 2016 Very last stock boost control port to inlet, second to turbo and such Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted June 11, 2016 Author Share Posted June 11, 2016 Yeah, I'm looking at it from left to right (left towards front of car, right towards the back of car). Left to second port on inlet tube, right to wastegate tee. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted June 11, 2016 Author Share Posted June 11, 2016 Ah, I have it backwards then, thanks for the info! Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted June 25, 2016 Author Share Posted June 25, 2016 http://i1308.photobucket.com/albums/s617/boostedturbododge/WP_20160624_16_33_47_Pro_zpsaycruq5v.jpg' alt='WP_20160624_16_33_47_Pro_zpsaycruq5v.jpg'> That much closer. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 25, 2016 Share Posted June 25, 2016 Your just a little bit behind BMB, do you think your's will be running before his... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 25, 2016 Moderators Share Posted June 25, 2016 I'd imagine so. I'm slow as molasses. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted June 25, 2016 Author Share Posted June 25, 2016 No lol, it might get in the bay today but it's not firing up today. Still need to replace the front struts, replace the back right wheel hub and rear brakes. In the mean time I hope nothing is fucked up and she just purrs like a walrus when we turn it over. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted June 26, 2016 Author Share Posted June 26, 2016 It's bolted to the transmission now. Have to take the turbo off again because I forgot the damn support bracket. Also missing the mounting bolts for the ac and alternator. Getting new belts and tensioner pulley. After all that BS drop the radiator back in, TMIC, intake tubing and a new battery. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 26, 2016 Share Posted June 26, 2016 Not sure which tmic you have, but I've found leaving the turbo loose on the up pipe until the tmic is located and tighten in the TB hose and turbo outlet is easier. Allows the turbo to move around a bit and help the tmic line itself up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
